Old 04-16-2018, 01:35 AM   #183
Sc629
Drives: 2017 86 Asphalt
Originally Posted by DustinS View Post
If the car has manual climate controls. It’s a different harness.
thats what i thought but the guy on facebook gave me hope they just simplified it to one harness that would work for both setups :/
thanks!
Sc629 is offline   Reply With Quote
Old 07-10-2018, 02:58 AM   #184
dezmoondo
dezmoondo's Avatar
Drives: Whiteout FRS
I don’t know why it is impossible to find the part number of the harness. I tried looking. Does anyone work for Toyota or TRD? I bet they can help us find it.
dezmoondo is offline   Reply With Quote
Old 07-10-2018, 10:29 AM   #185
Chaetagnath
Do you mean for the dash harness of a BRZ limited or other car with Automatic dual air? I believe it is 81302CA360.
Chaetagnath is offline   Reply With Quote
Old 07-10-2018, 12:38 PM   #186
dezmoondo
dezmoondo's Avatar
Thank you for the part number.
I was referring to the harness for automatic dual air. I have went on many part dealers for Toyota and Subaru and still couldn’t find the specific harness. I am sure dealers and order the part with part number
Old 07-10-2018, 01:19 PM   #187
Chaetagnath
As far as I know, it’s normally integrated into the dash harness. I do t think there is a separate one for the a/c. That’s why going from manual ac to dual auto is such a pain, because you have to retrofit it.
Old 07-30-2018, 10:14 PM   #188
AxisPower
Drives: 23 GT4RS
For all the people that have traveled down this path before, is it possible to replace the entire dash harness with a limited/monogram dash harness or are there too many differences between trim levels for the harnesses to just be plug and play and is a conversion harness the easier way of doing this swap.
AxisPower is offline   Reply With Quote
Old 08-25-2018, 07:50 PM   #189
dezmoondo
dezmoondo's Avatar
I have noticed that you have previously stated that it is not possible to retrofit the manual blower to the auto blower. If I do not care for the dual zone function, does it matter? Also if I do only single zone, the passenger side knob will not light up right.
Old 08-26-2018, 08:07 PM   #190
Chaetagnath
You can use the manual blower to do single temp with auto function. In that case, the passenger knob will light up, and even allow you to set a different temp as if it were dual, but won’t do anything functionally.
Old 12-07-2018, 06:31 PM   #191
Junior_ctba
Drives: Brz 2014
good afternoon guys, I've read and re-read it several times and still do not know how to do it, is there anyone in california who can do it for me? my email junioradrenalinamx@hotmail.com
Junior_ctba is offline   Reply With Quote
Old 01-24-2019, 06:15 PM   #192
lucas.sidoti
Drives: FT86 - White
Hey there! Here from Argentina!
I leave here female pin and male pin!
MALE
https://www.hi-1000ec.com/product/1214
FEMALE
https://hi-1000.shop-pro.jp/?pid=13999104
lucas.sidoti is offline   Reply With Quote
Old 01-06-2020, 08:55 PM   #193
Twitchy313
Twitchy313's Avatar
Drives: 2014 Scion FR-S
Could this be the harness?
https://www.subarupartsdeal.com/part...153,81302CA653
Twitchy313 is offline   Reply With Quote
Old 02-01-2020, 11:37 PM   #194
lucas.sidoti
Good news
Finaly all mu parts arrived, i have the harness wired and mthe servos that control the aire flow in.
Bad news:
At the moment of geting in the temperature control servo i figure out that its not compatible with the manual ac HVAC, first of all the gear thats comes with the manual HVAC does not fit with the gear of the servo. And altought i may solve that the oem hvac does not have the towers to insert the screws. I so that servo its not compatible at all. I would like to its that dustin did it
Old 02-02-2020, 12:44 AM   #195
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by lucas.sidoti View Post
Good news
Bad news:
You can only do single climate conversion if you keep the manual HVAC box. Need to either buy an entire used one from a dual climate car or buy a case and the internal dual parts. I bought a new case and internal parts. I just haven’t Installed them yet. My wife doesn’t like It when the numbers don’t match anyway so it doesn’t do me any good. I also don’t have ac currently due to being swapped.
DustinS is offline   Reply With Quote
Old 02-12-2020, 04:34 PM   #196
Twitchy313
Twitchy313's Avatar
Good news
Bad news:
Where did you get the harness from?
Wtb:pnp harness for automatic climate control for frs Sangthing Want-To-Buy Requests 5 01-02-2015 04:11 PM
BRZ limited dual climate control Sangthing Interior Parts (Incl. Lighting) 6 09-12-2014 06:01 AM
Ac knobs for BRZ limited / FRS with dual climate dnizzle Cosmetic Modification (Interior/Exterior/Lighting) 3 08-15-2014 10:43 PM
FS - BRZ Dual Climate Control Unit dvsidboy Audio/Visual, Electronics, Infotainment, NAV 4 01-12-2014 08:52 PM
