#197 | |
Drives: BRZ Pearl White
I think it is accepted that Ohlins makes some of the best shocks out there and makes a set for these cars. I doubt the cost would be warranted unless you did some serious spring rate increases and I don't know if Ohlins makes a shock with stock stroke. The factory shocks on these cars leave a lot to be desired, especially the rears. They look cheap and they have inadequate rebound control. The ride at the rear of the factory equipped car is poor. Incidentally, the poor spring control means the drive wheels lose traction more easily than they should, which is the only reason damper quality belongs in this thread. I'd be very interested to read about lap times of a stock car equipped with a lsd as compared to a stock care equipped with B6 Bilsteins. |
#198 |
A consensus emerges: traction out of corners is most affected by roll stiffness.
For rwd moving roll stiffness forwards should improve drive out of the corners. For fwd the opposite is required. For awd, all bets are off, the drive force allocation in any awd system designed for the street is fiendishly difficult to design in the first place and successfully modifying one is exponentially more difficult. Just dealing with the centre diff is enough to cause serious headaches, one reason Subaru's rather clever little centre diff is so handy to have in your car. (STi that is) |
#199 | |
http://www.cuscousainc.com/downloads..._lsd_guide.pdf It limits the spinning to no more than the speed of the outside wheel. The degree to which the lsd can limit the speed difference between the inside and outside wheels is a function of the difference between the clutch disc friction and tire grip (allowing for the leverage advantage the tire diameter gives to tire grip). Basically, you can wear out the tires first or the lsd clutch discs first... The extent to which an lsd can be varied should be a caution to anyone deciding to fit one. ALL these lsd lock up and a locked up lsd isn't a very good solution to the torque problem. The lsd is always trying to speed up the slower moving wheel. The Torsen divides input torque between the drive wheels in exact proportion to the relative tire grip until the torque bias ratio is exceeded, then it will spin up a wheel, which wheel depends on which tire has most grip as the torsen will eventually spin up the wheel with less grip first. In theory it is difficult to see how the clutch lsd can outperform the Torsen, especially with only a maxim of 151 lb ft to deal with. Lap times do not lie but unless nothing else on the car is different from lap to lap they may not tell you useful truth. Last edited by Ubersuber; 08-10-2014 at 12:38 PM. |
#200 |
Drives: '23 BRZ
#201 | |
Perhaps you should stop theorycrafting, and start actually testing, and you'll discover that your results will curiously match the hundreds of LSD tests that have already been done. |
The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#202 |
I'm only interested in street applications. But, the theory is interesting nonetheless.
I'm just wondering why Subaru fitted a Torsen. |
#203 |
Drives: 2014 BRZ
Cost
#204 |
#205 |
Probably more the maintenance requirements. If people found out they needed a full diff rebuild at ~30k miles they're probably be pretty pissed.
#206 |
Drivability possibly as well
#207 | |
Drives: GT-86
#208 |
#209 | |
Because compromise ®
Drives: Red Herring
I am suggesting that most of the people on this forum are enthusiasts of some sort but most buyers of this car world wide are never going to mod their car. I am suggesting for most buyers, who will never see a track or drift around a roundabout or switch off the nannies, the Torsen is more than adequate and may even have some bragging rights. "Yeah man, my car has one of them Torsens".
The Following User Says Thank You to Captain Snooze For This Useful Post: | acro (08-11-2014) |
#210 |
Village Idiot
Drives: '13 FR-S Ultramarine Manual
Tags |
uberstupid |
High-G Cornering Fueling Solution | EAGLE5 | Tracking / Autocross / HPDE / Drifting | 24 | 02-22-2017 08:04 PM |
cornering-on-rails feeling | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 09-20-2015 07:00 PM |
Engine cutting power after hard cornering... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 19 | 07-04-2015 08:40 AM |
Traction control light comes even when not hard cornering? | Yamajee | Issues | Warranty | Recalls / TSB | 26 | 04-10-2014 01:04 PM |
Anyone have the radio switching modes during hard cornering?? | silvercar | CANADA | 4 | 07-08-2013 12:49 PM |
