Old 08-27-2010, 05:48 PM   #197
C-Bone
C-Bone's Avatar
Drives: '03 Tiburon
cool I was wondering this too. to lazy to research myself lol...
C-Bone is offline   Reply With Quote
Old 09-01-2010, 06:41 PM   #198
Abflug
Abflug's Avatar
Drives: MR2
what´s up pros?! nobody´s able to compare the FT-86 to the SW20 MR2?!
Abflug is offline   Reply With Quote
Old 09-05-2010, 03:44 PM   #199
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Comparison between BMW 135i and FT-86
Originally Posted by VisciousGXR View Post
Here's BMW 135i dimensions
135i :
Length: 172.20 inches / Width: 68.80 inches / Height: 55.4 inches / Wheelbase: 104.7 inches / Weight: 3340lbs
Here is the comparison against BMW 135i. See how small the FT-86 is going to be?
* Aligned to the front wheel
* Measured down to single pixel against length
Want.FR-S is offline   Reply With Quote
Old 09-05-2010, 03:51 PM   #200
Want.FR-S
Want.FR-S's Avatar
Comparison against Toyota Celica
Folks, I guess we all forgot about this comparison...
Celica (2005):
Length: 170.5 inches / Width: 68.3 inches / Height: 51.4 inches / Wheelbase: 102.4 inches / Weight: 2500lbs
And my own version of comparsion between FT-86 and 370Z.
Really, between FT-86 and 370Z they are not that different in terms of the size, except that 370Z comes with a bulky hood. (Maybe this would help for people to visualize the 5 cm higher hood for pedestrian protection mentioned during the autocar interview with one of the designer of FT-86).
Old 09-05-2010, 04:43 PM   #201
C-Bone
C-Bone's Avatar
Drives: '03 Tiburon
I think it may look a bit better with a bit higher hood the ratio between the back and front looks a bit odd, the front is really small. I know it's for handling but a bit higher wouldn't affect it to much
Old 09-05-2010, 06:20 PM   #202
Franisco
Franisco's Avatar
Drives: D31a
'FT86'
Wheelbase: 101.2 in.
Length: 163.8 in.
Width: 69.3 in.
Height: 49.6 in.
Nissan 370z
Wheelbase: 100.4 in.
Length: 167.1
Width: 72.8 in.
Height: 51.6 in.
Originally Posted by White Comet View Post
No one's buying a Yaris to wind the piss out of it and possibly slam into a mountainside pretending they're the ultimate Tofu delivery person.
Franisco is offline   Reply With Quote
Old 09-05-2010, 11:32 PM   #203
Want.FR-S
Want.FR-S's Avatar
Oh, I forgot to mention this. You should see the light-blue and purple lines in the graph. The light-blue lines show the front and the back of the FT-86, whereas the purple lines show the front and the back of the compared car. Hopefully that would give you some perspective in this comparison.
Since the cars are aligned to the front axel, one should look at the wheel base first and then the length for comparison. Using 370z as an example, since the wheel base is only 1 inch difference (101.2 vs 100.4), you should see that both wheels (front and back) are aligned pretty closed. Then if you look at the lengths (370z, 167.1" vs FT-86, 163.8"), you see that 370z is longer on both the front and the back. That means 370z has more overhang compared with FT-86.
Hopefully that clarifies the pictures.
Old 09-06-2010, 07:22 AM   #204
Matador
hashiryu
Drives: Mk4 Supra
Excellent first posts Want.
Good stuff. Welcome.
Matador is offline   Reply With Quote
Old 09-06-2010, 11:05 PM   #205
Want.FR-S
Want.FR-S's Avatar
Thanks. I have got 9 months to prepare for this post....
Old 09-07-2010, 09:19 AM   #206
AaronCompNetSys
AaronCompNetSys's Avatar
Drives: 01' S2000; 05' WRX
Attention to detail, I appreciate someone else has it
Welcome
When that Godzilla post is scaled correctly, the GT-R will be ginormous compared to the FT-86.
AaronCompNetSys is offline   Reply With Quote
Old 09-10-2010, 05:07 AM   #207
Snaps
Supra Owner
Snaps's Avatar
Drives: 1995 Toyota Supra UK Spec
Guys, there seems to be some discrepencies between the actual height of the FT-86... Some people are saying 49.6", the beginning of this thread (and the 'FT86 info thread') states 48.1. What is it really?
I've done a little photoshop too, should clearly show the size difference. Both the cars are aligned to the right side of the picture, and aligned to the bottom.
Edit: The bottom of both cars is clearly not right, this is because of my shoddy selecting. Don't use the 'wheels' as a reference, just the body.
Edit: Also note, this is using the height of 48.1", not 49.6... These were done by cropping the pictures I used to the edges of the car, then changing the width + height to 10x the car's height (in inches) in pixels, so should be pretty much completely accurate.
Snaps is offline   Reply With Quote
Old 09-10-2010, 05:58 PM   #208
stevens8
stevens8's Avatar
Drives: '12 WRX
The FT and the celica are very similar in dimensions and the celica weighs in at 2425 LBS, so I dont see how it would be very hard to keep the weight below 2600. I;m all for the weight. If they can keep the weight below 2600 lbs, I'm totally fine with NA motor at 200hp.
stevens8 is offline   Reply With Quote
Old 09-10-2010, 07:27 PM   #209
Snaps
Supra Owner
Snaps's Avatar
Yeah, I would be more than happy with 2600lbs too, but isn't 200hp a little low for 2.0L nowadays? Honda manages to get 230-240hp out of the S2000 2.0L, and also 210 out of the integra's 2.0L?
I know that's using Vtec, but you would at least expect Toyota to be able to match it with the dual-vvti that's supposed to be on this car?
Old 09-10-2010, 07:31 PM   #210
C-Bone
C-Bone's Avatar
Drives: '03 Tiburon
I dont know if toyota has actually said exactly how much hp its gonna have, but im always happy with more
Has anyone compared the rumored price range to.... demby123 Scion FR-S / Toyota 86 GT86 General Forum 22 10-09-2011 03:18 PM
Subaru BRZ Dimensions and More Teasers Released Ahead of Frankfurt BRZman BRZ First-Gen (2012+) — General Topics 48 09-03-2011 11:32 PM
Wheel size, what's your opinion? #87 Off-Topic Lounge [WARNING: NO POLITICS] 4 02-24-2010 03:06 PM
