go_a_way1, MisterSheep
Old 10-27-2018, 06:26 PM   #19853
Ashikabi
Ashikabi's Avatar
Originally Posted by Impureclient View Post
For $40, I wouldn't even think of bothering trying to make them myself. That was a while ago when you paid that though, right?
I've had them I think 3 years now
The Following User Says Thank You to Ashikabi For This Useful Post:
Impureclient (10-27-2018)
Old 10-27-2018, 07:32 PM   #19854
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I installed lca, trailing, toe, sway + endlinks, and rear coils. It's way out of alignment now. lol.
Messin with camber, toe, and trailing arm adjustments.
front parts get installed another day...
I LIKE TIRES!
Old 10-27-2018, 09:28 PM   #19855
Dadillac
Drives: 2018 Ford Mustang EB Premium 6M
I just drilled 17 holes in my brand new car. 13 for the OEM arm rest and 4 for the front license plate holder. Also I installed the 86 Speed hood struts last week. I will also say that they work perfectly fine. Only time will tell if they are as bad as I have heard. But I suppose they will be just fine
Don
Dadillac is offline   Reply With Quote
Old 10-27-2018, 11:42 PM   #19856
humfrz
Originally Posted by SuperTom View Post
What's wrong with the stock hood prop? Lightweight, functional, Free
I have wondered this for sometime now.
I just don't find myself doing a lot under the hood of my car. I check the oil level about every other month. A few times a year I open the hood to look for something that a forum poster is talking about. Oh, yes, when I first got the car, I opened the hood once because my brother wanted to see what a FA20 engine looked like.
As far as hood struts, I suppose they are OK, and if someone wanted to give me a set and install them, I would be OK with that.
Meanwhile, I feel the hood prop does what I want it to do and I even think it's kind of old time-ie quaint.
humfrz
wulfstan (11-04-2018)
Old 10-27-2018, 11:47 PM   #19857
humfrz
Where is the video - ??
humfrz
Leonardo (10-28-2018)
Old 10-28-2018, 12:15 AM   #19858
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Don
For what it's worth, I've had them on my car for 2 years and aside the stickers peeling, they work great. They even work in temps as low as -20F so far. Probably one of my favorite mods for any car that doesn't come with them.
The Following User Says Thank You to DarkPira7e For This Useful Post:
Ashikabi (10-28-2018)
Old 10-28-2018, 12:18 AM   #19859
Ashikabi
Ashikabi's Avatar
I can probably agree with that. If I got a new (used, let's not be silly) FR-S tomorrow, by Monday I will have ordered a one piece drive shaft, hood struts, and a fumoto valve.
DarkPira7e (10-28-2018)
Old 10-28-2018, 12:23 AM   #19860
DarkPira7e
DarkPira7e's Avatar
I've always wanted to buy a different driveshaft but my mind is seated since I know mine "works". I love drivability mods. If you have one, sway me please! I bought the m85 diff and some new bushings for it, may as well replace the rolling pin too.
Old 10-28-2018, 12:27 AM   #19861
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I think my one piece shaft is smoother.
Old 10-28-2018, 12:51 AM   #19862
Ashikabi
Ashikabi's Avatar
Sapphirehero is right. One piece is smoother engaging and less noisy. My stock shaft had lots of play. I can't say my aluminum driveshaft shop one made the car faster but it did improve my driving experience. And for $350or whatever, it's a must in my opinion. If you have patience, you can get em used. I sold mine a couple months ago cuz it won't fit my LS build
Old 10-28-2018, 02:22 AM   #19863
Leonardo
Country Boy 4 Life
Leonardo's Avatar
humfrz
Fortune Auto 500. Blackworks LCA, J2 trailing & toe, whiteline endlink, Perrin sway bar. Had to hacksaw and use a boltcutter on the OEM toe ball joint bolt. Then it was short enough for my ball joint separator. Other than that, the install went fairly smooth. I'm excited about installing the parts on the front next. More pics soon...
EDIT: PIC RESOLUTION UPGRADE
I LIKE TIRES!
Old 10-28-2018, 02:26 AM   #19864
humfrz
Fortune Auto 500. Blackworks LCA, J2 trailing & toe, whiteline endlink, Perrin sway bar. Had to hacksaw and use a boltcutter on the OEM toe ball joint bolt. Then it was short enough for my ball joint separator. Other than that, the install went fairly smooth. I'm excited about the parts fot the front next. More pics soon...
Well, I'll be damn - you really did put them on -
humfrz
Old 10-29-2018, 06:35 PM   #19865
ELLSSUU
Drives: FR-S, 951, Venza, Accord, MDX
Refinished TRD wheels for my son. Two were slightly curbed. All had paint chipping that is apparently common with these. Sanded, scuffed, filled, cleaned and painted with a General Motors GunMetal color that was close as I could find. Just a bit lighter than the OEM TRD color. Still need to paint the barrels, apply the red to the sunken TRD center cap emblems and clear coat all.
I have not decided wether to clear them with a Satin or Matte clear. Suggestions?
ELLSSUU is offline   Reply With Quote
The Following 3 Users Say Thank You to ELLSSUU For This Useful Post:
Rican_D (10-30-2018), SuperTom (10-30-2018), wulfstan (11-04-2018)
Old 10-29-2018, 09:17 PM   #19866
Impureclient
Drives: 2015 FR-S
Originally Posted by ELLSSUU View Post
Refinished TRD wheels for my son....
I have not decided whether to clear them with a Satin or Matte clear. Suggestions?
I would do satin or even glossier. Higher sheen = longer lasting and easier to clean. My current wheels came in a matte finish and that's the only thing I'd change is do a gloss clear on them if I ever refinished them.
The only good thing is the matte finish hides the brake dust better but that's on a matte black finish and you are doing silver.
Impureclient is offline   Reply With Quote
