Old 09-29-2014, 09:53 PM   #2017
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
So I just received my oft did a stg1 flash want to install the open flash manager on my windows xp but it keeps telling me . the application failed to initialize properly (0xc0000135). Click to terminate the application . can anyone give some advice on this thank you .
el-92 is online now   Reply With Quote
Old 09-30-2014, 12:25 AM   #2018
Nardi330
Nardi330's Avatar
Drives: 86
I have issue connecting/updating OFT/OFM.
Recently tried to connect OFT with OFM to update software. OFM says that OFT was connected correctly at the beginning and started downloading updates but it hung at around 96% and while downloading something named "GPX.exe" (or similar) which brought out a XML error message.
I then cancelled which OFM crashed out. I re connected but the error message which was shown in the screenshot below kept appearing (even after reinstalling OFM 1.10.0). if i clicked continue and it gets stuck at "Device identified".
Anyone can help? thanks in advance.
Nardi330 is offline   Reply With Quote
Old 09-30-2014, 01:56 AM   #2019
steve99
make sure you logged in as administrator as ofm is trying to install new version
also try downloading latest ofm from openflash downloads site and intall it manually
may also be missinf font file see OFT TIPS link below and download and install font file attached to first post instructions their in post .
you have been hiding for a while
Old 09-30-2014, 02:16 AM   #2020
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
It would be easier if you just downloaded and installed the newest version of OF Manager (1.11.0). It's quicker than having and older version auto-update to the newest version. It's available for download off of the openflashperformance.com website. That will solve your problem.
Old 09-30-2014, 02:31 AM   #2021
Nardi330
Nardi330's Avatar
Drives: 86
yes there hasn't been much update to the car. Bought Tomei UEL and hoping to get it installed soon. need to get myself updated before switching to stage 2.
thanks Steve and Shiv. however the download page only show OFM 1.10.4 and not 1.11.0. will try 1.10.4 first to see if this will fix my issue.
Edit for update:
downloaded and installed 1.10.4 and it installed fine. connected to OFT and it has the same issue being stuck at PwgPRO.exe at 96% (ie. same as before). reconnected OFT/OFM again and same issue occured as before. thanks.
Old 09-30-2014, 02:49 AM   #2022
Shiv@Openflash
Drives: 2013 FRS
Ooops.... sorry about that. Check back in the morning... it will be there
Old 09-30-2014, 02:52 AM   #2023
Nardi330
Nardi330's Avatar
Drives: 86
awesome. thanks again.
Old 09-30-2014, 02:26 PM   #2024
el-92
el-92's Avatar
Can anyone give me some advice on this its annoying that I can't open it up I've never had problems installing programs before any tips. Thanks
Old 09-30-2014, 08:38 PM   #2025
el-92
el-92's Avatar
So I figured it out . I just used my new computer everything worked out fine .
Old 09-30-2014, 08:55 PM   #2026
Nardi330
Nardi330's Avatar
Drives: 86
hi Shiv,
i have now downloaded and installed OFM 1.11.1 and the issue is still here.
thanks.
Old 09-30-2014, 09:22 PM   #2027
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Seems like there are people with technical problems with OFT. I hope I don't come across this when I get mine.
Kelbyat07 is offline   Reply With Quote
Old 09-30-2014, 10:03 PM   #2028
steve99
hi Shiv,
thanks.
Reading the error text it appears your antivirius is blocking download. suggest temporarily disabling antiviruis to do install
Old 09-30-2014, 10:04 PM   #2029
steve99
shouldnt be a problem mate, generally caused by antivirius just disable it for install and not being loggeg in as administrator
Old 09-30-2014, 10:14 PM   #2030
Nardi330
Nardi330's Avatar
Drives: 86
will try it again at home then.
thanks steve99.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
