#2199 |
NASA SpecE30 Racer
If you have to modify the OEM MAF sensor wiring, then this is probably a good time to extend the wiring. I would cut off the sensor where you broke the white wire and add some length to each wire. I had to do it for a Vortech install, and just used the same size wire and some butt connectors. Place some black plastic tubing over it and it looks just like OEM.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
The Following User Says Thank You to King Tut For This Useful Post: | blackfireball5 (11-26-2014) |
#2200 |
Drives: Scion FRS
Ordered my flex fuel kit from motoeast and ordered a tune from James @ HRI tuning.
Going to see how the gtx2867 does with some more boost! |
#2201 |
Drives: RX-7 / BRZ
Has LJ barricaded himself inside and cut all phone lines/interwebz to avoid BF deals?
![]() @FullBlown We know your in there!
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
The Following User Says Thank You to Kiske For This Useful Post: | limitedblkwrx (11-28-2014) |
#2202 |
My car's going in for more boost tune. I'm at 10lbs now, we'll be tuning with the 14lb wastegate spring. I've got the gtx2867 and meth injection. Unfortunately all we have is CA 91 gas, but I'm still hoping for decent numbers with the meth.
#2203 | |
Drives: Scion FRS
#2204 |
Drives: RX-7 / BRZ
Alright guys, on the overpipe. I plan to install perrins 2.5 next week or so. I'm wondering if you guys think I could slice (and reweld) the OEM heat and make it work on the aftermarket overpipe? My goal is to take a few moments to help reduce heat and stop the potential melting of the sway bar bushing that some turbo owners have had.
My main reasoning is I'm asking if this would be more effective than using header wrap?
#2205 |
in orbe terrum non visi
Drives: violent
Pretty sure they are different steels and it would Crack at the welds. But I don't have one in front of me. I double wrapped mine in dei titanium wrap and my sway bar bushings are fine.
I have E85 where there isn't E85, that's my secret.
The Following User Says Thank You to Reaper For This Useful Post: | Kiske (12-05-2014) |
#2206 |
King of Kiwi Palace
Drives: Faster than you
FYI.. If you race your car and you're using the FBM Turbo/Mocal Oil Cooler kits
The Mocal oil filter sandwich plate WILL AND CAN come loose. Recommend before and after a racing event and possible in between sessions, you may need to retorque the center thru bolt if you see slight oil residue on the plate. And definitely recommend after each oil change to retorque it regardless since you will have the filter off.
The Following 2 Users Say Thank You to Ironsquid For This Useful Post: | blackfireball5 (12-05-2014), Reaper (12-05-2014) |
#2207 | |
Drives: Scion FRS Firestorm
#2208 |
Drives: RX-7 / BRZ
How far do I need to turbo drain through the oil pan. I have the hole drilled and everything fitted, just not sure if the inside should be flush or if the drain should push through an 0.5-2" or so.
#2209 |
I pushed mine in a 1/16" and it's been good.
The Following User Says Thank You to Dipstik-sportech For This Useful Post: | Kiske (12-06-2014) |
#2210 |
Drives: Scion FRS
Flex fuel from moto east gets here monday, hopefully can get it installed that day so Chris can start working on the tune.
Not sure if I want to keep the car, part of me is really tempted to get a 235, friend got one and it responds crazy to just bolt ons and a tune. |
#2211 |
Drives: Toyota GTS 86
About to purchase the stage 1 premium kit w/ GTX2867
aiming for about 400+ whp on e85, what else would i need to purchase to compliment the kit? catch can, walbro 485 fuel pump, 1000cc injectors are what i have written down so far, did i miss anything?. might just wait until i have enough to buy a radiator+ shroud + fans and a boost gauge, just not sure what i should prioritise and if u guys could help me ![]() |
#2212 | |
Drift King
Drives: '13 Firestorm FR-S 6MT
Well you'll need a clutch, possibly flex fuel depending how you want to run your setup. 400whp should be possible on e85, e85 runs a lot cooler, depending on the temperature where you live, you may be able to skip on the radiator stuff for a while Sent from my iPhone using Tapatalk
'13 6MT Firestorm FR-S
Tags |
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
