#197 |
2013 Scion FR-S Engine Failure
Vehicle Mileage: 78,xxx
Vehicle Make: 2013 Scion FR-S Mileage After Recall Performed: ~1000 Symptom(s): engine knocking at idle. Failure: None aside from engine knocking. The vehicle is currently sitting at the dealer in an unknown state. Toyota corporate recommend the dealership replace the entire engine. They also requested records of regular vehicle maintenance like receipts from oil changes. I change my own oil but keep records of the date and mileage of when I change the oil. I gave that to them and a few days later Toyota corporate denied a replacement engine with no real reason given. State: Illinois Is Dealership Offering Repair: No. I have contacted Toyota corporate to file a complaint for this issue and am waiting on a call from the service manager of the dealership. I currently still have the loaner vehicle they provided me when the said the second repair would still be covered under the recall. For anyone wondering the number the dealership gave me to contact Toyota was 800-331-4331. Last edited by Brett1024; 04-22-2019 at 03:46 PM. |
#198 |
Vehicle Mileage: ~64,500
Vehicle Make:2013 Scion FR-S Mileage After Recall Performed:275 Symptom(s): oil leak on driver’s side, RTV found on dipstick when checking oil Failure: none yet, but oil is leaking and RTV in engine oil is cause for concern State: Texas Is Dealership Offering Repair: TBD |
#199 |
Vehicle Mileage: 117,000
Vehicle Make: Subaru Mileage After Recall Performed: 1,600 Symptom(s): Lower than normal oil pressure Failure: TBD (rod knock and engine wont start) State: WI Is Dealership Offering Repair: TBD |
#200 |
Drives: 2013 Scion FRS 6AT
Vehicle Mileage:58,000
Vehicle Make: Scion FRS Mileage After Recall Performed:~2,000 Symptom(s): Engine knocking Failure:TBD State:CA Is Dealership Offering Repair:Not at the moment. |
#201 |
Drives: 2019 Mazda Miata RF
Not all of these are on the spreadsheet...anyone keeping tabs on the body count?
Post recall "issues" spreadsheet |
| The Following User Says Thank You to Gunman For This Useful Post: | mswbrz (04-23-2019) |
#202 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Have another local who is awaiting his account to be active. Linked him to the spreadsheet though so hopefully he updates it. Possible knock 3k miles after recall
Edit: he updated
#203 |
Drives: 2012 Scion FR-S
Just died on me today
![]() Located in Canada, all stats in km Vehicle Mileage:119xxx Vehicle Make: Fr-S Mileage After Recall Performed: ~7xxx Symptom(s): started as a slight tick, varied with RPM and only under load. By the end of a 50km commute, engine had a loud knocking noise, and shut down once I pulled off the highway. Failure: So far unknown, sounds like a rod bearing based on experience. State: Ontario, Canada Is Dealership Offering Repair: Yes; although unconfirmed at this point, the service manager anticipates a new short block to be provided by Toyota Canada, and the dealership will reassemble the motor with the new bottom end. I am concerned that the same dealership that screwed this up the first time is getting a second chance at assembling this motor properly. **Update: Dealer will have the car for an additional two weeks. New short block on the way, and they will reassemble the motor. Service manager assured me that they have new direction on how to apply the sealant to the timing cover, with a template that they received from Toyota Canada (hopefully from the assembly plant floor). In the mean time I'll get to enjoy this bright blue corolla hatch for two more weeks :ugh: I’ll update this post as this develops. Last edited by kri$han; 05-08-2019 at 12:58 PM. Reason: Updates |
| The Following 4 Users Say Thank You to kri$han For This Useful Post: |
#204 |
Vehicle Mileage:104,xxx
Vehicle Make: Subaru BRZ Mileage After Recall Performed:<4,000 Symptom(s): Engine knocking, loud grinding/ticking, died Failure:TBD State:MA Mine died last night on the highway. I had the recall work done exactly 2 months ago, along with a new clutch and spark plugs since they were already in there. It took them 3 weeks to do the work, when I got it back the car felt fine, but I kept it under 5K RPMS for the past 3500-4000 miles. Brought it up to 5.5/6.5K yesterday when merging and almost immediately the usual whirr turned into a horrible grind. Felt like the drain plug fell out. The oil light came on, then check engine, then every other code. Put it in neutral and coasted to the shoulder, smelled like burnt oil and had intermittent smoke coming out once the oil cap was removed. It currently won't turn over so I'm doing some research before taking it back to the dealer that did the recall work. Last edited by NickCarmer; 04-29-2019 at 12:41 PM. |
#205 | |
#206 | |
Drives: 13FRS
I was glad to get this work done without any cost to me. I am satisfied with how they handled this for me. I wish this were the case with everyone, but that's unrealistic. We are going back and forth with them because there is still a little oil leak. I'm finding a puddle on my driveway about the circumference of a baseball each morning. They are looking into this, as well, without cost. |
| The Following User Says Thank You to DirectorBrandx For This Useful Post: | daftpunk (07-18-2019) |
#207 |
Drives: 13FRS
Mileage: ~70,000
Make: 2013 FR-S Mileage after recall: ~1200 Problems after fix: (see below) I have received my FR-S back with a new short block, along with a few other new parts surrounding it to complete the job. The car was with them for over a month, mostly because they had Toyota Corporate guys come out at least twice, that I know of. I was glad to get this work done without any cost to me. I am satisfied with how they handled this for me. I wish this were the case with everyone, but that's unrealistic. We are going back and forth with them because there is still a little oil leak. I'm finding a puddle on my driveway about the circumference of a baseball each morning. They are looking into this, as well, without cost. **I don't know what came of the other three FR-S cars that were at the shop. But I hear that one of them was turned away because the owner slacked off on maintaining it properly and his oil changes were way overdue. Corporate apparently denied his him/her any repairs. |
#208 | |
Drives: 13FRS
Mileage: ~70,000 Make: 2013 FR-S Mileage after recall: ~1200 Problems after fix: (see below) I have received my FR-S back with a new short block, along with a few other new parts surrounding it to complete the job. The car was with them for over a month, mostly because they had Toyota Corporate guys come out at least twice, that I know of. I was glad to get this work done without any cost to me. I am satisfied with how they handled this for me. I wish this were the case with everyone, but that's unrealistic. We are going back and forth with them because there is still a little oil leak. I'm finding a puddle on my driveway about the circumference of a baseball each morning. They are looking into this, as well, without cost. **I don't know what came of the other three FR-S cars that were at the shop. But I hear that one of them was turned away because the owner slacked off on maintaining it properly and his oil changes were way overdue. Corporate apparently denied his him/her any repairs. |
#209 | |
Only users lose drugs.
Drives: All the time
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#210 |
It was Ira Suabru in Danvers, MA. Great rep and no issue with the clutch they put in, but it's only been a few thousand mile
| The Following User Says Thank You to NickCarmer For This Useful Post: | venturaII (04-28-2019) |
| Tags |
| fa20, failure, recall, spun bearing, subaru, toyota, valve spring |
| 2013 Valve Spring recall - modified (FI) engine thread | shiumai | Forced Induction | 71 | 08-11-2020 07:21 PM |
| TSB / Recall thread take over | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 17 | 02-19-2019 12:24 AM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 06:18 PM |
| PA Monogram Registry! | kazetaro | NY / NJ / CT / PA | 0 | 06-06-2014 07:49 PM |
| Another Detonation thread. (DI failure related) Input Please. | Thorpedo | Issues | Warranty | Recalls / TSB | 15 | 08-02-2013 08:23 PM |
