#2213 | |
Also use covolvers. If you're not using covolvers you're not unlocking the potential of V4a IMO. The best I've found is here: http://forum.xda-developers.com/show....php?t=2439254 fyi majority do not work for me. But BBE-2 is the best of the ones that work. Also towards the bottom of your v4a options there is an option for max output did you try turning that up? Hope some of this helps! |
#2214 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Bluetooth is odd with this thing. Works find on my Edge but any Iphone will not pair |
#2215 |
Not Bаnned Anymore
hmm I am not too sure then. What does the error say?
#2216 |
Not Bаnned Anymore
#2217 |
Not Bаnned Anymore
Yeah I can see it now. What OS are you on?? Mine looks way different
#2218 |
Not Bаnned Anymore
I have to check what mine is now, yours looks much nicer haha! Sorry I have no insight for you on the bluetooth issue.
#2219 |
Drives: 2014 Scion FR-S
![]() I'm using the bottom one. Not many options in that version. To test amp/sub I hooked up RCA to my phone and it thumped clean and hard. Sent from my SM-N920T using Tapatalk Removed it and having trouble adding back. Last it addled new what cpu and I just choose the last one.
#2220 |
I see, I am not using the Xhifi version because they no longer update it. When you go to the official site here:
http://vipersaudio.com/blog/?page_id=48 I use this one: FX version v2.3.4.0 (Android 2.3~5.0) and in there is a 2.3 and 4.x version. I installed the 4.x version. Works perfect |
#2221 |
USMC
Drives: 2013 FR-S 6-MT Raven
Has there been anyone on here that didn't have a SD card reader installed in their head unit? I've contacted cafi with no response. Also my C: drive says I have 5gb available but I can't even update any apps or download any. Please help someone!!!
Sent from my SAMSUNG-SM-N920A using Tapatalk |
#2222 | |
Not Bаnned Anymore
and TBH I haven't even looked at my SD card slot haha
#2223 | |
USMC
#2224 |
Drives: GT86 trd
Hi All
i am just installing my dashlinq4 in the UK I bought this second hand with the main plan to use the DEFI app linked to the advance series gauges - that and spotify! The app works fine on my phone / tablet but struggling to get it to connect to the dashlinq.. ![]() ![]() connection from in the app seems to go ok, though it notes "connected to phone" though when i go into the bluetooth settings it is as a obd device and shows as disconnected Am i missing something or am i looking at a need to root it? (hope not as havent got a clue on rooting!!! Thanks Neil |
#2225 |
Finally got my camera connected. Couldn't find anywhere good to run the wire. I have 2 cameras but 1 would require i cut a hole in car to push through. I pulled the surround piece off and ran the cable for this one for now. Ran cable through the license plate light but it doesnt seat fully. Any ideas?
I had to remove my LED license plate bolts due to being to wide to fit through the camera mount points. I already had to drill out my license plate and frame lol. I MAY just drill a hole and mount the other camera but not sure about having the camera set off to the side... ![]() ![]()
#2226 |
On my BRZ Limited I was able to run the wire to the side of the light and have it sit flush without cutting/drilling, but my wire went to the left of the license plate light whereas yours is to the right. I'm not sure if maybe theres more space towards the left of the light, but your wire may just be too thick. It might be worth a shot to try.
Also in case you didn't know, you can run the wire from the trunk lining to the inside of the car through that rubber grommet on the left of your first picture. |
| REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 06:23 PM |
| Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 03:54 AM |
| How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 04:58 AM |
