, dpfarr
Old 01-08-2017, 01:36 AM   #1975
menikmati
Drives: 2015 BRZ, 2005 STI
Received my $500 supercharger rebate today, seems like Edelbrock pulled through when it came to processing the rebate.
There was even an issue of missing an item on the rebate and an Edelbrock representative contacted me via email to request a screen capture of the missing information so that my rebate would be successfully processed.
menikmati is offline   Reply With Quote
The Following 2 Users Say Thank You to menikmati For This Useful Post:
CSG Mike (01-08-2017), Edelbrock LLC (01-17-2017)
Old 01-08-2017, 10:09 AM   #1976
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Damn that's pretty quick, when did you submit your rebate?
Alltezza is offline   Reply With Quote
Old 01-08-2017, 01:07 PM   #1977
menikmati
They received my rebate on 12/8/16.
Old 01-08-2017, 04:19 PM   #1978
VeganGirl
Drives: Scion FR-S 2013
Originally Posted by paiceyfan View Post
First, I have a manual, so not totally comparable. Also, my set-up is very basic, which consists of mostly stock items, with Continental DWS tires and the Edelbrock Supercharger with CARB Tune.
Running in this configuration, I have had issues with a fluctuating idle since the supercharger was installed back in March. Also, when I accelerated away in first, I felt like I had to give a little extra gas to prevent bogging down and then release slightly for a split second and then get back on it again, which took a while for me to get used to.
Of course, like others, I wondered if this was a vacuum leak or a characteristic of the CARB tune. I probably should mention that I am using Shell 93 octane gas.
Recently, Neal at The Racers Line suggested I consider the Delicious tune. The first version (21.0) has completely eradicated the idle issue and the bogging down, so I assume that means the CARB tune was the issue.
I am going through fine tuning now to get it as good as we can, but even the basic Delicious tune solved my issues.
I am not saying this is a solution for those who see the idle fluctuation problems, but it worked for me. Also, I wonder if Edelbrock need to look into this a little more closely. Maybe, there are some cars out there where the CARB tune has it's issues, but not with others, which feedback from owners would suggest.
Your issues sound similar to mine but I don't think I have issues with idle(at least I don't think, I honestly know 0 about cars lmao). I am using shell 93 in Florida, and I have a custom tune from a local tuner. My car is also all stock engine wise besides spec-d exhaust.
I also notice it only happens once the engine has warmed up. On short trips it doesn't do it. Only when I have been driving for about 20 minutes+
VeganGirl is offline   Reply With Quote
Old 01-08-2017, 04:30 PM   #1979
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Hi VeganGirl...So we may have similar issues, but not the same as my issues occurred consistently at all times in all conditions...Never stalled, though.
Sent from my XT1031 using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 01-08-2017, 04:51 PM   #1980
VeganGirl
Mine has never stalled either, is that possible to stall while driving? And being in an automatic?
When it does happen I notice it's around 40-45mph at 1500-2k RPM.
Old 01-08-2017, 06:42 PM   #1981
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by VeganGirl View Post
I am using shell 93 in Florida, and I have a custom tune from a local tuner. My car is also all stock engine wise besides spec-d exhaust. I also notice it only happens once the engine has warmed up. On short trips it doesn't do it. Only when I have been driving for about 20 minutes+
The first thing I would do is take some logs and have your tuner take a look. Did they do a street tune or just a dyno tune? It might be worth it going back and have them ride along while you try to replicate it since it sounds like you can consistently make it happen. good luck!
Old 01-11-2017, 09:31 AM   #1982
BigFatFlip
BigFatFlip's Avatar
Shameless plug:
The BigFatFamily is growing, so its time for a larger car. The Edelbrock was dead nuts reliable and was my daily driver. Can't speak highly enough of its quality and performance, with CARB to boot. Delicious Tuning and Sakou Michi were also a pleasure to work with. Definitely a worth while upgrade and completed my "BRZ STI" build.
Some Edelbrock specific parts coming off my car:
  • Delicious D-box for Edelbrock SC - $120, $100 if bundled with supercharger
  • Custom oil cooler set-up for Edelbrock SC. "Stealth" location behind front bumper vent bezel to not block the intercooler (bezel included). Includes all lines and fittings - $250
    ***RacerX oil cooler plate - $60
    ***Setrab 619 oil cooler core - $120
    ***Ptuning smaller wind shield washer tank - $90
  • Saikou Michi catch can, PCV side, lines modified to work with Edelbrock, but includes extra lines so it can work with any application- $70
Located in NorCal. Link to part-out post: http://www.ft86club.com/forums/showp...postcount=7285
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
Edelbrock LLC (01-17-2017), Phantobe (01-13-2017)
Old 01-13-2017, 12:00 PM   #1983
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
Any info on 2017 compatibility?
illmatic is offline   Reply With Quote
Old 01-13-2017, 12:31 PM   #1984
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
This is not definitve but.....
I just bought a whole Edelbrock/delicious tune package from Counterspace Garage.
I dont think Mike would have let me do that without warning if he was aware of any hardware issues. Then again, maybe none are known at this time. Again, just sharing...Edelbrock should be the one to answer this i suppose.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 01-13-2017, 12:36 PM   #1985
BigFatFlip
BigFatFlip's Avatar
I'm probably wrong, but I believe there isn't a CARB tune for 2017 yet, but if you are going Delicious, you should be fine.
Old 01-13-2017, 12:48 PM   #1986
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We have the power!
-Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Silverfox (01-13-2017)
Old 01-13-2017, 12:58 PM   #1987
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I eat Low Carb, so no worries there.
Daily: Audi TT RS
Old 01-13-2017, 01:13 PM   #1988
sato
sato's Avatar
Drives: Dodge Patitas
How many in here have "remote tunes", other than CARB tune?
Sent from my A1P using Tapatalk
The Following User Says Thank You to sato For This Useful Post:
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
