Old 01-23-2014, 04:24 AM   #197
Trettiosjuan
Drives: GT86
If you get the impression that the whole exhaust line is hanging evenly in its rubbers while keeping in mind that the whole system will expand a good inch when hot (rubbers should be angled forward somewhat evenly when cold), then you can just realign the tip(s).
Trettiosjuan is offline   Reply With Quote
Old 01-24-2014, 07:17 AM   #198
Mirko
Mirko's Avatar
Drives: Subaru BRZ
Does anybody know if the milltek catback has abe/ece approval? Its the only european exhaust I know that comes with burnt tips
Mirko is offline   Reply With Quote
Old 01-24-2014, 10:25 AM   #199
Trettiosjuan
Drives: GT86
The resonated secondary cat-back is ECE approved, look here (option 6 to 9 marked blue): http://www.millteksport.com/exhaust....3#.UuJUKxARlpg
Didn't know they now offered so many different tip options as of now, mine are as good as black now anyway so doesn't matter
Old 01-24-2014, 10:40 AM   #200
Mirko
Mirko's Avatar
Drives: Subaru BRZ
I really dont know how I did not see that when I first checked.
Ahah thanks man
Old 01-24-2014, 04:38 PM   #201
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Yeah, I read on Milltek's site that the hangars should be raked forward a bit when cold... mine are all raked almost 45 degrees aft when cold. I have no idea why or how that's possible. All I can think of is that maybe the shop didn't get the midpipe fullly inserted into the axle-back portion? IDK. Man I wish I had a lift so I could get a better view and monkey with it myself.
Here's what I'm seeing when I stare under my car:
It looks to me like the pipe is tapping against the diff housing and possibly the subframe as well?
The only thing I can think of is that the midpipe isn't fully inserted into that clamped sleeve fitting there, since that would cause the whole thing to be pushed back I suppose, which would in turn cause impaired vertical clearance because the whole thing would swing up on those hangar arms.
The muffler hangars are just as out of alignment (left is aft in this picture).
Ganthrithor is offline   Reply With Quote
Old 01-24-2014, 06:11 PM   #202
Trettiosjuan
Drives: GT86
Yep, the whole thing needs to be reclamped, if this warms the whole system is pushed upwards. The whole back box needs to moved forward by inserting the mid pipe more. Rubbers should be angled the other way (forward) and not so aggresively (about half angle from the pics). Would call the shop and ask if they can redo it properly...
The Following User Says Thank You to Trettiosjuan For This Useful Post:
Ganthrithor (01-24-2014)
Old 01-24-2014, 06:29 PM   #203
Ganthrithor
Yeah I dropped the car at the shop a couple of hours ago and they're gonna try and adjust it this afternoon. They said that they thought they had gotten it in far enough last time, but that the midpipe<>axleback sleeve was, "very tight." We'll see what they can do. I brought them the old midpipe as well since the carbon buildup / scoring from the clamping should let them use the old pipe as an insertion depth reference. Cue posts full of innuendo and, "That's what she said"-s, lol.
Edit:
It's fixed. Apparently you gotta use the lube if you wanna get that last inch in, lol.
Now that you've stopped laughing, wow does grease-smoke smell like shit. Since it's not an EJ motor though I won't worry too much about a touch of smoke coming out of the tips :P
Old 02-14-2014, 01:50 PM   #204
mush
mush's Avatar
found this today
The Following User Says Thank You to mush For This Useful Post:
Boxer486 (02-14-2014)
Old 02-14-2014, 03:14 PM   #205
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
found this today
Wow that's not something I'd expect from a >1000$ exhaust...
Sent from my SGH-I337M using Tapatalk
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
The Following User Says Thank You to Simon99 For This Useful Post:
mush (02-14-2014)
Old 02-15-2014, 01:11 AM   #206
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
Wow!!!! Just checked on my car and mine are clean. How did you notice it? Is there a puncture as well?
chiefshayan is offline   Reply With Quote
Old 02-15-2014, 02:39 AM   #207
mush
mush's Avatar
i think i noticed it about a month ago. cold start up in the morning started sounding raspy for the first 2-5 seconds, then it would be normal
decided to get under the car today to see whats up
i can feel air passing through that crack
no scrapes or scratches on midpipe or axel back, so the crack developed on its own
Old 02-16-2014, 04:05 AM   #208
chiefshayan
Man that's unfortunate. Try getting in-contact with someone from Milltek I'm sure they'll help you out. I took some pictures of mine today here's how mine looks after around 3,000 miles. Pretty normal IMO, my 928 which has 150k miles looks A LOT worse
Old 02-16-2014, 11:59 AM   #209
mush
mush's Avatar
Had mine on for around 9-10k miles already
Old 02-18-2014, 06:53 PM   #210
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
So I pulled the trigger and got the Resonated Cat-Back as well as the overpipe. Working now in combination with a motiv concepts catted front pipe.
The sound is just...wow . Think I waked up the neighborhood with a cold start at 2 AM in the morning. lol.
I definitely feel a bump in midrange torque and the noise is just butter to my ears. I can even hear a little bit of boxer rumble coming out of this lovely tubes.
Next mod: Catted UEL header.
Flasher is offline   Reply With Quote
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 10:30 PM
Dynosty Presents MXP Exhaust System for FR-S/BRZ Dustin@Dynosty Engine, Exhaust, Bolt-Ons 12 11-08-2012 10:15 AM
Subaru BRZ Arrives At Milltek Sport HQ For Development vividracing Engine, Exhaust, Transmission 13 08-13-2012 09:53 PM
What is the best exhaust system for the FT86 LOTUS86 Engine, Exhaust, Transmission 4 07-31-2012 03:36 AM
TRD Exhaust System... Griffdawg Engine, Exhaust, Transmission 2 07-18-2012 01:27 AM
