#197 | |
Kuruma Otaku
(Metal side note, you can make 18k gold that is purple all the way through, not just a surface treatment, with aluminum as the alloy. Also an intermetallic compound.)
Because titanium. |
#198 |
Rocket Surgeon
Drives: PSM GGA OMG
#199 | |
Drives: Toyota
Underground Midnight Races?
#200 |
Drives: '06 AM V8V Coupe
I thought I was looking at an old post for a sec rofl.
If he simply extends the stroke 20% up to 103.2mm, that eats up 8.6mm rod length, which sounds like a problem to me. 1.205 rod stroke ratio, horrendous increase in friction and bearing force? Unless I'm severely mistaken about engine geometry... |
#201 | ||
Pro Subie Engine Nerd
Drives: BRZ has a reserved space
There is more than one way to skin a cat. |
#202 |
So I'm a bit confused but what I mean by increasing bore was I don't see how stroke can be safely increased much.
#203 |
I never said I was going to increase stroke
![]() What spec do you have for the rod length on the FA20...curious. |
#204 |
So the FB20 has narrow angle ports, 129.3 mm rod length, 90mm stroke. FA20 is said to be same dimensions, valvetrain is similar, rollers on cams, no variable lift, I hear narrow angle is good for performance so I assume they keep that. FB20 has 10.5:1 compression ratio, FA is 12.5:1. Reduced stroke => 2mm off the crank, 2mm to the rods for a 131.3mm rod, with the same deck height. But then combustion chamber is different due to the higher compression ratio...if they only reduce the deck height to increase the compression, I calculated 1.7mm maximum to the rods. So if the engine is as similar to an FB20 as people seem to think, the maximum length the rods could be is 133mm, probably a little less?
#205 | |
Kuruma Otaku
Because titanium. |
#206 |
Drives: Attitude
#207 |
Kuruma Otaku
Are you thinking along the lines that the blocks between the FA and FB are pretty much the same die-casting with different cores. Bore pitch would be the same, so the FA can be safely bored to the same 94mm as the FB25, which would give you your speculative 2.4L with an 86mm stroke? Something like that?
Because titanium. |
#208 |
Grumpy Old Man
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
Quoting the use "oldeskewltoy" from club4ag here...
"Is it just me... hmmmm, but wouldn't a compact S/C fit in between the alt and A/C and place it directly in front of the T/B??? Hmmmm, I also note a single belt. That means it won't be easy to remove much from the belts path without extensive tensioner placement adjustment"
2016 Halo FR-S, 2010 Tundra, 92 325i convertible, 80 Mazda 626, 62 Impala
| The wheel bolt pattern is... | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 193 | 02-29-2012 06:04 PM |
| Mods? | Bruninho8 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 12-06-2011 06:11 PM |
| Estimated Price.. | SLeRoux92 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 05-25-2011 11:58 AM |
