Old 04-18-2020, 12:30 PM   #197
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by mrg666 View Post
Those T connectors do not give me any confidence that there will be sufficient coolant flow through the cooler. Do you see any temperature difference between the coolant inlet and outlet of the coil?
Why do you feel that way? And what do you mean difference b/t the inlet and outlet? Such as the temp going in and coming out? If so, I have not measured that.
Compared to the throttle body method I'd say it's an improvement. It warms up just as quickly but cools a bit better. It has not been very hot lately so I have yet to see the temps get above 225. Summer will be the real test. I'll be sure to use the torque app to measure the temps. It's a good solution to my NA set up, but not worth comparing to an A2O cooler nor even the Jackson Racing DROC.
MS, CSCS, TSAC-F, CPT
Old 04-18-2020, 12:50 PM   #198
mrg666
pessimistic skeptic
mrg666's Avatar
Cusco piping taps on the inlet and outlet of the radiator, as much as I can see. If this is true, the water pump is not on the flow path through the coil and it will not be forcing coolant through the coil. That was the reason. I could be wrong though.
When the engine is warming up, before the temperature is fully regulated, there should be some temperature difference between the inlet and outlet of coil, if there is flow, I thought. At least that is my experience with the STI cooler I have.
Old 04-18-2020, 01:00 PM   #199
weederr33
weederr33's Avatar
Ah gotcha. Yeah I cannot answer that fully. The only engineering aspect I have knowledge of is human biomechanics lol. I don't have a way to measure the inlet and outlet temperatures, but I don't see how it would not force coolant through as the fluid will find a way to flow into the various channels. Thereby it will have circulation. The only way I can truly compare is via temperature regulation of the two methods I had. But I will keep tabs on how it performs during the summer here.
Old 04-18-2020, 01:12 PM   #200
mrg666
pessimistic skeptic
mrg666's Avatar
I will be curious to see your update. Enjoy your beautiful car!
Old 04-18-2020, 09:03 PM   #201
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
One of my concerns with plumbing it using the radiator hose method is that, when the thermostat is closed, there should not be flow through the radiator hoses. Instead, it's shunted to a close loop within the block and through the heater hoses. If this is correct, radiator hoses and hence the oil cooler wont see any water flow until the thermostat starts to open.
After that I'm not sure. On one hand the feed hose taps into the lower radiator hose which should be the coolest place in the system. On the other hand it's on the suction side of the water pump which may very well limit the water flow through the cooler. It depends on the pressure differential between the two radiator hoses and I haven't a clue how to think that through.
Personally, I'm all over the place on this. After giving this some thought (and buying a couple of radiator hose adapters) I'm starting to lean more toward using the method suggested in the original DIY. I have the parts, it just strikes me as a pain in the ass to do all that and, being a lazy sort, I gravitate toward the easiest looking solution.
The original approach taps into the water galley just downstream of the water pump, runs water through the cooler and then dumps it into the plumbing going to (I think) the heater core. It has the advantage of getting feed water from the high pressure side of the pump as well as being a part of the bypass loop that flows water when the thermostat is closed.
OK - my head officially hurts. Good luck to all of us. My hope is one of the MEs here who does fluid and thermo - dynamics will jump in.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 05-01-2020, 11:33 AM   #202
weederr33
weederr33's Avatar
Upcoming plans for the summer:
repaint front bumper
clear bra front bumper
paint correction & ceramic coating
Old 06-16-2020, 07:10 PM   #203
weederr33
weederr33's Avatar
Just a little bit of HKS bling
Old 06-26-2020, 01:05 PM   #204
weederr33
weederr33's Avatar
Did a dyno this morning at a local place called Torqqe Performance!
CS400, HKS R-Spec high flow cat frontpipe, oem midpipe, TRD muffler; HKS intake duct and drop in filter. I was a little disappointed in the output, but still, good to know what it's putting down!
Old 09-14-2020, 05:16 PM   #205
LancePower
Drives: 2020 BRZ tS
The STi Pads are made for the Brembos?
Front and Rear?
Where did you get them?
LancePower is offline   Reply With Quote
Old 09-14-2020, 09:06 PM   #206
weederr33
weederr33's Avatar
Front and Rear?
Japanparts.com
F - ST262964S020
R - ST262964S030
I only have the fronts. While they grip great, damn can they get squeaky. I'm half tempted to put oem pads back in because it's quite annoying.
Old 09-15-2020, 04:01 AM   #207
LancePower
Drives: 2020 BRZ tS
Thanks for the info and feedback.
Old 09-26-2020, 09:46 AM   #208
weederr33
weederr33's Avatar
Paint corrected and ceramic coated by a local club member!
Old 09-26-2020, 09:50 AM   #209
Capt Spaulding
Persona Non Grata
Simply gorgeous.
Old 09-26-2020, 09:52 AM   #210
weederr33
weederr33's Avatar
Originally Posted by Capt Spaulding View Post
Simply gorgeous.
I plan to put a nice layer of wax on her tomorrow since the ceramic coating will be done curing. Then it will REALLY pop!
Weederr's Cosworth Supercharged Raven weederr33 Member's Car Journals 232 03-25-2024 10:09 PM
FS: DRL Mod for Monogram/10-Series/Release Series 1.0 leoh007 Audio/Visual, Electronics, Infotainment, NAV 0 05-12-2015 12:14 PM
10 Series / Series.Blue rear view mirror 86-ADL Cosmetic Modification (Interior/Exterior/Lighting) 4 11-16-2014 07:32 PM
BRZ series.blue/FRS Series 1.0 photos Johnny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-25-2014 11:23 PM
