Old 11-03-2014, 11:15 PM   #2101
Mikeez
Engineering Student
Drives: Scion FR-S 2015
I want to know how that water got in anyways lol...
Mikeez is offline   Reply With Quote
Old 11-03-2014, 11:27 PM   #2102
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
I want to know how that water for in there too. I'm not driving it. I let it dry and used a compressor to dry everything out the best I could. I'm not sure how much if any water is down in the bottom of the piping. After letting it dry I started out up and it ran better. My only guess is that maybe there is a coupler that is loose and somehow water got in when it was raining one day.
Either way, I'm driving my other car in the mean time. :-\
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 11-04-2014, 08:29 AM   #2103
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Well you could pull the spark plugs and turn the motor over to force any water out of the heads... though pulling plugs on this car has to suck.
Old 11-04-2014, 08:59 AM   #2104
blackfireball5
I'm not convinced there is water in the heads. It didn't run long enough to suck water in. I think water just hit the maf and caused it to die. Gonna take off some lower piping and see if there's anything down there today since it's a warner day.
Wheelwell Profile
Old 11-06-2014, 10:55 AM   #2105
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
Anyone running an aftermarket crash bar? I wanna see how you mounted everything.
xDBOYx is offline   Reply With Quote
Old 11-06-2014, 12:16 PM   #2106
mike the snake
I'm running the Drift Armor crash bar on my BRZ.
The intercooler mounted to it basically the same as it mounted to the stock crash beam.
The crash bar allowed me to cut holes in the front bumper to allow a LOT more air into the front for better cooling.
Old 11-06-2014, 12:59 PM   #2107
xDBOYx
xDBOYx's Avatar
Do you have any pictures? I dont see any mounting holes for the interooler from the website.
Old 11-06-2014, 01:53 PM   #2108
Dipstik-sportech
Dipstik-sportech's Avatar
I had to weld studs to my drift bar to mount the intercooler, it also allowed me to run the hot side pipe under the rad cradle shortening it considerably.
Old 11-06-2014, 06:18 PM   #2109
VroomVroom86
VroomVroom86's Avatar
Drives: 2013 Firestorm FRS MT
Would 255/40/17 be enough for 500hp? Tires would be toyo r888. Mainly street/mountain driving.
VroomVroom86 is offline   Reply With Quote
Old 11-06-2014, 06:29 PM   #2110
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
255 r888s at 500hp will require a new transmission and eventually axles.
Old 11-06-2014, 06:34 PM   #2111
VroomVroom86
Okay with that being said, and the upgrades you stated, I also plan on upgrading my LSD. I just don't want to be sliding everywhere upon straight line acceleration.
Old 11-06-2014, 06:38 PM   #2112
Reaper
Reaper's Avatar
Drives: violent
With a 10,000$ v160 swap, 1000$ DSS axles, a good progressive tune, a limited slip, coilovers and some gears and sticky 255s you have tons of grip.
I have stock struts and hankook v12s in 245 and spin 3rd everywhere and still blew up a transmission at 450whp.
Old 11-06-2014, 06:48 PM   #2113
VroomVroom86
Oh wow! Well I'm never going to swap my transmission for that cost lol I don't mind spinning a little bit, I just don't want it to be dangerous during wot.
Old 11-06-2014, 09:09 PM   #2114
Dipstik-sportech
It's only as dangerous as your right foot let's it be, it can be dangerous at stock power levels if you cant drive properly. I ran 500whp on the stock Prius tires, not for long mind you but I didn't die lol.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
