Old 08-29-2012, 11:09 AM   #197
apoplexy
Drives: whiteout manual frs
I just got my shipping confirmation. I ordered it 4 weeks ago now. Unfortunately, I'll be out of town for a week or so, but afterwards I'll post some pictures and give a writeup about how buttery it is or isn't.
apoplexy is offline   Reply With Quote
Old 08-30-2012, 01:52 AM   #198
Ad8707
Ad8707's Avatar
Drives: 2013 frs whiteout
Noob question ...Are these just unscrew stock and screw in the flossy thanks
Ad8707 is offline   Reply With Quote
Old 08-30-2012, 02:10 AM   #199
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Correct
Lee358 is offline   Reply With Quote
The Following User Says Thank You to Lee358 For This Useful Post:
Ad8707 (08-30-2012)
Old 08-30-2012, 10:40 AM   #200
boyin
Drives: whiteout FR-S
mine came in
boyin is offline   Reply With Quote
The Following User Says Thank You to boyin For This Useful Post:
travace (09-20-2012)
Old 08-30-2012, 11:02 AM   #201
Mishimoto
Drives: 2013 Subaru BRZ
Originally Posted by boyin View Post
mine came in
Very nice!
Mishimoto is offline   Reply With Quote
Old 08-30-2012, 11:51 AM   #202
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by Lee358 View Post
Attachment 11602
Here are two pics from the drivers door one showing the stitching in the steering wheel
I can't help but think about a clown nose...
raul is offline   Reply With Quote
Old 08-30-2012, 12:57 PM   #203
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
yes
The Following User Says Thank You to SkAsphalt For This Useful Post:
Ad8707 (08-30-2012)
Old 09-06-2012, 09:03 PM   #204
LXXXVI
Drives: FR-S, Raven, 6MT
I quickly installed the Flossy Shorty and I was impressed with how much smoother the the shifts were.
I installed it by shimming under in inside of the knob to clock the shift pattern.
I threw it together using some misc hardware as shown.
The screw keeps the washers in position and the screw head adds to the 0.188 to 0.250 total thickness.
The trick would be to use about $0.25 worth of #6 aircraft hardware where a standard 0.032" washer = 2/3rd's of a turn and the light 0.016" washer = 1/3rd of a turn for the 12mm dia x 1.25mm (0.05") pitch thread.
Here's a suggested hardware list if any one is interested:
Truss Head Screw, Phillips Drive: AN526-632-R12, $0.06/each
http://www.aircraftspruce.com/catalog/hapages/an526.php
or
Pan Head Screw, Phillips Drive: MS35206-232, $0.06/each
http://www.aircraftspruce.com/catalog/hapages/ms35206.php
Flat Washers: AN960-6 and AN960-6L, $0.02/each
http://www.aircraftspruce.com/catalog/hapages/flatwashers.php
LXXXVI is offline   Reply With Quote
Old 09-06-2012, 09:30 PM   #205
_F-R-S_
Drives: 13 whiteout scion frs
This is one of the best companys iv ordered from.. I happen to make the wrong order and quickly emailed. Was a very quick response back and helped me fix the issue and refunded the money and was able with the help of Flossy to get the right product.. i love customer service like this.. quick response and taking the time to fix the issue.. im sastified and will order more knobs from them in the furture. with that said.. cant wait till mine comes in =D
_F-R-S_ is offline   Reply With Quote
Old 09-06-2012, 09:34 PM   #206
mashal
DADA
mashal's Avatar
Drives: 2013
or
So did you use the lock out nut from flossy or no? I can get all that hardware from work as I work in aviation
mashal is offline   Reply With Quote
Old 09-07-2012, 12:56 AM   #207
gmookher
They are amazing quality. The heavyweight will make your shifting smoother i have the shortie redhead and it actually feels like it just wants to float into the next gear.
how does one choose between wanting a shortie or a heavy weight?
what shifts best?
where is it too heavy and whats the down side, whats good for track use?
... i am a shift knob noob!
gmookher is offline   Reply With Quote
Old 09-07-2012, 05:20 AM   #208
Lee358
Lee358's Avatar
what shifts best?
One MUST get a shorty to work with our reverse lock out no choice due to that.
Old 09-07-2012, 07:41 AM   #209
ozone42
Drives: SSM BRZ Limited
I did not get any special engraving or pattern on my shorty. I did find that due to the fact this is all metal, it doesn't bite into the threads a the end, making it easy to accidentally loosen.
So I took a small piece of thin cardboard and jammed it into the knob all the way, then screwed it on the shifter. The threads bite into the cardboard at the end, the friction is plenty for a solid grip that is not going to come lose, but you can take off any time you want it.
I'm sure you could do this to make your engraving pattern line up the way you want, you'd probably just have to try a couple times.
ozone42 is offline   Reply With Quote
Old 09-07-2012, 09:29 AM   #210
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
^ to make patters line up I've always just shoved a ball of tissue in the hole to help.
TouchMyHonda is offline   Reply With Quote
<< FT-86 SpeedFactory >> Shift Knobs | Cusco Cage | more soon... FT-86 SpeedFactory Interior Parts (Incl. Lighting) 15 11-02-2012 05:25 PM
Kartboy shift knobs. The best! Mach V Dan Interior Parts (Incl. Lighting) 5 10-01-2012 04:22 PM
Aftermarket shift knobs? titusdrake Scion FR-S / Toyota 86 GT86 General Forum 45 09-19-2012 10:59 PM
Perrin Performance Shift Knobs in Stock IslandImportPerformance Interior Parts (Incl. Lighting) 4 08-01-2012 01:02 PM
Shift Knobs For your FR-S TWMPerformance Interior Parts (Incl. Lighting) 19 06-03-2012 09:29 AM
