go_a_way1, MisterSheep
Old 06-24-2020, 03:27 PM   #22051
MJones_RB
MJones_RB's Avatar
Actually, I had the opposite idea.
What we need are motor mounts that have a mini "air suspension" setup for the bushings. That way, when it's time to change spark plugs, you push a button, raise the engine, batta bing, done.
Actually all we need are access holes across from the spark plugs so you can get a socket thru the fenderwall.
MJones_RB is offline   Reply With Quote
The Following 3 Users Say Thank You to MJones_RB For This Useful Post:
Dadhawk (06-24-2020), humfrz (06-24-2020), soundman98 (06-24-2020)
Old 06-24-2020, 08:24 PM   #22052
Oh sure, but my solution is much cooler.
MJones_RB (06-25-2020)
Old 06-25-2020, 12:52 AM   #22053
humfrz
Well, my second vehicle had a "door" you could open to access the spark plugs -
Dadhawk (06-25-2020), MJones_RB (06-25-2020)
Old 06-25-2020, 01:06 AM   #22054
soundman98
ProCrastinationConsultant
soundman98's Avatar
And a nice fender to sit on while doing it!
humfrz (06-25-2020)
Old 06-25-2020, 01:45 AM   #22055
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Originally Posted by Compelica View Post
Where did you specifically lubed it btw? Got a brake squeak for me that I need to fix real quick.
In my case, I went ham and lubed everywhere (except of course where the pad contacts the rotor).
I lubed all possible contact points where the pad meets the caliper assembly, and I even went as far as to lube the pad clips themselves.
Can't say this is a guaranteed solution because my car is just now starting to squeal again. Probably a result of me running Hawk HP+ pads though, which according to other forums squeal like a motherfucker), so I'm not gonna worry too much about it anymore (until maybe when I switch to steel brake lines in the future).
The Following User Says Thank You to KR-S For This Useful Post:
Compelica (06-25-2020)
Old 06-25-2020, 01:55 AM   #22056
Compelica
Compelica's Avatar
Drives: 86 GT
Thanks, I'll monitor for a while more then. Assuming brake pressure range from 0 to 10 (where 0 is no pressure and 10 is with foot all the way down) I get squeaks at 3-4, but not less or more.
I'm on Stoptech 309s.
Compelica is offline   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
KR-S (06-25-2020)
Old 06-25-2020, 10:30 AM   #22057
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
My dad had lots of cars with those style "side doors". But he also had cars with a lid that lifted up like this.
The Following 3 Users Say Thank You to Stephen W. For This Useful Post:
humfrz (06-25-2020), MJones_RB (06-25-2020), soundman98 (06-26-2020)
Old 06-25-2020, 11:06 AM   #22058
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Corvair?
dragoontwo is offline   Reply With Quote
The Following User Says Thank You to dragoontwo For This Useful Post:
humfrz (06-25-2020)
Old 06-25-2020, 04:25 PM   #22059
humfrz
Yep, my younger brother had a Corvair (1961), WO the turbo.
It was a good car till it wound up upside down in a corn field one night - only two curves in that county in Ohio, and he missed one of them -
Old 06-25-2020, 04:39 PM   #22060
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That fan belt routing gets me every time.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 06-25-2020, 08:01 PM   #22061
Cedric
Cedric's Avatar
Recently mounted 17 x 9 ET35 Wedssport TC105Ns with 245/40/17 Yokohama Advan Neova AD08Rs
Sent from my iPhone using Tapatalk Pro
Cedric is offline   Reply With Quote
The Following 4 Users Say Thank You to Cedric For This Useful Post:
jflogerzi (06-28-2020), MJones_RB (06-26-2020), trvth (07-02-2020), Vic4uf (07-08-2020)
Old 06-26-2020, 01:40 AM   #22062
Kyyuna
Drives: 2016 FR-S
Washed and Waxed the car, but only ended up doing all the metal panels since it was getting late (doing it by hand, and no buffer tool sure was something) and was hungry, the plastics can wait later in the week haha. Still have the inside to detail up, only did minor vacuuming, gotta do the trim and panel touch ups.
Found two minor chip rust spot on the passenger side door, luckily it's pentip sized, not the worst of things.
I still need to get around to finding a decent radio to replace the OEM unit too.
Wheels, wheeeeeeeels can waittt
Kyyuna is offline   Reply With Quote
Old 06-26-2020, 07:29 PM   #22063
MJones_RB
MJones_RB's Avatar
FYI, here's the spacer Toyota designed to put between the engine and the mounts to give you enough room to access the plugs.
The Following User Says Thank You to MJones_RB For This Useful Post:
Dadhawk (06-26-2020)
Old 06-28-2020, 12:04 AM   #22064
Compelica
Compelica's Avatar
Drives: 86 GT
Took the car for a canyon drive today.
The last thing that was changed were my alignment settings (-2 deg front camber from 0) which I could finally test them properly. I couldn't believe the difference it made - I'm a novice and I'm still not fully accustomed on doing gentle inputs, however the grip at the front improved so much - previously the car would be everywhere and the stability system blinking off crazy.
So today I learned something new - never underestimate on what an alignment could do
The Following 2 Users Say Thank You to Compelica For This Useful Post:
humfrz (06-28-2020), new2subaru (06-28-2020)
