| AUSTRALIA Australia and New Zealand |
#183 | |
Drives: WR BLUE MICA
http://www.alpine.com.au/showItem.php?item_id=162 |
#184 |
Drives: toyota
Since deadening improves road noise as well, I am leaning towards it more. It's not cheap if you do full car right, but if I only do doors (which I hope is enough to improve sound quality), will it still cost more than 500?
#185 |
Focal bam is like top of the range. Dynamat is a bit cheaper.
Depends on where you go. Some will only sound deadening around the speakers. Other will do the whole doors. Example of focal bam. Done properly. http://www.caraudio.com.au/forums/in...the-brz-or-86/ |
#186 | |
Potato Farmer
Drives: #SLOBRZ
That is over done. I used 1 x Dynamat door pack over 2 cars, one of them was my Aust championship winning SQ car.. The other i was told i had too much midbass in at the only comp i put it in, the door was solid. it's all about correct placement, smothering the door like that is just a waste of money and adding unessasary weight.
Something something butter..
www.vic86brzclub.com |
| The Following User Says Thank You to fuddbutter For This Useful Post: | ZZT86 (09-11-2013) |
#187 |
So just around the speakers is enough?
#188 |
Potato Farmer
Drives: #SLOBRZ
I cut the SD into strips and squares, then i go over the door skin knocking and looking for any vibration, then when i do, whack on a piece.
#189 |
Sound System BRZ
Alpine W910R head unit
Alpine PXE 660 sound pro Alpine 4 x 110 watts RMS @ 4 ohms Alpine mono 550 watts RMS @ 4 ohms Alpine 5 1/4 type R in rear Hertz ESK 163L.5 front Focal 10" sub x 2 boot Dyna Mat Extreme some pics during build All the connections are quick release ,takes me 30 seconds to remove both subs and amp panel .,no drilling in body , |
#190 |
Very nice jack
#191 |
A few questions.
How is the compatibility of the DDX630WBT with Apple iOS 7 and Android 4.4 Kitkat? I found out that other than the Subaru BRZ the Toyota 200mm wide 2DIN standard is also used by the Third generation (2007–2011; GE, GH, GR, GV) Subaru Impreza and Third generation (SH, 2008–2013) Subaru Forester. I was told by a dealer/installer that the steering wheel controls of the Subarus can be used by the Kenwood. There is no need for splicing. |
#192 |
Drives: Storm Black Toyota 86 GTS
Does the stock headunit out of a 86 GTS have rca outputs?
#193 |
Drives: stock 86 GTS
personally sad to see you didn't go boxed, but looks trick - never enough bass right!!
#194 |
Drives: BR86
| purchasing area 86 stuff | pkptd447 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-15-2014 03:09 PM |
| Help Me Get This Stuff OFF!!! | wootwoot | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 7 | 09-07-2012 11:38 AM |
| Any more cool stuff? | Davyator | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 05-24-2012 04:28 PM |
| More HKS stuff! | uspspro | Engine, Exhaust, Transmission | 0 | 04-25-2012 01:27 PM |
| Dimman's technical stuff. | Dimman | Other Vehicles & General Automotive Discussions | 74 | 10-17-2011 02:15 PM |
