#183 |
LMGTFY
Drives: 13 FRS, 91 Miata
Sounds to me like you should just stick to the hair dresser mobile.
#184 |
Drives: Miatas of Various Kinds
If the standard means of gaining adjustability is camber bolts in the front and LCAs in the rear, what features should I look for in each? It doesn't seem like the camber bolts vary much from one manufacturer to another; they are just bolts, so there's not that much to them. There seem to be quite a variety of LCAs, though.
DD & STR: 2009 Miata. DD & HPDE: 1995 Miata. Sold: 2004 Mazdaspeed Miata, 1991 CRX, 1977 280Z.
#185 | |
Drives: Legacy GT
Impressive that the miata allows that much adjustment stock. That is really not common.
Also, if you really are concerned with getting the alignment ride for track use you need a tire temp probe. Quote:
Same goes for some of the rear LCAs. Take a look at SPC's arms, and then superpro and whiteline. The color is different and that's about it. So anyway, for an inexpensive set of arms go with spc, whiteline, or superpro. Then for a fancy arm with turnbuckle style adjustment and an inner rod end the cusco and velox/verus arms are both pretty nice. Cheaper versions with a budget exposed rod end are not a good idea IMO. |
#186 | ||
Drives: '23 BRZ
For me, for street and track, if I can get -2 all around on the BRZ I'll be OK with that. Would like to get -2.5 front, but not going to coilovers on it any time soon... Will see what I can get with camber bolts and bringing it down 1". For me, street/track/time trials, I dont think adjustability beyond that is imperative, and I'll just run it maxed out all the time. And tune balance with sway bars if necessary. |
#187 |
It seems that best angles for this car for Street use are: camber 1.5 degrees for front and rear and 0 toe for front. But which toe for rear? Thanks!
#188 |
Drives: 2015 BRZ
That should be fine, but ideally you want more camber in front and a little less in the back. You want 1/16 toe-in rear.
| The Following User Says Thank You to Vital For This Useful Post: | gpvecchi (04-12-2018) |
#189 | |
Only users lose drugs.
Drives: All the time
https://www.rockauto.com/en/moreinfo...504006&jsn=317
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following User Says Thank You to venturaII For This Useful Post: | new2subaru (04-12-2018) |
#190 |
Drives: 2017 BRZ Limited Auto
This past weekend I did the Swift Sport Springs (BRZ) and SPC lower 14mm camber bolts and swapped the upper 16mm with the lower 14mm. We were using a Harbor Freight angle gauge to guess with.
Have appointment with alignment shop to do -2.0 front, -1.5 or whatever fixed stock is, as per this thread 0 toe front and rear. Unaligned it feels really good on the blizzack snows, yep still snows here in Indiana in late april, Uhg. When it stops snowing and they start fixing some of these craters in the road. I can swap on my New 17x8.25 XXR with 245/40/17 hankook V2. Going to be a real fun DD |
#191 |
Drives: 2014 GT86
IndyBRZed: If snow performance matters and alignment is mentioned, then better not go to camber more then -1.5 or even -1. With very limited grip available on snow/ice, grip/traction is lost way before there is lot of sidewall flex that might be needed to compensate with static camber to restore contact patch & grip, so lesser camber angles will provide flatter/better contact/grip on snow/ice. -2 and higher .. sounds more for performance alignment on dry tarmac. (stock alignment btw is 0 camber front, -1.2 rear)
#192 |
Drives: 2014 Subaru BRZ Limited MTblue
Just read all of this. many thank yous to all who posted!
This is my 3rd year tracking my '14 BRZ. I've maxed out the stock suspension and my tires are pleading for an upgrade!! (alignment w/ camber bolts: camber: -1.25° front, -1.5° rear, toe: front 1/32" out, each, rear 1/32" in, each) I'm reading through all I can to decide. A well known BRZ/FRS racer has suggested Tein Flex A's for track and street. I intend to do rear LCA's. I will lower no more than 1". Will I need to replace rear toe links at 1" lower? |
#193 | |
Alignment specs will depend on spring rates and tire choice. You will want more camber than that if you track your car. - Andrew |
#194 | |
Drives: '23 BRZ
Rear LCAs, why does everybody think they need these? You don't. Front camber plates would be a good move though.
#195 |
Drives: 2014 GT86
Because Rear LCAs is cheapest way to add camber adjustment in rear with sufficient range (i don't count "unofficial" H&R camberbolt usage in rear as much of an option, as due small range they can do only for evening out. Nor do i count as "cheaper" eccentric whiteline bushings, as installing them and/or adjusting with them is PITA and savings on a bit smaller price go down the drain paid on alignment tech time/work)?
Or you wanted arguing that getting alignment in rear or upping camber in rear aswell for track use is not needed? Sure not needed, if one doesn't want to get max grip and even tire wear. |
| The Following User Says Thank You to churchx For This Useful Post: | finch1750 (06-15-2018) |
#196 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I can easily achieve -3 front with camber bolts and a slotted strut on my set-up (and never had slippage in 100k+ miles between slotted and non-slotted struts). And I don't have to worry about bearings or whatever else up top needing to be serviced while enjoying a softer ride with my OEM top hats. But camber plates may be best for some people. Suspension is a very individually defined set-up based on goals and driver preference to get the adjustability needed for the intended purpose while keeping/sacrificing comfort level. |
| Alignment Specs? | 86_ZN6 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 06-10-2013 06:30 PM |
| Anyone do their own alignment? | TemeCal | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 11-09-2012 11:36 PM |
| Another crash bolts alignment thread | jeebus | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 10-28-2012 12:29 AM |
| DIY alignment | dsgerbc | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-17-2012 11:41 AM |
| where to get alignment? | FML | Hawaii | 2 | 08-08-2012 01:36 AM |
