#211 | |
Kuruma Otaku
So you would need two electronic, independent wastegate controls, a mess of piping, the two different turbos, and probably a front mount air-air intercooler and a water-air inter-stage-cooler. Plus a standalone ECU that can handle a map and outputs for the two wastegates. Plus it would need to regulate how hard the boost comes on from the compounding as it probably wouldn't build in a linear fashion. The practical is a headache. The theoretical is massive boost, very minimal lag, and huge power.
Because titanium. |
#212 |
Drives: slow :(
i wonder what type of internals well see on this motor?.... the last 2 scion 4 cyl motors both had forged cranks ant the new 2ar from the new scion has a sleeved block hmmm....
#213 |
Drives: '06 AM V8V Coupe
So today the new pics that came up seem to show a new ! engine in the glass model...
If it is the real thing, maybe we can speculate on some stuff So I said in that thread the 2 engines look like they're the exact same dimensions, so my hopes for Valvematic are dead (weep), and VVTL-i won't be there since it has that extra rocking arm thing which similarly takes up an extra inch on either side.So this suggests this motor has Subaru i-AVLS or something of that sort, otherwise >200hp would not be so easy to do...which I am honestly surprised with since they said Toyota is reworking just about everything. Another possibility is that the D4-S mixes air and fuel much better and allowed them to optimize the lift for high rpm operation... |
#214 | |
Drives: 2010 Evo X MR-T
the mention of reworked bore and stroke also sounds promising. it just may turn out to be quite rev happy
#215 |
You should tell Honda that! Where is AVTEC?Well then, without variable valve lift, I hope this lives up to its expectations... |
#216 | |
Drives: N/A
And Subaru uses AVCS. Which, I believe, advances or retards the cam timing as needed to a certain limit. I'm just going off of memory here.The big difference is the reversed intake. The FB201 has the opposite intake direction. I know it was different from the old display, I think. BRZ Prologue FB201 This was discussed in the topic and from what Ichitaka was saying, makes a big difference in piping.
#217 |
Drives: gti, nsx, integra type r,porsche911
what sort of difference?
I just read from the other member saying it will have less LAG. |
#218 |
I dunno actually AVLS looks smaller than VTEC or VVTL-i, so maybe there's a chance. But it's still a disappointment considering the better stuff out there nowadays...
And yea AVCS is your run of the mill cam phasing, but only 2 profiles...which kinda sucks. I hope they switch to continuously variable, it lets you do interesting things with the exhaust timing to limit pumping loss, if there is no intake duration changing. @CyberFormula - I think he means that it will be easier to run piping to a front mount intercooler. Less piping between intercooler and intake, less lag, makes sense. |
#219 | |
Drives: free Hyundai, 2006 Kawasaki ZX6R
#220 |
People with FI experience, how much headroom do the manufacturers usually leave in terms of knock resistance? I'm under the impression that moderate boost setups usually don't decrease compression ratio... Is it correct that for performance cars they usually design it to run on 91? Then with 93 a little boost wouldn't be much of a problem right?
#221 | |
#222 | |
MODERATOR-SAMA
Drives: Swagtron Scooter
From my experience, cars that have been offered from the factory with forced induction had a few points of compression removed to make the engine perform more reliable. Even if stock boost pressures are a mear 5psi on small turbos. Today in many more modern cars, knock is controlled via ECU or a separate device that detects pinging and tells the ECU to either reduce boost pressure or pull or add timing. So we can effectively run low-octane unleaded AND high-octane unleaded in performance cars without worrying about knocking. So i guess to answer your question, if we turn up the boost moderately we have to make all other conditions equal during the 4 stroke process, so we have to turn up the fuel, and pull timing. This makes the compression ratio virtually unchanged allowing you to run the same amount of low-octane fuels safely and effectively, and 93 octane or similar high-octane ratings wont really have a major effect on the performance if not just better peace of mind. When we start bumping up internal pressures from factory settings is when we need to start thinking about high octane to reduce risk of knock. So not all performance cars have really high compression ratios from the factory, including ratios added from FI. That force makers to build the engine around certain octane ratings. But some engines have been tested and seen to run more optimally on higher octane ratings due to their nature. Probably because they have pretty high factory internal pressures or aggressive factory timing maps for performance.
#223 |
Well if timing has to be retarded that's not good, as it is essentially reducing compression, so I guess I was asking how much pressure you can run literally without changing anything but the amount of fuel (but not the A/F ratio either).
#224 | |
Drives: N/A
? I didn't think you could run any boost without reducing the dynamic compression unless you plan on running race gas.
| Joke Thread | VenomRush | Off-Topic Lounge [WARNING: NO POLITICS] | 27 | 07-09-2011 01:44 AM |
| The Music Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 03-28-2011 12:35 PM |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 06:10 PM |
| FT-86 to debut new GPS-track day technology for use on track and GT5! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 01-30-2010 12:30 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
