Old 11-04-2012, 01:05 AM   #2115
alan.chalkley
Drives: 4wd zooks
How many AT vs MT cars have the c.e.l. problem.
I would imagine that the AT ecu has more complex functions to manage.
alan.chalkley is offline   Reply With Quote
Old 11-04-2012, 01:33 AM   #2116
Rob_g
Drives: 2010 4Runner Trail
There's probably less AT out there as there seems to be far less demand for it.
Rob
Rob_g is offline   Reply With Quote
Old 11-04-2012, 10:18 AM   #2117
mhigham
Rob
Would be nice to know breakdown between the 2, both in problems and in build numbers.
My local dealer has at least 10 BRZ/FR-S (they are both a Toyota and Subaru dealer) and they are ALL automatics. Not a single manual.
Mike
mhigham is offline   Reply With Quote
Old 11-04-2012, 01:11 PM   #2118
xwd
Originally Posted by SpeedmasterBRZ View Post
The 08+ STi was having a big tuning issue and shortly after launch a some were recalled for a flash when others were not. They might officially launch a recall if there is enough cases that come up.
It would be nice to see on the list on the first page what fixed the complaint not just repaired. That way we can see if the flash/ecu is the best fix or not a fix at all.
You can have bad parts in a batch of ecus and others not. I work on electronics for a living and you would be surprised how much variance there is from one part to another depending on the batch and the suppliers.
The 08-2012 WRX/STi still has the same issues today as they did back with the 08 model. Guys with 2011s are still breaking ringlands due to the crappy stock tune, especially the OL/CL delay and the fact the car runs lean with the factory tune and suffers detonation. It's especially prevalent with people who run 91 octane. Has nothing to do with the electronics and everything to do with the programming.
I'm not saying there can't be something in the ECU which is the issue but I find it fairly suspect you'd have a bad input or output on the ECU itself without there being other major issues.
Old 11-04-2012, 02:01 PM   #2119
jduffy
jduffy's Avatar
I don't see your name on the repair list so either you haven't had a problem or you never reported it. I don't think you would be as positive if your car was in for repair as many times or as long as some have here.
Nope, not a single problem for me yet. No chirping, no CEL, no idle issue.
I'm neither positive nor negative, I'm a realist. This could happen to me at any time but it's a matter of percentages and statistics.
Getting emotional over an inanimate object's success or failure is counter productive. You might as well place a rock on your desk and scream at it expecting results. When my time comes I'll deal with it. I've owned enough other crappy cars, motorcycles, snowmobiles, boats, computers and audio products particularly.
In point of fact I deal with angry customers everyday so I know what it's like to be on the other end of quality issues. You do your best and try and control client expectations. Some will never be met. Again, it's a matter of percentages and statistics with failure rates.
The owners of my company know that we can't keep everyone happy so you keep the failure rates as low as you can and keep your company moving forward with the successes. I do not doubt that Toyota and Subaru are doing much the same thing.
The intriguing part regarding this issue is that there is not a blanket fix, a blanket statement from the manufacturers saying ah ha, we've got this nailed down. The mystery continues and continues and continues.
It's become a type of automotive soap opera with no ending in sight.
jduffy is offline   Reply With Quote
Old 11-04-2012, 02:30 PM   #2120
mhigham
My ECU had an open circuit. So my particular case was a hardware problem with the ECU, not the engine. Could this have been cause by a bad part in the calibration? Of course. I feel I will never get a good answer though of what the actual fix was.
Mike
Old 11-04-2012, 05:38 PM   #2121
Rob_g
Manufacturers do not like to admit there is a fault with their product, even if it's obvious. And if they do have to acknowledge an issue, you can be sure they will do so by releasing as few details as possible and downplaying any significance of the issue. I think Toyota and Subaru have really dropped the ball in regards to getting this issue fixed in a timely manner for their customers. 6 months into product launch and there still seems to be no fix that is %100 guaranteed. They are trying to fix an obvious mechanical problem with a software patch and there's just no way that is going to work for everyone. Sooner or later this ECU merry-go-round will have to stop and there's going to be possibly a large number of people still having problems.. What's the answer then? Who knows, only time will tell.
Rob
The Following 2 Users Say Thank You to Rob_g For This Useful Post:
eurospeed (11-04-2012), jduffy (11-05-2012)
Old 11-05-2012, 11:12 AM   #2122
beardy
Drives: GT86 Pearl White
Update, picked up my car today from the shop, cam sprocket changed (and something with the VVTi timing that I cannot remember the correct english word for..) Took it out for a drive, but since we are nearing winter, the roads was really slippery, even with new wintertires, but I did some 6-7k rpm runs.
Seems to be in order, but waiting for the ECU upgrade flash - sometime late november as it is not fully released in all countries in Europe.
beardy is offline   Reply With Quote
The Following User Says Thank You to beardy For This Useful Post:
eurospeed (11-05-2012)
Old 11-05-2012, 02:13 PM   #2123
Jase
Drives: Toyota 86 GTS Aero - White
Mine started with the idle problem today. Here is my post from our local forum in Australia:
Mine has developed the same problem. It did it once at a petrol station very early on (2nd tank I think) but I'd had a bit of a brain fart and was very low on fuel, which I assumed to be the cause at the time. Very rough idle and car shuddering like one cylinder wasn't firing, but I turned it off before the CEL came on (or I didn't notice it anyway - not something I was expecting or looking for in a brand new car).
This afternoon in stop start Sydney traffic the idle started falling again, not to the point of shuddering or tripping the CEL, but enough to make me look like a bit of an amateur on a few hill starts... The problem seemed to me to have something to do with the aircon compressor kicking in and out - like the ECU wasn't compensating for the extra load or something.
Headed home via the Putty Road and gave it the berries for most of the way, keeping it right up in the rev range during all the best bits (first trip up the Putty in it by the way - awesome!!). Got home and it would barely idle, massive shudders and CEL light came on. Turned it off and on again - fault persisted until I touched the throttle (the same process as yours UncleWonka^^). The clutch seemed to have no bearing on the fault - i.e. I could get the fault with either the clutch pushed in or the gearbox in neutral. I then tested to see if the aircon was contributing to the problem. While it was a little worse with the air conditioner on, I suspect this was a symptom not a cause, i.e. an already low shuddering idle lowered further due to the extra load from the compressor. The engine would almost completely stop (almost down to 200rpm) before the ECU would try to correct for the aircon, then would hunt between 400-800rpm, then the shuddering, CEL etc.
The one thing that struck me was that every time this has happened, the engine/exhaust/car in general has been quite hot. Not overheating on the gauge, but had been subjected to hot conditions for a significant period of time. The first occurrence was on a 38 deg day after a lot of low speed driving (mostly 60-80km/h) in stop start conditions, the second after walking pace Sydney gridlock 33 deg afternoon, and then an enthusiastic run up the Putty. I've got no idea how this could affect the ECU or fuelling, maybe one of the sensors is reading incorrectly?? Or the hot engine is causing detonation and a resultant change in ignition timing by the knock sensor??
I've got no idea really, I'm not a mechanic so I'm just throwing some ideas out there. If anyone has heard of a lasting solution to this problem I would really appreciate hearing about it - I want to have a bit of information before I approach the dealer so they take the problem seriously and investigate it properly. This seems to be happening to a few of us so clearly it isn't an isolated problem.
If it makes any difference mine is an August built manual GTS.
Sorry for the long post guys, I do tend to go on a bit. I just wanted to get as much info as i could out there so maybe someone has some ideas. I'll give an update with the dealer's response soon.
Jase, Today at 3:05 AM
Jase is offline   Reply With Quote
The Following User Says Thank You to Jase For This Useful Post:
Old 11-05-2012, 02:32 PM   #2124
Sean K.
Sean K.'s Avatar
Drives: 2008 Lotus Elise SC
Jase,
What's your mileage at now? Just wondering....
Thanks,
Sean
Sean K. is offline   Reply With Quote
The Following User Says Thank You to Sean K. For This Useful Post:
charger (11-06-2012)
Old 11-05-2012, 03:49 PM   #2125
EJ33177
EJ33177's Avatar
Drives: 2013 Scion FRS Ashpahlt AT
EJ33177, FR-S, 7313, VIN starts at 75, dropped off today for CEL and VSC lights. Baltimore MD
My codes are P000A, C1201, and B1410. I seemed to know more about the problem then the customer service woman. She just told me, "The car is so new we have to send the info to Toyota." aka we have no idea what to do.
Stuck in a corolla for the time being. I have a feeling I might end up saying good bye to the FR-S forever over this.
Day 1-dropped off at dealership
EJ33177 is offline   Reply With Quote
The Following User Says Thank You to EJ33177 For This Useful Post:
Old 11-05-2012, 04:30 PM   #2126
mhigham
Those are not the usual codes I believe.
Old 11-05-2012, 05:10 PM   #2127
nashsnazzy
Drives: 2013 Scion FR-S White Out
It looks like I'm now a member of the cam , ecu , whatever you want to call it club. Car started giving trouble Saturday, about 2600 miles on the odometer, and then it sounded like there was gravel in the engine near idle. The idle is hunting around 400rpm. I had the brake light, CEL, and traction control light all come on at the same time. Toyota has ordered a new ECU and I'm not sure what else (I'll update when I get the work order in my hands). My VIN ends in 7076xx.
Status: Toyota replaced ECU, the codes were P0019, C1201, U0100. I've put about thirty miles on the car and I've seen no evidence of the issue. I'll post back in this thread if it pops up.
nashsnazzy is offline   Reply With Quote
The Following User Says Thank You to nashsnazzy For This Useful Post:
Old 11-05-2012, 05:33 PM   #2128
Yruyur
Yruyur's Avatar
Gravel sounding...not sure if an ecu will fix that.
Sent from my flux capacitor using Taptalk
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 07:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 11:42 AM
Idle issue scioneric CANADA 23 08-24-2012 02:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 11:00 AM
