#183 |
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Just saw the update to the first post which includes that, thank you!
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8 |
#184 | |
Drives: 2013 FR-S, 2012 MCS
I also want 250-270whp. The only reason I'd even consider a SC over a TC is because of the early onset of torque down low. I want the earliest boost possible, therefor smaller, cheaper, FI kits (win win). However I think the overhead of a turbo, just in case I do want to upgrade my torque converter and take it to a drag strip later on down the road I can and also add hp with supporting mods (I think the AVO turbo is rated at like 360 crankhp while the base kit only puts down about 272chp) where with a base SC (think Innovate) my overhead is almost shot right out of the box unless I use E85, which is so inconvenient for me I don't even consider it a possibility. This thread has been a great read, and while I'll probably never follow through on a FI kit, pretty darn good info here for anyone interested in tuning for forced induction. |
#185 |
Drives: 2013 MT Ultramarine Scion FR-S
Great thread. Luckily for me I've already told myself I am waiting for the warranty to be up before I do any FI, which gives me a couple years. Although you do have me changing my mind on the SC vs turbo choice again...
I talked myself into a SC but here we go again. AVO sounds pretty reliable, especially for the price (and I love the mechanical oil pump).
#186 |
Junior
Drives: a car
mmk I'm callin for a sticky!
#187 |
This area is a pain in the ass for every engine to control leaking. Head, block, chain cover intersection is probably the most common leak area.
#188 |
Junior
Drives: a car
Would the heat soaking be different if you held the car at full boost for the same amount of time? or does the repeated cooling and heating cycle compound the heat within the engine bay?
#189 |
Drives: WRB JR BRZED
If you don't have access to E85, your limited to what....a little over 300 whp unless you want to introduce serious turbo lag. So at that point, I chose SC so I wouldn't have to deal with any of the problems turbos can introduce and save money. SC problems seem more manageable anyways so I'll just max out the potential of the SC kit and get as close to 300 as I can.
#190 |
Junior
Drives: a car
has anyone seen a TMIC turbo kit for this car yet?? would it even be possible...
I would buy it (if it produced some decent numbers) and pair it with this hood...: http://www.rksport.com/product-p/rk-435.htm done correctly, it could be to the same effect of the hood bump on the E92 M3
#191 | |
Drives: 2016 STi DGM
-2014 SSM BRZ MT
#192 |
Drives: 2017 Subaru BRZ, 1994 Mazda Miata
Going back to the OP I think the Jackson Racing kit is the best setup for a DD.
The "factory tuned" kit is $5k +/- taxes/shipping and if you are paying for installation.
For a DD the kit is complete out of the box. But if you want to track the car then you want to get an engine oil cooler.
In terms of OEM quality, Jackson Racing has been around for long time and knows their stuff that even Honda went to them for their CR-Z supercharger kit.
There are still cars out there that are running the older Jackson Racing eaton kits. My brother has a Rotrex kit on his car designed by Oscar Jackson, and it has over 100,000 supercharged miles and it has given him no problems.Plus I see your in CA, and that CARB sticker would be a huge plus. Definitely after the 5 year mark, who wants to keep uninstalling and reinstalling for every smog check. I think a DD shouldn't have a hassle of worrying about being pulled over or not being compliant. Last edited by NoppyNop; 01-29-2014 at 03:39 AM. |
#193 |
Drives: UM86 - 6MT
Does the Jackson racing kit, along with these other kits provide equivalent airflow to each piston? I know the innovate does but is that a concern or do most of these kits, as mentioned above, cover all that so everything is balanced?
#194 |
Trust me, I'm the Doctor
The JR kit uses the factory intake manifold.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#195 |
Drives: UM86 - 6MT
the JRSC kit is pretty bad ass
#196 |
I Love custom Turbo kits
Drives: Limited BRZ
@1086, there is a new chief in town....
MAP Performance's turbo kit. Stage 1 kit $5250 (The price is absolutely ridiculous for what it includes!!!) http://www.ft86club.com/forums/showp...&postcount=407 AEM Failsafe $300 One gauge pillar pod $50? FBM Oil Cooler $600 BRZEdit Lite $175 Brake pads/fluid/SS lines $300 Turbo blanket $100 Replacement bolt on Crash Beam: $150 http://www.enjukuracing.com/products...Scion-FRS.html Total: $6975 BUT, that includes exhaust AND fuel upgrades AND Catch Can. This is absolutely your best bang for buck.
| FT86 Buyer's Guide! FRS vs. BRZ Differences Detailed! [Video + High Res. Stills] | Rosso_Corsa | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 11-03-2013 04:10 PM |
| First time buyer - help! | chotemaamu | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 02-27-2013 12:21 PM |
| FRS as a Daily Driver? | Pake1 | Scion FR-S / Toyota 86 GT86 General Forum | 104 | 08-15-2012 11:48 PM |
| Will the BRZ be your daily driver | WRXGuy1 | BRZ First-Gen (2012+) — General Topics | 47 | 05-23-2012 12:15 PM |
| The daily driver | KiingDavid | CANADA | 25 | 02-06-2012 01:14 PM |
