02-18-2020, 06:00 AM | #21561 |
Rust bucket enthusiast
02-18-2020, 07:54 AM | #21562 |
Drives: brz 2017 hksv2
02-18-2020, 04:13 PM | #21563 |
Drives: '15 Halo Scion FRS, 1999 Saturn SC2
I made my last car payment.
2015 Halo Scion FR-S 6MT new w/TRD exhaust, cold air intake, quick shifter, sway bars, lowering springs, & brake pads. Since then, TRD door braces, strut tower bar, & battery tie-down, Motul fluids in trans/diff & brakes, GrimmSpeed master cylinder brace, Stoptech stainless brakelines, OpenFlash Header 3 w/overpipe, OpenFlash Tablet on E85
The Following 11 Users Say Thank You to trvth For This Useful Post: |
02-19-2020, 12:05 AM | #21564 |
Finalized my tune with some Dyno pulls. Here is a link to a video of a run. In dynojet numbers put me right at 300whp and 250 wtq. Lower lines are a baseline stock brz.
2013 Series 10 FRS #553
RCE T2's, SPC LCAs -4/2.6 camber JDL 4-2-1 EL, FP and OP, Tuned by Zach@CSG on e85 RR Wilwood Front/Rear Sport BBK, Motul 600 Fluid ARC-8 17x9 SX2 GTs 245s/Koing 17x8 v730's 225's Last edited by jflogerzi; 02-23-2020 at 02:29 AM. |
02-20-2020, 04:32 PM | #21566 |
Drives: 2013 Scion FR-S Series 10
I did what you're not supposed to do: Go to a dealership out of warranty.
I developed that issue where on take off and deceleration in 1st and 2nd there is a metal pinging noise. I told them to drive the car to hear it (easily reproduced) and then re-torque all of the bolts in the rear because that is what everyone on here has recommended. I wanted to eliminate that as an issue before we talk about a bad axle or CV joints or anything. $140 later, nothing. I was at the dealer for 2.5 hours. They don't hear the sound but they claim to have re-torqued the bolts. As I pull away from the dealer, I hear the noise repeatedly. Great! Maybe it is the e-brake issue that at least one person had? Whatever it is, it is super annoying. The best part is they told me my front brake pads are "2" and "Red" and I need new ones and I need to replace the front rotors as well... Except that last May when I got the PS ECU replaced, they did a full inspection and marked all pads as "8" and "Green." Firestone never found an issue with pads or rotors and I've been to them a few times recently. How, in one year, did my pads lose 80% of their life? I should have said something. I only put like 5K miles in the past year. The rear pads are at 8, by the way. Also, they brought up the "carbon deposit" on the intake manifold that they can clean for just $150!!! I found a thread on here that shows you can wipe that up with a paper towel. Two years ago when I was at the dealer, they told me there was rust in my brake fluid and they wanted to charge $125 to flush the system. I went to Firestone and they did it for $60, and the tech said my fluid was fine. The tech used to work at Toyota and said he left because of how shitty they are. I feel stupid for not going to an independent shop or Firestone or anywhere else, and for letting these dingbats look at my car. I honestly have zero idea if they even did anything. I'm eager to go home and check my dashcam to see if they just parked it and forgot I was there, and just drove it back into the parking bay, claiming to have done something. /rant over. |
The Following User Says Thank You to mazeroni For This Useful Post: | Impureclient (02-20-2020) |
02-20-2020, 05:21 PM | #21567 |
Drives: 2015 FR-S
They don't call them stealerships for nothing. Make sure you give them an appropriate Google review, businesses should be punished for bad service and nothing does it better than a bad Google review.
02-20-2020, 10:15 PM | #21568 |
Drives: 2017 Toyota 86
Changed my transmission and rear differential oil with Motul Gear 300 also put in Mtech springs and Whiteline shift kit.
The Following User Says Thank You to Contender For This Useful Post: | trvth (02-26-2020) |
02-20-2020, 10:17 PM | #21569 |
Drives: 2015 Ultramarine FR-S AT
Continuing my quest for GT3FRS lol
Sent from my SM-G975U using Tapatalk |
The Following 5 Users Say Thank You to Kestrel For This Useful Post: | BigHugeFatGuy (02-28-2020), JesseG (02-24-2020), jflogerzi (02-21-2020), Kiske (02-29-2020), MJones_RB (02-21-2020) |
02-27-2020, 05:55 PM | #21570 |
Refilled the coolant today. Got this coolant refill vacuum kit on eBay for like$30. Uses compressed air to suck the air out of the system then the vacuum pulls coolant in till full. Should completely eliminate air pockets. Also shows if you have a leak in the system
Sent from my ONEPLUS A5010 using Tapatalk |
02-28-2020, 03:53 PM | #21571 |
Drives: 17 Asphalt 86
Finally slapped on a TRD sticker I had laying around for the useless center button on the TSC panel. Along with a quick wipe down.
Then cleaned off my winter mats as they were filthy. Did a one over with powerclean then hit it with some opti-seal afterwards. ..I actually peeled off a layer of salt from the driver side mat. I did not know that was possible lol. Edit I also stuck on the FT86Club sticker. I need to go over it to seal the adhesive around the lettering. |
02-29-2020, 01:02 PM | #21572 |
Wes
Cleaned and re-oiled my K&N filter. The amount of dirt and leaves that came out was moderately alarming. No wonder the car’s been feeling wheezy lately (could be weather too of course, but that was A LOT of junk)
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | humfrz (02-29-2020) |
02-29-2020, 02:02 PM | #21573 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | StraightOuttaCanadaEh (02-29-2020) |
02-29-2020, 07:34 PM | #21574 |
Wrapped my interior silver pieces with Avery Dennison brushed aluminum vinyl. It's not a drastic interior change but I think the brushed look is much classier than painted silver
Forgot, I wrapped my radio bezel and passenger dash panel with Avery carbon fiber vinyl too |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
