Old 04-04-2015, 09:52 PM   #2003
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Originally Posted by *LongFella View Post
CSG David - You know he's buying my Jenny, right?!? ;-)
Sure am!!!
0351USMC is offline   Reply With Quote
The Following User Says Thank You to 0351USMC For This Useful Post:
*LongFella (04-04-2015)
Old 04-04-2015, 10:25 PM   #2004
tnle
Drives: Toyota 86 13'
Out of curiosity, do you guys have a Australian distributor?
tnle is offline   Reply With Quote
Old 04-05-2015, 04:13 AM   #2005
Xuningshen
Drives: Subaru BRZ
First time I really drove my car [up a mountain] or even kept the rpms high for more than a quick minute. mt wilson roads. it was really fun! haha the kit is great.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
The Following 2 Users Say Thank You to Xuningshen For This Useful Post:
*LongFella (04-05-2015), 0351USMC (04-05-2015)
Old 04-05-2015, 01:17 PM   #2006
CSG David
CSG David's Avatar
Tune for 7400, shift at 7000. No offense, but this is an FA20 motor we are talking about. Everything has to make sense.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
0351USMC (04-05-2015), sw20kosh (04-06-2015)
Old 04-05-2015, 03:16 PM   #2007
We ship internationally.
Old 04-05-2015, 07:31 PM   #2008
0351USMC
0351USMC's Avatar
From Moto-East:
I'd keep the revs at 7850. Our car is between 7650 and 7850 (soft cut starts around 7750 usually and full cut at 7850). Hard core auto-x folks will spin to 8000 to get more MPH, but I wouldn't go higher than that with this valve train and stock rods.
Mike
Old 04-05-2015, 07:43 PM   #2009
tnle
That's break the bank levels of hurt with international shipping, low exchange rate and tight customs lol
Old 04-05-2015, 07:53 PM   #2010
It's no different from a distributor still having to pay for shipping and customs, and deal with the exchange rate, except you get CSG support
tnle (04-05-2015)
Old 04-05-2015, 08:18 PM   #2011
Casey10s
Casey10s's Avatar
Drives: 2013 white limited BRZ
For the CSG people, I am running Amsoil 10W30 on my JRSC and I think that is what you use. How many miles do you recommend until the next oil change?
Mostly will be street use with maybe some track at some point.
Casey10s is offline   Reply With Quote
Old 04-05-2015, 08:56 PM   #2012
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
^This
Don't push it more then you need to, unless you have the money to replace an engine...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
The Following User Says Thank You to *LongFella For This Useful Post:
Old 04-06-2015, 02:02 AM   #2013
We use Motul 300V 5W30.
The only way to determine your oil change interval, accurately, is to get an analysis performed by Blackstone or Dyson.
http://www.blackstone-labs.com/
http://www.dysonanalysis.com/
We use Blackstone, but both are excellent.
dp1 (04-06-2015)
Old 04-06-2015, 11:24 AM   #2014
Originally Posted by 0351USMC View Post
From Moto-East:
Mike
I would never rev a stock engine that high. That's asking for an engine failure very, very quickly.
With a full cut at 7850, the engine will still have enough revs to easily hit 8250 RPMs, at which point, you'd actually be spinning the Rotrex to past it's spec as well.
The reason we (CSG) recommend shifting at 7000, is because the TPS and PPS have approximately a 0.04s delay in response. This is enough time where if you have well developed shifting technique (lifting the throttle right as you clutch in), there is a 0.04s long moment where the engine is essentially being free revved at WOT.
Now, you say, wait, there's a rev limiter at 7400! Yes, there is! However, RPMs also have momentum, and if your engine's rate of RPM climb is not zero or close to at 7400, the momentum will still take the RPMs higher.
Our datalogs show that at WOT, a 400-450 rpm rise is frequent.
That's why we recommend shifting at 7000. There's so much more power with the JRSC that you WILL overrev your engine if you're not careful. With a higher redline, the results are catastrophic.
Statements like that make us question how much testing has been performed by other Jackson Racing distributors.
0351USMC (04-06-2015), mkivsoopra (04-06-2015)
Old 04-06-2015, 11:32 AM   #2015
Here's some datalogs illustrating what's going on. This is a lap at WSIR (available in Gran Turismo 6) that shows the RPM plot, throttle position plot, and clutch position (on/off switch).
Now, lets zoom into that spike with the peak RPMs.
You can see clearly between the 2nd and 3rd graph, that I am COMPLETELY off throttle, before the clutch sensor is engaged. However, being an on-off switch, you can't see the exact position of the clutch.
Between 1.00.46 and 1:00.56, there is a surge of 554 RPMs, which occured from a WOT shift at 7209 RPMs.
As you can see from the first, zoomed out graph, there are a LOT of RPM surges at WOT shifts, which happens with any FI solution. You'll also note that all of my shifts, except for that one, occur at 7000 RPMs.
This wasn't even a record lap attempt at WSIR. You can imagine the RPMs with a 7850 redline...
Old 04-06-2015, 11:53 AM   #2016
0351USMC
0351USMC's Avatar
Wow, that's good stuff to know. Yeah I think the safer bet is the stock rev limit of 7400 and shifting at 7000. Thanks for the info!
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
