Old 01-10-2012, 03:05 PM   #183
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by Homemade WRX View Post
Well condsidering my rods are VAR anyway, that wouldn't be a cost increase. I am vaguely familiar with 4340M but if I recall it actually doesn't contain any elements different from 4340 but lacks a few that 4340 has. I believe it has a higher molydenum percentage as well. So, I'd guess a harder material = more machine cost.
Sorry, I don't really know your answer off the cuff. I guess I'm off to see what I can find on it's properties versus 4340 and 300M. Where I imagine it will fall in cost. But if that's the issue, the $160 difference between 4340 and 300M, I don't think there will be market there...from a part making perspective.
4340M=300M same material. 4340M and 4340 have similar make up but are different enough. M has less sulfur, and some vanadium (off the top of my head) plus others, different % of the stuff that is the same.
Because titanium.
Old 01-10-2012, 04:20 PM   #184
dbagdbag
Drives: 2013 Mustang GT
i wish i knew as much as some of you do, i feel like an idiot reading the last few pages.
hopefully this will be a good car for me to learn with, I want to go beyond my intake and exhaust days when I thought I knew a lot about cars.
carry on.
dbagdbag is offline   Reply With Quote
Old 01-10-2012, 11:26 PM   #185
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
^^^no worries, I do enjoy sharing what I know about engines, kinematics, etc...you'll see many such thread on NASIOC where I try to take an engineering view and put them into Layman's terms...though I often screw those up too
I plan to do the same here to clarify what I, and others, are rambling about. It's all part of explaining why I make the changes or decisions that I do
Homemade WRX is offline   Reply With Quote
Old 01-11-2012, 01:59 AM   #186
serialk11r
Drives: '06 AM V8V Coupe
Hey uh, typically for higher rpm people switch the valve springs right? But a lighter valve instead would reduce float with less friction...are titanium valves very cost prohibitive? Seems strange, since valves are relatively small. What is the lightest type of valve? Hollow stem titanium?
Old 01-11-2012, 08:49 AM   #187
Homemade WRX
Ti valves are VERY expensive and have a short life. The price has scared even my most loaded customers
This has come about as I've seemed to reach the limit of off the shelf valve springs. They are now a consumable with standard stainless and inconel valves. I'm working with a few suppliers with this so that I can keep pushing the package towards 11k.
Old 01-11-2012, 09:47 AM   #188
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Ti valves ... have a short life.
They don't seem to have any problems in OEM motorcycle applications. I'm curious what issues you've run into that limit their longevity. Or is it just a matter of heat retention in turbocharged applications?
old greg is offline   Reply With Quote
Old 01-11-2012, 10:12 AM   #189
Levi
Drives: Toyota
11k RPM or 11k $ ?
Levi is offline   Reply With Quote
Old 01-11-2012, 11:27 AM   #190
Homemade WRX
Larger valve size and RPM. The heat will obviously be a factor as the material will soften especially as titanium has poor thermal conductivity. Galling and necking becomes an issue from my 'no hands on' understanding. You need soft seats, like cast iron or beryllium copper.
Coatings and alloys have come a long way from where they first started. Del-West and Xceldyne are two of your larger suppliers if you're looking to spend about $250 per valve. Then don't forget to by the correct guides and seats. Then get your coatings done and have the machining done.
From my understanding, Gibbs racing has in fact gone away from them in Super Speedway engines.
From what I know of it, the failure of a ti valve is usually in the stem. Now you can see the hi-end they're are friction welding various metals together. To achieve a stem portion that isn't so suscuptable to galling and can better handle the load (also you want good thermal conductivity too) and then a low density head material that can take the heat from combustion. Oh and not to forget a hardened tip too.
Originally Posted by Levi View Post
11k RPM or 11k $ ?
11k RPM
Old 01-11-2012, 05:22 PM   #191
Levi
Drives: Toyota
11k RPM
If you'll be able to make the engine rev till 11K RPM I'll take buy it ofr 11K €!
Old 01-11-2012, 06:02 PM   #192
serialk11r
DANG okay that is expensive. How about hollow stem stainless? 20% weight reduction is like...10% more revs
Old 01-12-2012, 08:18 AM   #193
Homemade WRX
Just a tip, my international custers, largely Kiwis and Aussies, watch the exchange rate as a time to buy rebuild components or even when to finally make a purchase. When you're talking thousands on an shortblock or engine, every little bit helps.
I'll see what it looks like. I really need to spend time with the head on flow bench to see if large valves are even necessary and to see what flow these heads can actually support. Lighter is better regardless but I've been fine sending EJ's to 9K+ with OTS springs.
Just because the bottom end can take 10k doesn't mean the head will support the power
I'll be working with a supplier on some ovate wire, beehive springs for the FA engine. The cam stock is going to be pricey part. Speaking of which, I've seen people comment on hear that the car was coming with AVLS, which I can't find anything supporting this. I'm fairly sure it is simply a dual AVCS head.
Regardless, I am VERY anxious to get my hands on the FA platform!! I'm thinking 2.4L without the crazy high rev's will be the ticket. You know, something mild like 8500...but really I'll put redlines where it's done making power.
Old 01-12-2012, 12:36 PM   #194
STInk
Drives: 04 STI
Unfortunately these modern engines are made so much better than last decade, but based on reviews it is clear the motor runs out of breath up top. The exhaust is made to hit Federal noise targets, and that short-primary header is designed to make midrange torque; along with a cam that is designed to reduce emissions. I'd bet money (and I will!) that power can be extended upward, but it won't be cheap, and it won't be more than 10% tops.
Another angle to think about - Subaru designed a brand new engine... do you really think they gave us "all" of it right from the start? The Audi/VW 2.0t embarrassed the big brother V6, so the factory detuned it. Every couple years when they needed to refresh the line they turned up the HP wick via software. This Subaru motor will have some give, and they have some future bolt-ons in mind - you can bet on it.
Some no-brainer things we can do to increase power to the wheels: lighter pulleys, lighter flywheel, carbon driveshaft. Coat the inside of the exhaust manifold and midpipe area with Jethot 2000. I'm guessing gasket-matching will be near perfect from the factory. Forged wheels, lighter rotors and light tires will be a must! God this is going to be so fun!!!
STInk is offline   Reply With Quote
Old 01-12-2012, 12:48 PM   #195
serialk11r
Err run out of breath up top? But the torque peak is confirmed at 6600...that doesn't sound like midrange to me lol. The pictures released strongly suggest it is just a cam phasing system, no lift. FB20 has no lift, and the width of the engine is already pushing it.
@HomemadeWRX you say 2.4L? O_O Increasing bore? The engine already runs right up to the wheel wells as is.
Old 01-12-2012, 01:10 PM   #196
Calum
That Guy
Drives: 2013 asphalt FRS MT
Perfect, when you get the package done I'll be waiting.
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
Mods? Bruninho8 Scion FR-S / Toyota 86 GT86 General Forum 3 12-06-2011 06:11 PM
Estimated Price.. SLeRoux92 Scion FR-S / Toyota 86 GT86 General Forum 44 05-25-2011 11:58 AM
