Old 11-03-2014, 12:48 PM   #2087
mike the snake
If you used the throttle body coolant lines for the turbo, could ice have built up inside the TB and intake, causing this much water in the intake?
He did mention it was very cold out.
Old 11-03-2014, 01:04 PM   #2088
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
First weekend it's dropped below freezing. A couple actual snow flakes fell. And I didn't drive my car the whole weekend.
blackfireball5 is offline   Reply With Quote
Old 11-03-2014, 02:35 PM   #2089
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Originally Posted by blackfireball5 View Post
This is what it was doing after it died while driving:
You are using fullblown kit? What stage and there was a reflashing of your ECU? I think its more software
Mikeez is offline   Reply With Quote
Old 11-03-2014, 03:03 PM   #2090
blackfireball5
FBM Stage 1 base kit.
I don't think it has anything to do with software. There was literally water dripping out of the air intake. That is not normal. lol.
The car runs great. It has a custom tune performed by Pure Automotive. I started the car this morning and it was very cold. Started right up and came right down to normal idle after warming for a few minutes. After about 10 minutes of warming I left for work. The moment I hit a main road, it bogged and died. My guess is that when the car warmed up it melted some frost or something else and is messing with the maf sensor.
I won't get to play with it until I get home. However I don't believe it has anything to do with the software.
Thanks for your reply.
Old 11-03-2014, 03:04 PM   #2091
blackfireball5
I guess that's my cars way of telling me it's time to pack her away for the winter.
Old 11-03-2014, 04:12 PM   #2092
Mikeez
Engineering Student
You're right, I am sorry. I have not seen previous threads. Either the MAF has water in in messing up with it or there is water in the piston. Please let us know how you fixed the issue when it is.
Old 11-03-2014, 04:13 PM   #2093
blackfireball5
Will do, thank you.
Old 11-03-2014, 04:43 PM   #2094
Dipstik-sportech
Dipstik-sportech's Avatar
Sounds like it's flooded, try holding your foot on the floor and cranking it. Mine did that if I stalled it, was a bitch to get going and when it did it ran pig rich for a second.
Old 11-03-2014, 04:55 PM   #2095
blackfireball5
I'll give that a shot when I get home. Gonna inspect the intake first.
Old 11-03-2014, 07:38 PM   #2096
blackfireball5
This pipe is FULL of water. I got it to start but it was still running weird. So i took the tube off. Water was blowing out of the blowoff valve. Where the hell could all of it come from. It's not coolant. It doesn't smell or look like coolant.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
Old 11-03-2014, 07:58 PM   #2097
blackfireball5
Wheelwell Profile
Old 11-03-2014, 07:58 PM   #2098
blackfireball5
That's after drying for like 10 minutes.
Wheelwell Profile
Old 11-03-2014, 08:48 PM   #2099
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
If there was enough water to lock the motor and mess up the sensor readings resetting them all by disconecting the battery for 20min or so may help.
While the battery is disconected I'd clean everything the best I could. Pul the MAF and use a MAF cleaner on it and let dry throughly. Then I'd go to town with a rag and some WD40 inside the intake and also spraying some into the engine itself.
You maybe able to expel any moisture in the block itself by holding your foot down and starting (much like clearing a flooded engine.)
Old 11-03-2014, 09:00 PM   #2100
FirestormFRS
Sir I would highly recommend you stop running that car until you find the source of the water. Water doesn't compress at all. Get enough of it in one cylinder and your rods will compress, break, and destroy your engine.
FirestormFRS is offline   Reply With Quote
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
