10-20-2015, 09:09 AM | #183 |
@tracerit I decided to crack it open again yesterday - there's no way to fully clear it, always a bit touch but you can tip it the filter upward a bit to minimize contact with that hump.
10-20-2015, 04:43 PM | #184 | |
Drives: '13 SSM BRZ Limited 6MT
The Following User Says Thank You to tracerit For This Useful Post: | 1Cor10:23 (10-20-2015) |
11-09-2015, 01:39 PM | #185 |
Drives: 2015 BRZ Series Blue WRB
Im considering buying this cold air intake from perrin. Does the bumper needs to be remove in order to clean the intake every 8-10k miles?
11-09-2015, 01:49 PM | #186 |
@Jfheisenberg yes, this is the best way to service. You can probably get away with pulling back the top of the bumper but you risk misalignment when reinstalling plus tearing of foam.
Sent from my SM-N920W8 using Tapatalk
12-27-2015, 04:19 AM | #187 | |
Drives: 2013 Subaru BRZ Limited (CBS)
Is that a shared common underground garage? Like in an apartment or condo building? If so, it looks like the board allows tenants/owners to keep stuff in their parking spots? AND YOU HAVE A LIFT IN THERE? AND YOU CAN WORK ON YOUR CAR IN THERE?! Do you keep your tools in your spot? If so, aren't you afraid of theft? So many questions!
2006 Lotus Exige Aspen White (Supercharged Honda K24A2 swapped.)
1994 Autozam AZ-1 Mazdaspeed 1996 Mazda Miata (Track car.) 2007 Suzuki SV650 (Track bike.) |
12-30-2015, 02:10 AM | #188 | |
Drives: 2013 Subaru BRZ MT Limited
Silver 2006 Toyota Tacoma Double Cab 4WD Longbed, Name: Loki - God of Mischief and Chaos
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
03-28-2016, 04:37 AM | #189 |
I was strolling around ft86speedfactory and noticed that the regular Perrin CAI is now CARB APPROVED!!!!! Now I'm feeling pretty bad about having just purchased the HKS intake duct just last month :/
http://perrinperformance.com/i-13324...-fr-s-brz.html @PERRIN_Chris are all regular Perrin CAI's CARB approved retroactively or will there be a new batch being released? |
03-28-2016, 02:49 PM | #190 |
Drives: 2014 Subaru BRZ
That's right, they're CARB approved now! This also applies to the intakes we've sold in the past since they are the same intake. If anyone needs a CARB sticker, send me a PM with your address, thanks!
05-02-2016, 04:56 PM | #191 |
Hey guys, i just installed my perrin cold air intake. I actually forgot to add the air divider, is that necessary? i'll be taking the bumper out again to align it better so im just wondering if it should add the air divider or not.. please advise.!
@PERRIN_Chris |
05-02-2016, 05:02 PM | #192 |
You mean you forgot to add the two brackets to push the bracket away from the filter? I'd take the bumper off to add them, it could put pressure on the filter and maybe cause it to break eventually. Remember not to overtighten the clamp going to the filter! I see that happen a lot and the rubber on the filter breaks.
05-02-2016, 05:57 PM | #193 | |
from what i read that panel is called air divider, not sure if it needs to be there or not. |
05-02-2016, 06:35 PM | #194 |
OK got it, you'll want to put that diverter back for sure, it could make the MAF get some weird readings. At least you'll get some practice getting the bumper off!
05-02-2016, 06:47 PM | #195 |
ok thanks. Yeah i havent got any cel codes yet. Oh and yes , the bumper is a pain to take out, well taking the side markers makes it complicated
05-14-2016, 04:43 PM | #196 | |
Drives: 2015 Silver BRZ
For folks that report smoother takeoff from rest, is that likely due to better throttle response as Perrin dyno does not seem to show much low rpm torque improvement? Thanks Len |
Similar Threads | ||||
PERRIN Silicone Intake Duct Review | JoeBoxer | Engine, Exhaust, Transmission | 287 | 01-24-2018 10:01 PM |
Perrin Catback Exhaust Installation and Review! | Sony | Engine, Exhaust, Transmission | 316 | 01-24-2016 01:01 PM |
cold air intake vs short ram intake ? | tnt | Engine, Exhaust, Transmission | 5 | 02-02-2014 12:43 AM |
cold air intake? | carbonBLUE | Engine, Exhaust, Transmission | 72 | 09-30-2013 12:56 PM |
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley | draggin_az | Engine, Exhaust, Transmission | 21 | 04-29-2013 04:58 PM |
