Old 01-27-2016, 01:36 PM   #197
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by KoB14 View Post
That's what I thought, but from what I've seen everybody has used transparent blue vinyl
No. You have to replace the LEDs. The only thing the blue vinyl is used for is if you want to do the Tick marks a different color than the numbers. They are illuminated by the same LED. So to get Blue ticks, and white numbers, you have to cover the ticks with the Vinyl.
DustinS is offline   Reply With Quote
Old 01-29-2016, 11:53 PM   #198
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
This.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 01-30-2016, 11:52 AM   #199
ort895
ort895's Avatar
I don't mean to sound like an idiot but what type of led's do we need? Im taking some welding/painting/ auto body classes now so my car is about to get realllllll unique
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 01-30-2016, 01:21 PM   #200
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
plcc2
Pwolf is offline   Reply With Quote
Old 01-30-2016, 02:35 PM   #201
FirstWinter
Drives: Car
Swapping FRS & BRZ speedo
I have a FRS. Would it be possible to find a speedometer off a wrecked BRZ and swap with my speedo to get different LEDs? Everything should be good right?
FirstWinter is offline   Reply With Quote
Old 01-30-2016, 02:43 PM   #202
Pwolf
Pwolf's Avatar
Technically yes (I don't know if anyone has done it yet though) but mileage is recorded on memory in the gauge cluster.
Old 02-01-2016, 08:57 PM   #203
ort895
ort895's Avatar
So what type of led's does our dash use. And what is required to change the color of our speedo "stick" since it seems to be tinted red.
I should be able to do this on Thursday since I have access to a soldering iron at school.
Old 02-01-2016, 09:05 PM   #204
stevesnj
stevesnj's Avatar
All the answers are in this thread.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
MaXimus (03-15-2016)
Old 02-02-2016, 01:13 AM   #205
Pwolf
Pwolf's Avatar
I usually don't go to the "it's been answered before" line but both questions have been answered on this page...
Old 02-02-2016, 01:44 AM   #206
Futaba
Futaba's Avatar
Drives: GT86
Can the next person that attempts this who has a working MPH/KPH toggle please take a high quality photo of the rear of the PCB (side the connector goes in) , preferably near the main connector please, need it for research!
Your assistance will be muchly appreciated, only requires lifting the PCB out of the plastic frame once you have taken off the front white housing to get access to the LED's (just lifts right out).
Futaba is offline   Reply With Quote
Old 02-09-2016, 12:04 PM   #207
DustinS
DustinS's Avatar
Don't remember reading it anywhere, but for those who do the LED swap on the Dual Climate Panel. When you are taking it apart, there is a set of pins for the Screen on the top left (when looking from the back). They just pull straight up. Just go at it slow.
Was fighting this last night as I took the new panel apart to clean and swap them. Didn't want to break anything.
The Pins go into the set of holes at the top right of this picture.
Old 10-20-2016, 11:38 AM   #208
boomslang
Drives: Toyota
Anyone have the forward voltage and forward current values of the factory white cluster LEDs?
I'm guessing around 3.0 volts and 0.02 amps.
boomslang is offline   Reply With Quote
Old 11-21-2016, 02:34 PM   #209
86Boyz
Drives: on the highway to hell
If I would do this mod I would go with ultra violet purple lighting.
86Boyz is offline   Reply With Quote
Old 04-13-2018, 12:22 PM   #210
assbox
assbox's Avatar
Drives: Whiteout FRS
I've been in the process of completing this project. Figured i'd post if anyone was curious on how to separate the gauge needles from the black caps so you can clear them FULLY.
I used a x-acto knife to cut the two black caps on the backside of the needle. I slowly wiggled the knife back and forth while giving it a little pressure. Go slow so you dont stab yourself or put the blade through the black plastic. Once the two caps are sliced off, you can take a fine flat head screw driver and pry up using the little notch. Once you have the plastic cap off, you can lightly pull the needle through the black cap. After scraping the paint off all the needles using a box-cuter style razor, just re-assemble as you took apart. Lastly i used a fine solder tip, to melt the plastic post to the back cover of the needle. You just have to touch the cap for a fraction of a second to get it to seal up, so be careful.
And if anyone wanted to see what the door controls, hvac, lighting adjustment, and traction control led locations where at on a FRS, see the below picture. The x'd off items do not contain LEDs or may not be in your car due to an after market product.
A the very MINIMUM you must buy the following:
Driver and passenger door control leds are : 0805 SMD LED = total needed 6
FRS air circulation and temperature knobs: 74 Neo-wedge LED = total needed 2
FRS AC and air circulation buttons (middle button)- 3mm round LED =total needed 2
FRS HVAC Fan Speed - PLCC-2 SMD LED (all) = total needed 6
Interior dimmer control - 3mm round LED = total needed 1
Clock/hazard/airbag unit - PLCC-2 SMD LED = total needed 8
Gauge cluster (not shown in picture) - PLCC-2 = +-30
be sure to pick up more than the minimum as odds are you may mess up a couple during installation.
IG: ft86carbon
assbox is offline   Reply With Quote
The Following User Says Thank You to assbox For This Useful Post:
sato (04-13-2018)
Gauge Cluster on FRS tonytduc Scion FR-S / Toyota 86 GT86 General Forum 16 07-24-2017 10:56 PM
BRZ cluster gauge swap? InYOHface Cosmetic Modification (Interior/Exterior/Lighting) 31 03-25-2017 07:31 PM
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 03:54 PM
Gauge cluster mod? kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 8 11-27-2013 11:59 PM
Want to try a gauge cluster experiment with me? stockysnail Northwest 2 04-12-2013 11:57 AM
