#197 | |
Drives: Crapcan
http://www.larryspower.com/heads/Chambering.html The guys in thailand claim to have done it with the stock ECU in their 17'. Who knows what they did though, probably just stuck the 17' sensors in the FA24 block is all. They are using the FA20 heads but not sure which timing cover. I know one reason we can't run the FA20DIT timing cover and get that sweet, sweet larger oil pump, is that the cam sensor port isn't in the right spot. Not sure on timing cover compatibility FA24 vs. FA20 though.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | new2subaru (12-16-2022), Teseo (12-17-2022) |
#198 | |
Weight Weenie
Drives: 15 FR-S
| The Following User Says Thank You to new2subaru For This Useful Post: | NoHaveMSG (12-16-2022) |
#199 |
Drives: Crapcan
I am pretty much in the same position. I have 100K+ miles on my engine, 40ish track days with more to come. It's only a matter of time. When I go to refresh curious what options will be when that time comes.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | chaoskaze (01-09-2023) |
#200 | |
Weight Weenie
Drives: 15 FR-S
#201 | |||
Drives: 2020 BRZ Sport Tech RS
I just want to have my "perfect" combo of the BRZ generations.
| The Following 2 Users Say Thank You to Tatsu333 For This Useful Post: | new2subaru (12-21-2022), NoHaveMSG (12-17-2022) |
#202 |
Drives: frs
For the cost and hassles, better go with FA20 forged. Plug everything back like before
#203 | |
Drives: Crapcan
Bench wrenching is fun though. Hopefully we see more development on this in the future.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (12-17-2022) |
#204 | |
Original crank is forged anyway, and the weak point (if any) is the rods (leaving aside the known oiling issues). Cast pistons are more thermally stable than forged as well and allow for tighter clearances in the bore. Aftermarket pistons tend to be forged to be more detonation-resistant, which is great for FI applications but much less important in an NA application presuming the tune is reasonable.
| The Following User Says Thank You to Tatsu333 For This Useful Post: | NoHaveMSG (12-17-2022) |
#205 |
Drives: 2000 Subaru Legacy B4 RSK (JDM)
My guess is this shop is using the FA24 block with WRX FA20DIT Pistons, FA24 upper & lower oil pan assemblies & a FA24 front timing cover with farely standard FA20 heads....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| The Following User Says Thank You to Opie For This Useful Post: | NoHaveMSG (12-19-2022) |
#206 |
Drives: Crapcan
Swapping piston's would be a bummer.
#207 | |
Drives: Q5 + BRZ + M796
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Teseo (12-19-2022) |
#208 | |
Drives: Crapcan
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#209 | |
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Hyper4mance2k (04-28-2023) |
#210 | |
Drives: Crapcan
Also in my head: ![]()
| FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 11:18 AM |
| FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 09:27 AM |
| Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 11:55 AM |
| FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 04:59 PM |
| Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 01:33 AM |
