Old 08-03-2015, 08:27 AM   #183
churchx
churchx's Avatar
Drives: 2014 GT86
Originally Posted by AceHeader-MT
150- highest peak HP and lower torque
150- robotic weld at 2-1 merger
250- 1-2%HP drop from 150 and 3-4% more torque
250- 100% hand welded
350- LHD cars only, 100% hand welded
350 dyno sheet available here:
http://www.ft86club.com/forums/showt...t=80609&page=5
Those higher or drop of hp/torque are relative to 350, or 150 vs 250?
Old 08-03-2015, 09:38 AM   #184
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Originally Posted by Calum View Post
Your link to the dyno plots doesn't work.
Can we get a complete explanation on ALL of the different options for this header.
There's type a and type b, as well as different overpipe designs. If I was going to order one I wouldn't even know where to start at this point. Also, you should include the explanation on your site.
Edit, after reading through some of the posts I'm come to the conclusion that the type A has 15* collectors, while the type B has 20* collectors. The 15* are more expensive because they take longer and require a human to weld, but they make more power. I'd be interested and in knowing how much more, but that has been asked already.
There's also the type C, but that's a temporary measure to get orders filled faster. Nevertheless, I'm curious to know the collector convergence angle on the type C, and if the internal steps help or hurt power.
There are also three options for the 2-1 merge. The 350 (mm?) is left hand drive only and gives the most low end power, but the least high end power gains.
The 150 is the opposite of the 350's gains in that it gives the best high end power and the least low end gains, of the three options.
There is also a 250 that can work with both left and right hand drive and would likely offer the best of both worlds when it comes to gains at both ends.
Is that accurate?
Edit 2, so I just looked at your site, you also offer custom collector convergence angles.
Appologizes for all the confusion with different types.
To simplify, we only have a Type A and B now.
Type A= 100% hand made. 15* converging angles
Type B= 80% hand welded. Slip joints and 20* converging angle
Any collector will fit with any header. A or B
It's since come to our attention that the type A is WAY overbuilt for an NA application. Also it takes over 3 weeks to build.
The type B is designed to get the same relative performance with a turnover time of just over 1 week.
All converging angles can be customized, but the 15* and 20* angles from the primary runners have shown very little variance in overall HP or Torque. The extent of the gains are found in the "2-1 OP's" which is why (depending on track/driving conditions) we have different variations to suit different applications.
Depending on the track we're racing at, we have a 2-1 collector to suit our needs.
Hope this helps clear up some things. And, yes the 250 is really for our colonial cousins in RHD cars to get maximum torque.
AceHeader-MT is offline   Reply With Quote
Old 08-03-2015, 09:47 AM   #185
AceHeader-MT
Drives: 2012 FR-S
350= max torque (202.4NM), lowest peak HP (175.1HP)
250= torque (approx 200NM), HP (approx 178)
150= lowest torque (approx 195NM), HP (approx 182)
These numbers are approximated off percentages of the 350 when we did a stock dyno run with OEM frontpipe
Old 08-03-2015, 10:20 AM   #186
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Is that accurate?
I'm glad somebody agreed with me on this. I would rather see it simplified especially if it brought the price down some.
JoeBoxer is offline   Reply With Quote
Old 08-03-2015, 12:07 PM   #187
churchx
churchx's Avatar
Drives: 2014 GT86
AceHeader-MT: thanks for nfo. I guess i'll prefer more torque even at expense of lower hp.
And btw, from my view nothing wrong with being way overbuilt. I'd still want to have the best, instead of regret of choosing compromise
Old 08-03-2015, 01:15 PM   #188
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm not saying they should change the choices, this nearly a la cart setup is pretty awesome if you ask me. I just wanted everything explained in one ease to find location.
Old 08-03-2015, 01:36 PM   #189
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
Wow thats a lot of options.
Since you'll be in the Boston area this month i'd love to meet up and chat about a couple of options for my car.
Will you be bringing any systems with you stateside?
Kotu100 is offline   Reply With Quote
Old 08-03-2015, 03:12 PM   #190
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Man 3 designs just for the overpipe? The lv of expertise is no joke.
Old 08-03-2015, 03:50 PM   #191
Not a surprise the Ace makes more power than every other header on the market
Old 08-03-2015, 05:00 PM   #192
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by AceHeader-MT View Post
Hi Folks,
The type A's are welded by- what you would call- a NASA welder...while the B's are welded by a NAVY welder and the Panasonic welding robot.
-Ace Header
As someone who's been in the Navy for 16 years, that really doesn't give me any confidence at all. When I read that, my first thought was that you were selling something with welds that'll look like Borla's welds.
My thought was, "so one is made by someone who specializes at keeping air in, and the other at keeping water out?"
Old 08-04-2015, 02:05 PM   #193
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Originally Posted by olsonpg View Post
Hey ACE! Just received my Type B in the mail and it looks amazing cant wait to put it on tomorrow.
I just had one question that i'm sure might cross a few peoples minds and that is on the type "B" if the "slip" joints cause any sort of restrictions for the gases to stumble over on over internally ?
Thanks ACE you guys rock.
Phil
Slip joints make the manufacturing process quicker and the losses you are thinking about are negligible.
CounterSpace Garage is offline   Reply With Quote
Old 08-05-2015, 01:17 PM   #194
Carlysh
Carlysh's Avatar
Drives: 2007 Mazda 3, New Raven FR-S 6mt
Curious what numbers and power delivery this header does on pump 93 with 3 inch full exhaust
Carlysh is offline   Reply With Quote
Old 08-05-2015, 01:50 PM   #195
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
T-minus 6 months until PLM knock off...
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 08-05-2015, 01:51 PM   #196
CounterSpace Garage
Better than 91 octane but not as good as E85.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
