#197 |
The harder way is more time and it is the same steps as above just needs a 1/4-20 thread 3/4 to 1" long, epoxied to the carbon and let dry for at least an hour out of the cold air. I then used a 1-1/4" Di. flat washer and thread lock. I spun the wing nut until it gently felt the slightest tension and thats it. Barely put any pressure against the washer as it will pull the center part of the plaque and bend it. It's just there for my peace of mind if the tape were to fail somehow.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | axelo (01-01-2016) |
#198 |
Progress is ongoing!!! ....
#199 | |
Drives: Toyota 86 2017
When you sell this one let me know !
| The Following User Says Thank You to misterfly For This Useful Post: | stevesnj (01-06-2016) |
#200 |
#201 |
/dev/null
Drives: Uphill
The antenna delete DYI is great, thanks for sharing!
- Did you by any chance measure the length and width of the hole? Last edited by Sarlacc; 01-07-2016 at 02:00 PM. |
#202 |
Thanks, I totally forgot to measure it, I could of maybe found a plug that would go right in. But this is a good temporary solution and I already had the carbon plaque.
#203 |
Drives: Whiteout frs
Thanks!!!! Looks better than a old school anttena....
| The Following User Says Thank You to axelo For This Useful Post: | stevesnj (01-14-2016) |
#204 |
I agree, I'm looking for a plug that fits closer in size to the opening. If I find it I'll post on here. Did you happen to measure the hole size?
#206 |
Removed the to tall MOMO for this old school race ball knob, the color is stunning, puts a nice contrast in the interior. It has matching horizontal white stripes which i'm going to engrave onto and an 86 front and center.
| The Following User Says Thank You to stevesnj For This Useful Post: | Sarlacc (01-17-2016) |
#208 |
#209 |
Covered up the DD and used the workhorse today!
#210 |
A new project is in progress! Having fun doing it too!
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| Jac's BRZ build thread | Jac | Member's Car Journals | 0 | 04-30-2014 07:09 PM |
| 2016 FR-S vs 2016 MX-5 Coupe | NWFRS | FR-S / BRZ vs.... | 55 | 11-29-2013 11:17 AM |
| EOJ (Not much of a Build) Thread | jonbatz01 | Member's Car Journals | 41 | 07-31-2013 07:34 PM |
