Old 09-30-2014, 10:32 AM   #183
s2d4
s2d4's Avatar
Originally Posted by Vicsweet View Post
any idea if a +35 17x9 will hit the tie rod at full lock? I'm looking at getting those on my eibach pro springs. thanks
No it won't.
The Following User Says Thank You to s2d4 For This Useful Post:
Vicsweet (09-30-2014)
Old 09-30-2014, 10:39 AM   #184
Vicsweet
Drives: Brz
Thanks @s2d4
Vicsweet is offline   Reply With Quote
Old 10-01-2014, 09:25 AM   #185
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I'm running this exact setup. 17x9 +35 on Pro Kit with Camber bolts.
Fits well doesn't rub on full lock. Very functional setup for daily driving.
Wise is offline   Reply With Quote
Old 10-01-2014, 06:56 PM   #186
Vicsweet
Drives: Brz
Is it necessary to run camber bolts ? @Wise?
Old 10-02-2014, 12:31 AM   #187
Wise
Circle Work Clerk
on +35 it's recommended, otherwise the wheels will poke noticeably.
Wouldn't need them with coilovers as you can just adjust to get camber and the right height.
Old 10-02-2014, 02:32 PM   #188
luuser75
luuser75's Avatar
Drives: M/T Raven FR-S
Nice car man! I'm planning to run the same setup. Any more pics! ?
luuser75 is offline   Reply With Quote
Old 10-02-2014, 11:27 PM   #189
Wise
Circle Work Clerk
Here's couple more.
Old 10-23-2014, 12:26 PM   #190
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Why can't i find a place to buy 17x9 +45 SBC rpf1's? Is it because the finish is limited edition? I checked all the usual places: ft86 factory - enjuku racing - frsport - touge factory - even ebay is having a hard time coming up with results. Seems most are for 5x114.3.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 10-23-2014, 01:44 PM   #191
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Tire Rack has 17x9, +45 in SBC
NLSP is offline   Reply With Quote
The Following User Says Thank You to NLSP For This Useful Post:
Takumi788 (10-23-2014)
Old 12-20-2014, 12:13 PM   #192
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
Originally Posted by Smoke Destructer View Post
Anybody figure out what the wheel is rubbing on at full lock yet? I'm wondering if that can be remedied with careful camber adjustment. Also to the people who are rubbing, are you running any spacers at all? I'm interested to know if something like a 3mm spacer up front fixes the problem.
When I initially installed my coilovers with a 1" drop, I had -2.6 degree of camber on the front left wheel and 0.5 on the right front. I tested for rubbing at full lock and initially rubbed on the tie rod on the front right. I'm guessing this is because of the positive camber. I got the car aligned at -2.0 on both front wheels. I no longer rub on anything at any time.
Mad_Mike is offline   Reply With Quote
Old 12-20-2014, 02:42 PM   #193
s2d4
s2d4's Avatar
Yes, that is because you are on coils with smaller spring ID.
People rubbing them on stock is because they don't have much room for useful camber due to spring perch, which then gets them on the tie rods.
Old 12-20-2014, 06:54 PM   #194
Mad_Mike
Mad_Mike's Avatar
I did not hit the tie rod on stock suspension. The tire was very close to the spring perch.
Old 01-07-2015, 12:57 PM   #195
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
So, is the consensus here that this wheel will fit the stock suspension without rubbing? I want to use these with a 245 tire on the stock suspension. I'll probably get coilovers later, but not until my warranty is up next year.
smg1138 is offline   Reply With Quote
Old 01-07-2015, 01:00 PM   #196
N_I_N
N_I_N's Avatar
Drives: FR-S [Hot Lava]
It WILL fit with a +45 but there will be a very slight rub when you lock the wheel completely to the right. It a metal on metal rub. I run this setup and have only rubbed maybe 3 or 4 times when pulling out of a parking spot.
I also run a 245 Dunlop Direzza and do track days driving pretty hard and have never had the tires or rims rub during normal driving or on track.
N_I_N is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 04:50 PM
Wheel Directory: Enkei Kojin 17x9.0 +45 Clipdat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-02-2016 05:18 PM
