Sam Strano
Old 01-12-2015, 08:41 AM   #2045
vroom4
OeM seems to work well enough that I can't see an upgrade as necessary.
vroom4 is offline   Reply With Quote
Old 01-12-2015, 08:47 AM   #2046
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
I tend to agree, but also on the fence
on R1Rs, my oem pads produce a max of -0.7 g's while braking.. I'm sure that could be improved.
then again I never stab my brakes, so who knows??
Old 01-12-2015, 08:54 AM   #2047
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Changing pads can give you different initial bite and modulation ability when braking. It's all down to the users' preference.
Plus in really hot climates, many runs can fade them.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following User Says Thank You to Kido1986 For This Useful Post:
VADERR (01-12-2015)
Old 01-12-2015, 10:45 AM   #2048
VADERR
Completely Lost
VADERR's Avatar
Drives: 2015 CBS BRZ Limited
I'm seriously considering some carbotech xp10's I should be a lot of bite
VADERR is offline   Reply With Quote
Old 01-12-2015, 11:13 AM   #2049
renfield90
The Stig's German cousin
You should be able to hit over 1g braking on top tier street tires. My torque app isn't the best way of measuring, but it pegged me at 1.1 and that sounds about right.
I use Hawk HP+ but most people won't like this pad - extremely high initial bite. Either it will force you to redefine what smooth means on a brake pedal, or you will force the pads through the garage wall. If you want a dual purpose autocross/track pad, look elsewhere; it couldn't cut the cheese for me on track, except for short sessions.
Old 01-12-2015, 01:25 PM   #2050
vroom4
Ive driven a fully prepped STX car on HP+, it was miserable. Even after 4 events I still could not modulate the brakes. It was an on/off switch. To each their own of course.
Old 01-12-2015, 01:38 PM   #2051
Kido1986
Dodging cones
Kido1986's Avatar
More power to you if they work well for you but this car is too light to get enough heat for these pads and they will be really hard to modulate too. The AX6, two steps down, was too much for a 2600-2700lb car.
Old 01-12-2015, 01:38 PM   #2052
renfield90
The nice part is it's tough for people to beat me in my own car
Old 01-12-2015, 02:36 PM   #2053
VADERR
Completely Lost
VADERR's Avatar
Ughhhh lol I'm so confused haha i wish you could test drive parts like you can cars
Old 01-12-2015, 02:41 PM   #2054
vroom4
Shoot me a message on what you want and maybe we can work something out? I've been testing various parts and have a decent amount of my used stuff in stock.
Old 01-12-2015, 09:53 PM   #2055
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
Pads don't increase or decrease G's achieved under max braking. Tires and technique do that.
Brakes either engage ABS/lock up or they don't and need to be fixed. Any car from the factory should be able to engage ABS/lock up if functioning correctly.
Are you saying with sticky tires and factory pads you can't engage ABS?
Briankbot is offline   Reply With Quote
Old 01-13-2015, 08:12 AM   #2056
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
in a straight line on a nice hot day at high speeds? no
Old 01-13-2015, 10:03 AM   #2057
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
That sure seems like an issue which needs to be addressed. I am curious to see if my factory pads end up performing similarly once I'm on stickier tires.
Old 01-13-2015, 10:05 AM   #2058
qoncept
qoncept's Avatar
I had a 1987 Cutlass Ciera that could lock up the brakes with $10 pads. Are you saying that's as good as brakes can possibly get?
qoncept is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
