#2017 |
Drives: 4 wheels
All you need is
Header, exhaust, tune. KW v3, front camber plates, rear control arm, and a front sway bar. Wheels/tires. Getting a FRS with TRD parts/shocks, wheels/tires isn't much cheaper. |
The Following User Says Thank You to justint5387 For This Useful Post: | tigermack (03-08-2016) |
#2018 |
Rear arm question
Justin what are the benefits from aftermarket rear control arms other than camber adjustment? DP
#2019 |
Drives: 2013 Satin White Pearl BRZ
The bushing type and beeing able to adjust them are the only benefits because you have to use the factory mounting locations
Sent from my SAMSUNG-SM-G900A using Tapatalk |
#2020 |
APEXHNTR
Drives: 10 Series FR-S #1867
Camber is king!
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#2021 |
The Stig's German cousin
#2022 |
Drives: '22 BRZ
Welp, I'm REALLY beginning to see why a front bar is good for autocross. I finally got some warm weather and empty cloverleafs at lunch, my car is 95% neutral on throttle (maybe a bit of understeer as you really push it hard, but stable) and a complete drift machine as soon as you lift throttle at all. It'll be quite tail happy in transitions, I bet. Going to do a couple of events before buying a front bar, but yeahhhh, even on a road course it'll be quite a bit more aggressive than stock even with a bar, lol.
The Following User Says Thank You to DocWalt For This Useful Post: | Racecomp Engineering (03-08-2016) |
#2023 |
If you're looking at V3s for auto-x, you really should check out our RCE Tarmac 2s. Based on KW Clubsport 2 ways, but custom valving and springs. Still built by KW and with a lifetime warranty. A bit more serious than KW V3.
- Andrew |
#2024 | |
Drives: monogram raven
Sent from my XT1585 using Tapatalk |
The Following 2 Users Say Thank You to RTR For This Useful Post: | Racecomp Engineering (03-08-2016), Turkish (03-08-2016) |
#2025 | |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
![]() I hadn't really planned on posting a review (much less in the STX thread), but I have found that the RCE hollow swaybars pair PERFECTLY with the B8/Tarmac shock/spring combo. A little on the rough side for the street, but still manageable, but tight as a fiddle on the parking lots. It doesn't have all the adjustability of the T2's, but comes in at a much lower price point.
The Following User Says Thank You to Turkish For This Useful Post: | Racecomp Engineering (03-08-2016) |
#2026 |
Drives: 2013 Subaru BRZ Limited LR
Hey guys,
** This post has been edited to reflect data gathered from other members so it reflects my best known current LCA listing for STX interested members ** I'm trying to determine exactly which LCAs are stx legal? My list and understanding is as follows: SPC - Legal configuration available. By default, bad bushing material and additional metal. Legal with bushing swap (FR.Sport Part No. 10594) Whiteline (newer model) - Legal Truhart - Stated to have been run at nationals by Scooby South*, so legal? Velox - Stated "legal" configuration available. RacerX - Stated "legal" configuration available. Cusco - Not legal due to spherical bearing. But there are people stating to use these in STX**? RS*R - Legal. Agency Power - Not legal due to spherical bearing. Buddy Club - Status not known. I'm pretty confused. From my reading of the rules, any of them with a bushing is legal as long as the bushing has no more metal in it than stock. That seems like something difficult to really assess? The Whiteline and SPC would both appear to be legal. I have the Whiteline on order and planned to run them at Miller Park; so I'm feeling a bit worried here. In closing I want to be clear I did attempt to read the rules myself, and by my understanding plan to run the Whiteline. *http://forums.nasioc.com/forums/show...postcount=1377 **http://www.apexjunky.com/featured/ap...stx-brz-build/ Last edited by GeorgeJFrick; 03-10-2016 at 12:02 PM. |
The Following User Says Thank You to GeorgeJFrick For This Useful Post: | finch1750 (03-29-2016) |
#2027 |
The new whitelines that are rebranded Spc and the spc are STX legal. I can't see why they wouldn't be.
#2028 | |
Drives: 2013 FRS, 2024 Trueno Edition
The SPC site mentions that it has a "new xAxis(TM) Sealed Flex Joint". Which looking at a cut away of the bushing it would appear illegal. Whiteline's LCA are legal as they do not contain the same technology for the bushing.
![]() Last edited by Shneegle; 03-10-2016 at 10:29 AM. |
The Following 5 Users Say Thank You to Shneegle For This Useful Post: | G-Man (03-10-2016), GeorgeJFrick (03-10-2016), jbailey8748 (03-10-2016), justint5387 (03-11-2016), tigermack (03-10-2016) |
#2029 |
Didn't realize spc changed anything. I don't know the exact wording of the rule book but it has to be the same poly-type bushing no extra metal in the bushing. Whitelines new rlcas deffinately are OK. They are spc rebrands with an eccentric in the poly bushing at the body mount.
I have spoke with velox and the will get you a proper body mount with legal poly bushings and it should be lighter but hard to adjust while on the car. And whitelines is half the price of velox Sent from my SAMSUNG-SM-G900A using Tapatalk |
#2030 |
Drives: 2014 DGM BRZ & 2015 WRB WRX
The RS*R LCA is legal.
Sent from my SM-G900V using Tapatalk
The Following 2 Users Say Thank You to TallTerror13 For This Useful Post: | GeorgeJFrick (03-10-2016), jbailey8748 (03-10-2016) |
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
