Old 09-09-2014, 09:44 PM   #1989
Originally Posted by Dihudaxia View Post
Hi CSG/RCE team,
I have a question to ask, not sure if its been posted here, but i am kinda lazy to read thru all the pages..
Am looking to change my current setup to a REALLY comfortable coilover setup and based on a fellow forummer's review and a well made video review, i have been led to believe that RS*R Black-i is the way to do (for my budget).
"More comfortable than the stock setup" has been mentioned a couple of times in the review of the Black-i vs Sports-i vs the something else-i.
My question is:
The Black-i has a spring rate of 7F/7R while the sports-i (supposedly less comfortable) has a spring rate of 6F/7R. While i believe the dampers are tuned differently, can a coilover with a stiffer spring rate really be that much more comfortable??
Isnt the role of the springs to absord the shock??
Sorry for the long ass question, i am really picky about ride comfort. It must be softer and more compliant that stock setup!
Thanks!!
The Sport-i is what you want; the black-i is for slamming the car. PM us for a quote
Dihudaxia (09-10-2014)
Old 09-09-2014, 09:52 PM   #1990
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
@Racecomp Engineering @CSG Mike
What is your preferred rear toe link choice with what is currently available on the market? Any price
Lawnik is offline   Reply With Quote
Old 09-09-2014, 09:58 PM   #1991
gramicci101
Off Topic
@CSG Mike will say SPL. And he's right, it's a top notch product. You could do Cusco, Whiteline, or GTSpec as well.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
CSG Mike (09-09-2014), Lawnik (09-09-2014)
Old 09-09-2014, 10:08 PM   #1992
Winner winner chicken dinner!
SPL
let us know if you want to order.
gramicci101 (09-09-2014), Lawnik (09-09-2014)
Old 09-09-2014, 10:22 PM   #1993
Lawnik
Lawnik's Avatar
SPL
So can I safely assume that you also prefer the SPL lower control arms as well?
I have KW V3's
Thanks for the reply
Old 09-10-2014, 02:29 AM   #1994
I have KW V3's
Correct, and that is what we use on our shop BRZ (and soon on the WRX).
Old 09-10-2014, 02:39 AM   #1995
Dihudaxia
Drives: 86
Originally Posted by Racecomp Engineering View Post
I can't speak to the RSR coilovers as I don't have any first hand experience with them. You may want to check with the user RYU and ultra as I'm pretty sure they've both run their coilovers.
To answer your question, YES you can improve ride comfort while still increasing spring rates. BUT the damper likely won't be cheap.
A very important note: better than stock to one may be much worse than stock to another. It depends on your roads, your expectations, and what kind of bumps bother you. Many will say that their set-up rides "better than stock" but in reality, it's just "different than stock."
I've been on coilovers that swallow up wheel bending potholes without issue, but make the man boobs you didn't know you had jiggle all day going down a concrete stretch of highway. And vice versa...coilovers that are smooth as silk on mostly good but maybe a little choppy pavement, and they make you hit your head on the ceiling on a larger sharp bump.
Both of the above were running stiff rates and could have used some damper tuning. With a little more work they could have had the best of both worlds.
So yes, you can make a coilover with firm rates ride smoothly. It will, however, be easier to make a system that rides well if you're sticking with mild/medium rates as long as you have the travel and good damping. The really excellent damping needed to make very stiff rates ride well generally costs some decent money.
- Andy
Thanks both for your comments. Really appreciate your ideas.
@Andy RCE, maybe a little bit more information for ya.
I totally understand the damper vs harder riding springs idea. Thanks!
Currently am running Swift Springs on stock dampers. While on the topic of ride comfort, generally the ride comfort on the Swifts are ok, bearable, but harder riding than the stock setup.
The road conditions here are quite poor, roads full of potholes and poor repair jobs.
What I am looking for is a suspension that can deal with the sharp bumps and stretches of uneven roads without breaking my spine. The stock does a decent job, the Swifts, not so good with that.
In a nutshell, the more Camry the better.
Hahahah!
If not RS*R’s are there any decently priced coilover that can give a soothing ride? Was also considering HKS GT, spring rates are lower (esp the rears). Will keep reading up and finding out more
@Mike CSG
Any reason for saying the Sports-I is better? Is it due to damper valving or have you tried them both?
Am not really going for low. Low is a bonus. Will PM you, maybe easier to share your ideas via PM.
Dihudaxia is offline   Reply With Quote
Old 09-10-2014, 02:41 AM   #1996
@Mike CSG
The sport-i is made for comfort; the black-i is literally designed with a shorter damper to accommodate cars with 3" or more drops.
The US spec sport-i has lower spring rates and utilizes the OEM top hats for a softer ride, compared to the JDM spec or CSG spec sport-i.
Old 09-10-2014, 02:47 AM   #1997
Dihudaxia
Drives: 86
I see!
How does it fare on rubbish roads? What settings are the dampers on?
Old 09-10-2014, 02:50 AM   #1998
I see!
Settings will vary by car; it's difficult to say blindly, but it's single adjustable so it's easy to play with.
Old 09-10-2014, 10:04 AM   #1999
Hahahah!
@Mike CSG
You might also consider just adding Bilstein HDs to your set-up.
- Andy
Old 09-10-2014, 10:28 AM   #2000
Dihudaxia
Drives: 86
- Andy
I was actually thinking about that...
But was thinking of the Koni's instead of Bilstein HD (which btw its the B6 or B8???)
I thought that Koni's twin tube low pressure gas dampers may yield a better (more comfortable) ride than Bilstein's high pressure monotube. But that is just my theory.
Well, my friend has ordered a set of your RCE Yellows and Koni's so i will take a taxi ride in his car and i reckon if his koni's can handle the Yellows, it should also do well for my Swifts no??
But coils are tempting for one reason, i find my ride height abit too low... Needs a lift cos i have slight scraping issues with the ramps in my carpark....
Old 09-10-2014, 11:56 AM   #2001
Sorry, Bilstein B6 = Bilstein HD.
Definitely go for a ride with your friend to check it out. Konis will do well with Swifts. Our springs are a little taller and use replacement shortened bumpstops so the ride may be slightly better with our springs, but you'll still get a good idea of what to expect.
Both are good shocks...IMO Bilsteins ride better over big bumps, but Konis are a little smoother over small stuff.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 09-10-2014, 12:20 PM   #2002
Dihudaxia
Drives: 86
- Andy
Alrighty...
Cant wait for his taxi ride.
Thanks Andy, you guys here in the thread are awesome!!
Cheers!
The Following User Says Thank You to Dihudaxia For This Useful Post:
Racecomp Engineering (09-10-2014)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
