#183 | |
The Gunshine State
Drives: '14 BRZ Limited
![]() Lol spam.
![]() Current DD: M235i |
#184 |
Drives: 2017 BRZ PP
Well I 'performed' the spring removal today; very straightforward. A brief drive was all I needed to know this was the right move for me, although perhaps not for everyone. The most noticeable change for me is the clutch pedal pressure is now linear, not weirdly sprung with different loads at different pedal position, which I found disconcerting, and made it tricky to feel the bite point. Combined with drive-by-wire throttle and I was often fluffing my clutch/throttle calibration. Now I can clearly sense through my foot the friction of the discs biting into the flywheel. The bite point has clarity. It's just another layer of tactility and precision that the spring setup couldn't offer.
| The Following User Says Thank You to Zestyfesty For This Useful Post: | jcw99 (09-12-2020) |
#185 | |
| The Following User Says Thank You to humfrz For This Useful Post: | jcw99 (09-12-2020) |
#186 | |
Señor Member
Drives: '17 BRZ PP
#187 |
Drives: 2013 BRZ Limited
Also did this two weeks ago after having my car for a couple months. It took 5 minutes to get the spring out and damn, I was skeptical for the different this would actually make, but it is so much better. Linear and easy to modulate clutch. Yes, slightly heavier when pedal is all the way down, but still lighter than many cars I have owned. I know others have mentioned pedal hang at the top of the throw after doing the mod, but I have no hang, works great. Do recommend.
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
| Tags |
| clutch helper spring, helper spring removal |
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 12:11 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
| Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 | Redline360 | Transmission and Driveline | 2 | 07-30-2012 10:01 AM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
