Old 10-13-2014, 08:26 PM   #183
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Originally Posted by F1point4 View Post
FYI there is a 652 part number now. I've been using a pair in my car for several thousand miles and a pair of track events. Wrapped mine in gold tape.
http://www.ft86club.com/forums/showp...0&postcount=78
I ordered two from an Internet parts distributor and received 650's I am using heat tape as well, hoping they will survive a while longer at the track.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 10-14-2014, 10:16 AM   #184
Deep Six
Deep Six's Avatar
Anyone care to tell me how you removed the 10mm lower ECU bracket bolt ?
I can't get a socket on it to save my life.
NM Was going after the wrong bolt.....gonna be a bitch getting some of these bolts started back in, not much room to work with for sure.
[SIGPIC][/SIGPIC]
Old 10-14-2014, 12:59 PM   #185
Deep Six
Deep Six's Avatar
Failing coil replaced, car runs up to redline with no issues anymore!
Wanted to share some additional perspective on this:
Cel started coming on more frequently during daily driving, 6000 rpm would activate it.
Gas mileage had dropped to below 23 mpg average
Car would hesitate and sputter (stalled once) as you pulled to a stop and seemed sluggish in general.
Strange fuel smell in the cabin especially with the fan on high. Possibly unburned fuel??
During the couple sessions that I ran with the cel there was a profound change in the traction / stability control. I had turned it off with the 5 second switch but it was really nuts whenever I had high rpm high g load corners. Motor cut and rear brakes grabbed to the extent that I nearly lost it.
With the new coil, all of these street issues are gone and it feels like I am running the E85 tune compared to how the car was running up till now. The power difference is enough to tell the difference. Even the exhaust note standing outside the car at idle sounds different.
It would appear that when a coil gets this bad, there are multiple symptoms present even if the cel is intermittent.
[SIGPIC][/SIGPIC]
The Following User Says Thank You to Deep Six For This Useful Post:
zombieite (04-23-2016)
Old 10-16-2014, 12:29 PM   #186
Teknian_Culprate13
Teknian_Culprate13's Avatar
Drives: Scion FR-S
I've got the same code, cylinder 1 coil is out. My question is would a Perrin crank pulley woud my warrentee for that. I'm afraid the dealership will say it's the reason for misfire, only other mod is airfter and invidia catback?
Teknian_Culprate13 is offline   Reply With Quote
Old 10-16-2014, 03:46 PM   #187
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
They SHOULDN'T but some dealers are ass holes, some are cool. Im lucky to have two really good Subaru dealers within 30 minutes of me.
If you're worried, change it out first.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 11-01-2014, 03:19 AM   #188
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by romin View Post
Did you notice any gains over stock??
FRS Justin is offline   Reply With Quote
Old 11-05-2014, 09:40 PM   #189
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
No power improvement but the engine seemed to run smoother.
romin is offline   Reply With Quote
Old 11-14-2014, 02:37 PM   #190
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by ATL BRZ View Post
I was thinking about a smaller bolt-on shield that doesnt focus too much on covering the exhaust below, but more directly covering up the coils and reflecting the heat that rises up off the exhaust away from them, but not trapping it.
Brace yourselves: shitty mspaint inbound
or
Something like the above. Could have a hole drilled where the coil bolts in so you install the shield with the same bolts.
On an interesting note, after I installed my Nameless headers (which are ceramic coated) and I haven't seen mine fail again (knock on wood).
raul is offline   Reply With Quote
Old 11-14-2014, 02:38 PM   #191
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I'm planning on pulling my header and OP in my time off next month and having them ceramic coated as well. Couldn't hurt to lower engine bay temps significantly.
Old 11-14-2014, 03:17 PM   #192
DarkSunrise
DarkSunrise's Avatar
Thanks for the update. Makes me feel better about having my JDL header thermal coated
2022 BRZ Build
2013 FR-S Build
Old 12-01-2014, 12:06 PM   #193
ATL BRZ
ATL BRZ's Avatar
Since it hasn't been fully posted yet for reference, the newest part number for the coils is 22433AA652
@smbstyle welcome to the coil killers club
Old 12-01-2014, 12:18 PM   #194
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Thanks.
After almost 8k track miles without a hiccup, something was bound to happen! Only downside is it's a P0352 (drivers side rear), which looks to be the hardest place to reach. shit.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 12-01-2014, 04:38 PM   #195
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Originally Posted by smbstyle View Post
Thanks.
I've done it.
At the track.
On a hot engine.
I unbolted the shield for the high pressure lines and moved it out of the way a little bit. It shouldn't be too bad on a cool engine.
celica73 is offline   Reply With Quote
Old 12-01-2014, 05:53 PM   #196
Lawn_Mower
Lawn_Mower's Avatar
Drives: GTI, BRZ
I've killed a coil on the track too, it was replaced under warranty, had no issue at the next event, although it was significantly cooler outside.
Lawn_Mower is offline   Reply With Quote
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
