Old 04-06-2020, 01:24 AM   #183
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Originally Posted by TRS View Post
BTW: I am following your Youtube account and were watching every single fr-s video you posted in order to get an idea about the Sound level. Unfortunately there are not many clips Filmed from outside.
My Main concern is that the exhaust gets too loud, at least for german Standards. Can you give me an idea how the noise level is, lets say compared to a bone stock Mk5 Camaro? I also decided to use the Perrin 3" resonated, as well the CX headers. There will be a little extra noise reduction due too the converters I believe. I assume you dont use any, correct?
Unfortunately I dont have much video from outside of the car.
I am not running converters and my engine is far from stock so it will sound quite different, but it is slightly louder than a SS Camaro when driving casually. Running converters on it will help significantly.
spitsnaugle is offline   Reply With Quote
The Following User Says Thank You to spitsnaugle For This Useful Post:
TRS (04-08-2020)
Old 04-08-2020, 05:06 PM   #184
Chickeneatman
Drives: 2013 FR-S Ultramarine
Originally Posted by spitsnaugle View Post
Welding in the bumper
This looks really nice. I will plan on doing this with my swap. It looks like that intake uses the LS3 MAF. Is that correct? Do you plan on swapping from the LS2 MAF to LS3 MAF?
Chickeneatman is offline   Reply With Quote
Old 04-09-2020, 02:34 PM   #185
spitsnaugle
I am.
Though for the week its running without the MAF connected, its running MAP only (luckily its tuned for both situations). It is a connector change and changing the order of the pins in the connector. Then a minor voltage change/remap with HPtuners.
Old 04-10-2020, 02:52 PM   #186
Chickeneatman
I am.
Whats the reasoning for keeping the MAF around if you can run SD?
Old 04-10-2020, 04:12 PM   #187
spitsnaugle
low speed accuracy and air intake temps.
Old 04-18-2020, 03:24 AM   #188
wtout86
Drives: Whitout FR-S 6MT
Awesome build! Sorry non car related, but whats this I see in the background? Is that a 9r? Or a Ripper maybe?
wtout86 is offline   Reply With Quote
Old 04-19-2020, 02:06 PM   #189
spitsnaugle
Good eye, its a Ripper! Theres also a P&H Scorpio MKII outside.
They're both my friends but I'm looking to pick up one here in the next couple weeks.
Old 04-21-2020, 02:27 PM   #190
spitsnaugle
An updated engine bay photo with new intake below:
New dyno run put it 453hp @6100rpm 440lb ft torque at 4300rpm.
13HP increase over the previous intake with its relatively long/gentle sweeping 90° right off the throttle body.
Intake temps have dropped SIGNIFICANTLY over the filter in the engine bay.
The Following 5 Users Say Thank You to spitsnaugle For This Useful Post:
BigTuna (04-30-2020), gtpvette (04-21-2020), mrg666 (04-22-2020), TRS (04-26-2020), Zer0 (04-26-2020)
Old 06-18-2020, 03:50 PM   #191
spitsnaugle
Some updates:
The car is in the body shop right now, I had some minor repair work done to fix a dent and replace the bumper middle of last year after some damage from a trailer. Unfortunately the shop didnt do the job up to spec, so its at another shop now getting redone.
Old 06-19-2020, 01:27 PM   #192
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Maybe I missed it. Did you ever determine the cause of the engine failure? Fluke? Oil starvation? Knock event? Bad bearing?
If so, did you do anything new to mitigate it from reoccurring?
Old 06-19-2020, 01:39 PM   #193
spitsnaugle
High G-force cornering caused oil starvation.
Steps to prevent:
  • Melling 10295 high pressure oil pump
  • ImprovedRacing Baffle insert
  • Oil Cooler
  • Oil Pressure/Temp Gauges
  • Accusump Installed
The Following 2 Users Say Thank You to spitsnaugle For This Useful Post:
GrabTheWheel (06-20-2020), Irace86.2.0 (06-19-2020)
Old 06-20-2020, 01:07 PM   #194
GrabTheWheel
Drives: 16' BRZ
Steps to prevent:
  • Oil Cooler
  • Accusump (yet to install, trying to find space)
I hope this is enough for you! I had an almost identical setup minus the accusump. I know some people swear by them.
GrabTheWheel is offline   Reply With Quote
Old 06-20-2020, 02:09 PM   #195
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
ummm...
Did you miss the fa20 torque dip or something??? LOL just messing with ya...
JAden
Jaden is offline   Reply With Quote
The Following User Says Thank You to Jaden For This Useful Post:
BigTuna (06-22-2020)
Old 07-10-2020, 06:02 PM   #196
TRS
TRS's Avatar
Drives: 2013' Toyota 86 (EU spec)
Hi @spitsnaugle, I need your assistance. �� I'm expiriencing some serious heat issues when driving with AC at high outside temps, especialy when driving slow.
Load of the engine has an effect, but minor compared to switching AC on/off. I know you modified your hood. My issue here is that the mod you did would be massively illegal in Germany. As well it would not suit my design concept for the car.
So what are your expiriences with that? Did you try different radiators/fans etc and maybe collected some data?
I'm running the skunk2 ultra which is pretty much the biggest rad I could imagine to fit the frs. I know that surface area is much more decisive than size, but I dont see a very big difference betwenn the skunk ultra and EG the Jackson racing.
Some thought? BTW, are you running a under flor liner?
TRS is offline   Reply With Quote
cx racing, ls swap, ls2, pure automotive
2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP ILLSMOQ Engine Swaps 172 11-24-2022 08:01 PM
LS2 swap by KAB Customs with Pure Automotive Motec Sportsguy83 Engine Swaps 254 10-17-2018 01:45 PM
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 12:10 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 05:21 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 02:03 AM
