09-29-2014, 11:56 PM | #1961 | |
E.g., on an oval, you can be riding the bump stop and be perfectly okay... |
09-30-2014, 12:05 AM | #1962 |
Stig's dark passenger
How much slower is an FRS. Around streets of willow without a wing??
09-30-2014, 12:23 AM | #1963 |
Drives: WRB JR BRZED
On the track prep thread, it says to not brake hard enough to engage ABS. If there is no brake fade, what other reason is there not to use ABS?
09-30-2014, 12:30 AM | #1964 |
Off Topic
ABS will be slower. If you can hold the brakes just below the point of engaging ABS, you will be using as much of the tire's traction as possible to slow the car down and the brake pads will be a steady pressure on the rotors. You're basically at the maximum effective braking ability of the car.
If you brake hard enough to engage ABS, it will pulse the brakes, repeatedly locking them up and releasing them. It isn't smooth and could upset the car if you're in a turn. Plus since you're repeatedly losing traction, you're not slowing down as effectively as you would if you had traction the entire time. Longer braking times mean shorter acceleration times means longer lap times. |
The Following User Says Thank You to gramicci101 For This Useful Post: | CSG Mike (09-30-2014) |
09-30-2014, 12:45 AM | #1965 |
09-30-2014, 01:49 AM | #1966 | |
09-30-2014, 03:39 AM | #1967 |
Brake a little earlier, and stop using it. You'll find that you'll scrub the speed faster, AND be more settled for the corner
09-30-2014, 07:24 AM | #1968 |
Drives: 2012 Toyota 86
ive taken this advice and it has proven good for me. i use to just ride the abs into all the corners, now i stay out of it, if i need to brake earlier, so be it. as many people more experienced than me on here have said, and im sure mike has said once, corner exit is more important than entry. i have a nice clip of me overtaking a porsche cayman after a corner exit that demonstrates this nicely.
[ame]http://youtu.be/xGvNDPLL-CM[/ame] |
The Following User Says Thank You to troek For This Useful Post: | CSG Mike (09-30-2014) |
09-30-2014, 07:57 AM | #1969 |
Drives: FR-S, Evo 9, Evo X
Mike this is a great thread and a terrific resource.
Thanks, Marty Grand |
The Following User Says Thank You to Mgrand34 For This Useful Post: | CSG Mike (09-30-2014) |
09-30-2014, 08:05 AM | #1970 |
Drives: 2013 FRS Whiteout
@CSG Mike
I wanted to know what a reasonable front and rear camber would be to accomodate 9" wheels with 255 tires. What's the max I could use without really causing an extreme wear situation for daily driving. I do occasional HPDE so I know camber would benefit me. Part two of the question- When installing rear control arm to adjust camber at what point will i NEED toe arms? At what camber setting do the rear toe arms fall short. Thanks! |
09-30-2014, 10:19 AM | #1971 |
Drives: RV-7
Mike, would you recommend rotating tires between track days at different circuits?
If so, what pattern would you use with a square setup and non-directional asymmetric tires (Michelin PSS)? I'm rotating rears cross to front, front straight back after a track day but am wondering if it helps at all in prep for the next event. TIA... |
09-30-2014, 01:36 PM | #1972 | |
On a similar note, how do people feel about remote reservoir shocks? Good? Bad? Not worth the point cost in competition? Etc.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
09-30-2014, 04:36 PM | #1973 | |
You *need* the arms when you want to be able to adjust rear camber. Otherwise you're at the mercy of your height adjustment. |
09-30-2014, 04:37 PM | #1974 | |
Similar Threads | ||||
Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 07:48 AM |
Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 09:54 AM |
