Old 02-18-2014, 12:57 AM   #211
Techfl3x
Techfl3x's Avatar
Drives: Firestorm Red FRS/86 MT
Originally Posted by lbroskee View Post
We threw it out and got the correct cable to make it PnP. Not sure y they automatically send this crap out, but i wanted it to b fully reversible
Agreed. I ended up using an old cable from a previous hid kit. Worked out nicely
Techfl3x is offline   Reply With Quote
The Following User Says Thank You to Techfl3x For This Useful Post:
lbroskee (02-18-2014)
Old 02-18-2014, 01:07 AM   #212
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
ya wen i did my retrofit the bulbs on my HID kit were useless so we ripped that part of the harness apart to use with the new bulbs. improvisation FTW
lbroskee is offline   Reply With Quote
The Following User Says Thank You to lbroskee For This Useful Post:
Techfl3x (02-18-2014)
Old 02-18-2014, 07:29 PM   #213
Techfl3x
Techfl3x's Avatar
Finally finished this DIY. Thx for the info. Haven't aligned them yet but cut off line looks nice. Was bummed that one ballast doesn't turn on immediately though. I have to switch them on and off.
Old 02-18-2014, 11:11 PM   #214
lbroskee
lbroskee's Avatar
ya i did a quick alignment on mine but still haven't done it correctly. i can't find a clear wall with enough room to do it that doesn't put my car in the middle of a road
Old 03-20-2014, 12:37 AM   #215
BaeK
BaeK's Avatar
Drives: 2013 Whiteout FRS
Wow, huge thanks to @civicdrivr @raul and HIDPlanet for the awesome guide/help. I was finally able to complete the project over the weekend and I gotta admit, its a lot better than our stock halogens.
Raul and i have noticed that the relay harness that's being shipped out now is different than the one pictured on the first page.
For pics:
http://www.hidplanet.com/forums/show...2013-Scion-FRS
retrofit
BaeK is offline   Reply With Quote
The Following 2 Users Say Thank You to BaeK For This Useful Post:
civicdrivr (05-06-2014), raul (03-20-2014)
Old 04-25-2014, 11:59 PM   #216
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
Originally Posted by civicdrivr View Post
That's what I'm thinking as well.
@thorlius - do you have the new harness that has a ground at each ballast instead of at the battery?
Sent from my Nexus 4
I had issues with My amp that were oddly similar... I have a feeling it's all related.
Oh and this thread is amazing! I love the using the stock projectors in the high beam spot just for the DRLs. Looks sick... I Hope people start playing with the taillights some. It'd be cool to see some custom ones, though, the aftermarket has really done well on that front.
I don't think I can do this mod until I fix the lights in my miata or at some point I will have to go from these to Oem Miata garbage... It's awful... anyone who's owned an NA can attest to this.
zohare is offline   Reply With Quote
Old 05-01-2014, 11:51 PM   #217
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
Wow, it's been over a year and I somehow missed this and am just seeing it now. I pretty much just dealt with the flickering, because it's subtle and only an issue at night at stoplights, half the time.
I'm ordering the new wiring harness with those grounds (mine is the one with just the battery ground) and also some 4300k bulbs instead of the 6000k's. Hopefully that (the harness, not the bulbs) fixes it. If not, ballasts are next.
Brandon
thorlius is offline   Reply With Quote
Old 05-02-2014, 03:16 AM   #218
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Could you reupload your pictures to imgur? This way we can see the tutorial. your images are over-bandwidth!
Mad1723 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mad1723 For This Useful Post:
civicdrivr (05-06-2014), kalamitykode (05-02-2014)
Old 05-06-2014, 01:28 PM   #219
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I'll toss them on Flickr, thanks for the catch.
Sent from my Nexus 4 using Tapatalk
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-28-2014, 12:46 PM   #220
20firestorm13
Drives: 2017 Halo Toyota 86
The pictures are no longer accessible and I just got mine in and I need to adjust them. This is the only link I can find for it lol.
I finally got around to getting the headlights aimed properly.
Tools Needed:
-Tape (painters tape is preferred since its easy to see, but all I had was duct tape)
-Measuring tape (one that is at least 25')
-Phillips head screwdriver
-Wall and flat, level ground (I find that loading docks are perfect for this)
-Night
The basics: The DOT standard for aiming lights is simple. Park the car on flat, level ground 25' from a wall. Measure the height of the head light from the ground (use the little dot in the headlamp lens to measure from), subtract 2", and line up the uppermost portion of the cutoff with that number.
For example: The headlight in the below picture 26" from the ground. Therefore, the top of the cutoff should be 24" from the ground (when parked 25' from the wall).
The adjusters youre looking for are these:
Passenger side:
Driver side:
The screwdriver goes between these two slots:
Remember the old saying - righty, tighty, lefty, loosey? Well, righty in this case raises the beam, lefty lowers it.
And its as simple as that.
Color band at ~100'
Overall, these projectors are very impressive given their size and price point. The highbeam impresses me most. Unfortunately I was unable to snap pics of that as I was being questioned by cops.
20firestorm13 is offline   Reply With Quote
Old 08-04-2014, 02:03 PM   #221
Mooseknuckle44
Mooseknuckle44's Avatar
The adjustment is really simple. If you're looking at the backside of your headlights there's 2 little knob looking things with a toothed washer underneath them. One is on the corner down towards the wheel and one is right there in plain sight closer to the hood. Just wrench on those til you're happy with their direction. One is for elevation and one is for right to left. Good luck.
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
Mooseknuckle44 is offline   Reply With Quote
The Following User Says Thank You to Mooseknuckle44 For This Useful Post:
civicdrivr (08-12-2014)
Old 08-08-2014, 04:47 PM   #222
xBlackBillGates
Drives: N/a
Question
Does anyone know if we can use this kit to retrofit aftermarket headlights such as the ones by spyder, spec-d, and winjet so we can have led drl's instead of halogen? I want to have the "expensive" look of LEDs and bi-xenon.
xBlackBillGates is offline   Reply With Quote
Old 08-08-2014, 04:49 PM   #223
Mooseknuckle44
Depends on how comfortable you are baking open the lights. Should be fine but don't hold me to that.
Old 08-08-2014, 09:41 PM   #224
xBlackBillGates
Drives: N/a
If it works I will surely post pics here. Although I won't get my FR-S until 2015 due to me being active duty in the military. Even then it depends on my permanent duty station and by that time Scion may have hid and led drl as a factory option. Just doing research before hand so I can put my pennies in the right jar (My I seem to ramble a lot). If anyone else attempts this please post pics and your methods here.
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 07:37 PM
The Retrofit Source Bi-Xenon FR-S Retro-Quik Conversion Andrew @ TRS Exterior Parts - The Rest 84 07-23-2012 09:43 PM
OEM Fog Light install! ON and working! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 07-04-2012 07:11 PM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 06:07 PM
Five axis limited retro Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 28 05-18-2012 03:16 PM
