#183 | |
Drives: 2013 BRZ Limited - WRB, MT
#184 |
wat
Drives: a potato.
^ the small cutter pin that holds the shifter and shaft together. Really hoping this isn't a common thing, perhaps just a lazy person putting the car together? hell idk.
the shifter felt real notchy, was hard to get into gear at times. I guess the dust boot held it in place enough, but no doubt there was alot of movement. The shifter is VERY smooth and precise now with a pin put in there. |
#185 | |
#186 |
wat
Drives: a potato.
ah can't remember the size, but it was the smallest one they had available. the hole is very small on the shaft.
#187 |
Great diy. I had things all buttoned up within an hour.
I need and tiny boot since mine got torn ![]() Mine was from a forum member so didnt have the rear bushing. I can completely see why one is needed now. With all the boots off I was rowing through gears and you could see how much the arm that holds the shifter in place moves around. Gonna go with whiteline bushings and positive shift bushing. Sent from a Motorola DynaTAC 8000X |
#188 |
Drives: 2013 Scion FRS firestorm
Installed mine last week. Love the shorter throws and new shifter feel. I did notice the horizontal play and rattle at high rpms. I'll have to make sure everything is tight and try a few things to decrease the rattle when I install the new dust boot.I managed to rip mine like many others.
#189 |
Drives: 2015 WRX
#190 |
Drifter
is the pin mentioned above not a 3/32th pin ?
#191 |
assistance request....
i can't get the cubby tray out, tried everything but can't find the release tabs and/or pull it out with by pulling gently through the usb port hole. mine is different from the op's as i have the remote start button in mine if that makes a difference for removal. |
#192 | |
Drives: Attitude
#193 |
#194 | |
Drives: Attitude
Girly-man arms? Worked fine for me. See below.
#195 |
alright.... quick run to the cleaners to drop off my skirt and it's finally out!
#196 |
Trust me, I'm the Doctor
Three additional items when installing the short shifter in a 10-series (FR-S) or Limited (BRZ):
Item 1: When removing the cubby hole shelf, you have more than just the USB/Aux to unplug. The push-start button has TWO cables connected to it. I found you cannot reach behind and pull out the cubby shelf. Instead, pull UP and out, and the top clips will release and then the you can get the cubby shelf out, and the push-start button's connectors will be accessible and you can remove them. Item 2: when removing the entire center console, you've got the heated seat connector controls to remove as well, not just the 12V. This seems obvious but if you're following the DIY step by step somewhat blindly, it's easy to overlook till your realize "Oh, I've still got 2 cables connected!" Item 3: The black washer that's between the shifter rod and the cotter pin doesn't seem to be necessary if you lose it. B/c I did. I pushed the connecting rod out and heard something fall, but I couldn't see anything on the ground, though it sounded like it hit plastic instead (but it wasn't in the cabin, or on some of the stuff running underneath the transmission shifter linkage). Still, on reassembly, I just went without it. Doesn't seem to hurt anything. It was such a thin washer to begin with anyway and the bushing material that surrounds the connecting rod in the kartboy shifter is delrin and not soft, compliant rubber. So, the washer seems to be a bit superfluous. If you didn't lose it, by all means reuse it, but don't worry if you did lose it. (correct me if I'm wrong here)
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
| STI Short Shifter Kit | Hanakuso | Engine, Exhaust, Transmission | 37 | 01-18-2016 09:19 PM |
| Kartboy Short Throw Shifter!! | RallySport Direct | Transmission and Driveline | 16 | 04-18-2013 02:18 PM |
| Kartboy Short Throw Shifter!! | RallySport Direct | Announcements, Contests, Giveaways | 34 | 03-18-2013 03:18 PM |
