Old 02-26-2016, 08:56 AM   #183
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Congrats sir. They really are great cars. Try to track it at least once. The real beauty in these cars, cant fully be appreciated till they are in that (their) element.
Wife still bust my balls every track day that we don't have our cayman anymore.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following User Says Thank You to brzaapi For This Useful Post:
Gaiakai (02-27-2016)
Old 02-26-2016, 04:03 PM   #184
Coaster
Coaster's Avatar
Drives: Civic
Anyone been in a 981?
Thoughts on suspension and gearing?
Hope to own one someday...
Coaster is offline   Reply With Quote
Old 02-26-2016, 10:07 PM   #185
strmshadow84
Drives: 14 Cayman S, 16 Camaro 2SS
I have a 981 S, haven't tracked the car at all. The suspension feels nice and tight not really any body roll that I can feel (not a pro). I feel that the gearing is too long though, the only thing that I really dislike about the car. 1st and 2nd gear feels just way too long and I feel that 6th gear could be longer (for better mpg on highway).
strmshadow84 is offline   Reply With Quote
The Following User Says Thank You to strmshadow84 For This Useful Post:
Coaster (02-26-2016)
Old 02-27-2016, 12:46 AM   #186
Gaiakai
Gaiakai's Avatar
Drives: '21 Civic Type R
What do you think of the shifter feel compared to the 86 twins? My 987 feels very vague compared to the very quick and precise shifter from the BRZ.
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram!
Gaiakai is offline   Reply With Quote
Old 02-27-2016, 02:07 AM   #187
strmshadow84
I feel the same, the shifter doesn't have the as precise of a feel as my BRZ did, I guess since it's a remote shifter *shrug*
Old 02-29-2016, 12:12 AM   #188
Tokay444
Originally Posted by ZDan View Post
Centrifugal blowers are quite peaky as they build boost with rpm. Vortech supercharged S2000 is peakier than stock:
That's one of the most linear graphs I've ever seen. "Peaky" and, "stock S2000" don't even belong in the same sentence.
Old 02-29-2016, 09:44 AM   #189
ZDan
ZDan's Avatar
Drives: '23 BRZ
Linear doesn't mean "not peaky". See how power builds to a *PEAK* right below redline? It's peaky. Which is fine, as it has fantastic close-ratio 6-speed gearbox which makes it a joy to keep in the relatively narrow powerband.
Any N.A. engine that makes a respectable amount of power per displacement and a broad flat torque curve is necessarily going to be somewhat "peaky" in terms of power curve.
The centrifugally blown is objectively peakier. If we define the powerband as the rpm range where the engine makes at least 85% of peak power, the centrifugally supercharged engine makes that from 7500 to 8900rpm, 16% of the rev range. The N.A. one makes at least 85% of peak power from 6800 to 8900, 24% of the rev range.
The POINT I was making 2 years ago was that centrifugal blowers don't reduce peakiness, but rather exaggerate it. The dyno chart posted bears this out.
Turbo engine making the same power would be a lot less peaky with a much broader powerband. Which just means that torque peaks earlier and then falls off with rpm.
Personally, I *love* my F20C's power delivery. Only thing I would change would be to go to the bigger cam lobes a lot earlier to eliminate the goofy/gimmicky "kick" at 6000rpm. Crossover should happen at the rpm where the power/torque is the same on either set of lobes.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
CSG Mike (03-01-2016), toeout (02-29-2016)
Old 02-29-2016, 10:26 AM   #190
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
@WolfpackS2k I have to thank you for this post. I've read it over multiple times and ultimately helped in my decision to get a 987 instead of supercharging my BRZ. Your impressions and breakdown are spot on sir
Obligatory whoring of my new (to me) car, with a Boxster parking buddy I found at work:
Congrats on the new car! I'm very happy to have been able to help you with your decision.
The 981 is a pretty great car, but if you drive one back to back with a 987 it exposes how numb the steering of the 981 is. 987 has hydraulic PS, the 981 EPS. It's quite noticeable.
I agree with your sentiments on the gearing. First 3 gears are too tall and 6th is too short! What were they thinking???
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
The Following User Says Thank You to WolfpackS2k For This Useful Post:
strmshadow84 (03-04-2016)
Old 02-29-2016, 10:30 PM   #191
Tokay444
Linear means not peaky.
Peaky.
Linear.
Old 02-29-2016, 10:38 PM   #192
totopo
Drives: 370z
look at the torque curve. torque is hp/rpm, so you see the stock tq curve is basically completely flat, with the little VTEC YO! bump to the second cams. The sc'd torque curve you see is slightly up sloped at the end, which means it is peaky. maybe mildly peaky, but still not linear. contrast that to the roots type like below, where you make peak torque low.
totopo is offline   Reply With Quote
Old 02-29-2016, 10:53 PM   #193
Tokay444
That's not peaky.
What roots type below? Those are 3 N/A motors.
And hp is a product of torque. Not the other way around.
(RPM*torque)/5252=HP.
Old 02-29-2016, 10:58 PM   #194
totopo
Drives: 370z
That's not peaky.
ops. i don't know my muscle cars well, shoulda looked more carefully, my bad
Old 03-01-2016, 04:13 AM   #195
Sounds like you need a Kpro.
Engagement at sub 4500 with a test pipe is common once you're tuned.
ZDan (03-01-2016)
Old 03-01-2016, 04:13 AM   #196
Peaky.
Linear means "straight". You can have an upward slope, and still be linear.
ZDan (03-01-2016)
brz, cayman, s2000
2013 981 Cayman ironchef Other Vehicles & General Automotive Discussions 49 12-09-2012 08:03 PM
FR-S vs Cayman colganc FR-S / BRZ vs.... 102 09-13-2012 05:17 PM
GT86 vs. 370 vs. Cayman S wrxgoose FR-S / BRZ vs.... 0 08-28-2012 12:26 AM
FRS/brz VS Porsche Cayman jurjurson FR-S / BRZ vs.... 22 08-15-2012 05:14 PM
FR-S, Cayman S, & Lexus GS Mcdj18 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-23-2012 05:49 PM
