10-13-2022, 02:10 PM | #19643 | |
Drives: 2017 BRZ Premium MT (DGM)
As for the "alignment and fuel induction service", see attached scan. Looks like maybe they meant wheel alignment (which maybe I'd look into after replacing tires at next oil change interval) HOWEVER the "fuel induction service" still seems suspicious. As you speculated, I'm guessing they just meant running some injection cleaner through the system. Regarding the transmission/rear differential fluid changes. Thoughts as to why the factory maintenance schedule says "inspect" only for the transmission fluid? I did find (as you point out) many threads here suggesting that both (rear diff AND transmission) fluids be changed. Again, thank you guys both. |
The Following User Says Thank You to joro2 For This Useful Post: | NoHaveMSG (10-13-2022) |
10-13-2022, 02:31 PM | #19644 | ||
Drives: 22 BRZ limited
The Following 3 Users Say Thank You to dragoontwo For This Useful Post: |
10-13-2022, 02:34 PM | #19645 | |
I am a strong believer in not over changing fluids. Many people seem to just do it because they can and it makes them feel better. Tranny and diff oils though can certainly stand to be changed a little more often than the others. This is especially true in places that see temperature extremes of heat or cold. Not saying run out every year and change them unless tracking or very heavy use but that is a different discussion.
10-13-2022, 02:37 PM | #19646 |
There are indeed cars that can benefit from such a service but the Twins double injection (direct and port) really does a pretty good job of blowing carbon off on it's own.
Could get pretty much the same results as dumping a $7 bottle of cleaner in the fuel tank anyway.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | joro2 (10-13-2022), soundman98 (10-13-2022) |
10-13-2022, 02:42 PM | #19647 | |
10-13-2022, 02:45 PM | #19648 |
I bet there are at least a few that strongly believe it is AWD and turboed so there is little doubt they will not have a clue that it has the Toyota DS4 injection system on it.
The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (10-13-2022) |
10-13-2022, 03:40 PM | #19649 |
chicken tonight
this "fuel induction service" is a load of BS. It's not a fuel additive, so it's a lie to say it "works its way through the injectors."
It's sprayed into the intake upstream of the throttle body.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
10-13-2022, 08:26 PM | #19650 |
Drives: Crapcan
Oh that's right. Isn't that where they take the can of cleaner and pour/spray it into one of the PCV ports on the back of the intake manifold? Waste of time with D4S.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (10-13-2022) |
10-13-2022, 08:29 PM | #19651 |
I thought they put the car in a mist filled room with the gas cap off and that is how it manages to clean both the intake AND the injectors. Then it all meets in the middle through the throttle body and flush's off the valves.
The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (10-13-2022) |
10-13-2022, 08:47 PM | #19652 | |
ProCrastinationConsultant
literally takes a screwdriver and 20 minutes to do yourself, but i'd never do it on a car with less than 150,000 miles, and only if it's got a funky idle.
The Following User Says Thank You to soundman98 For This Useful Post: | Ultramaroon (10-13-2022) |
10-13-2022, 11:25 PM | #19653 |
chicken tonight
Like James Brown funky? Papa don't take no mess.
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (10-14-2022) |
10-13-2022, 11:40 PM | #19654 |
helmholtz resonator
Drives: '15 ultramarine
10-14-2022, 12:40 PM | #19655 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
It's also a dessert topping and floor wax!
It did save my CB650 with four sticky carbs that a shop couldn't even ... Helped my 2 stroke string trimmer start in the spring for 20 years. Seafoam has a place. Just where, is debatable.
"I gotta rock." -- Charley Brown |
The Following 2 Users Say Thank You to bcj For This Useful Post: | soundman98 (10-14-2022), Ultramaroon (10-15-2022) |
10-14-2022, 11:50 PM | #19656 |
it's a bit of everything. more like wd-40 for inside the motor.
i see they've got 'sea foam spray' now for intake cleaning. 20-ish years ago, they didn't have that. the official procedure on the can was to pull one of the vacuum hoses ahead of the carb/throttle plate, and basically allow the motor to 'slurp' the stuff in. there was a real risk of hydro-locking the motor with this method
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 10:35 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 08:53 AM |
