Old 03-26-2020, 07:06 PM   #183
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
ACE CS400 installed!!!
Paired with the HKS R-Spec front pipe, oem midpipe, and TRD High Response Muffler Ver. R.
I got it installed. Took me about 5 hours because I'm slow and it was probably the most difficult header to install. I tried to snake the overpipe portion in like I did with my AVO, but because of the merge collection, it would not budge. So I unbolted the engine and jacked it up. That was probably the most surprisingly easy thing to do! The bolts came undone with no problem at all, and lifting the motor 1/4 of an inch to slip the overpipe portion in was a breeze.
Now... the annoying part. The overpipe! That piece of shit is by far the most difficult part I've ever had to install. The three bolts had to screw in and were at funky angles. The 2 were pretty easy, but the top right bolt can kiss my whole ass. That sucker was so hard to thread and then tighten I almost gave up. I had to remove a portion of the plastic paneling in the wheel well to get my socket lined up. Then, the overpipe-to-front pipe part had threading too! I've never seen that before. Once again, that was also a nightmare to line up, thread, and torque.
I plan to do some data logging tonight and send it off to Zach at CSG and let him do his magic. I'll be curious to see how it stacks up against the HKS header it's replacing and the Nameless/Cosworth I had on both my FR-S and BRZ. If all goes well, I will be the last mod I do for a long, long time. Hopefully this weekend or next week I can get some sound clips of the set up.
MS, CSCS, TSAC-F, CPT
Old 03-27-2020, 01:39 AM   #184
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Keep us posted.
Old 04-05-2020, 10:36 AM   #185
weederr33
weederr33's Avatar
ACE CS400 Review
My review did not post. Well the short is this: ACE CS400> Cosworth 0.3 manifold> HKS EL header.
I took the car for a nice run down and wow does it have power all around! Each time I came out of a corner, there was power on tap. It feels more lively than the HKS did. While raspy, it was not as raspy as the Cosworth. The tuning by Matt@Cosworth was damn good out of the box. Zach@CSG did excellent work tuning in the car on both my HKS and ACE headers. I also did notice one thing. I have the beatrush under panel, and my CS400 DOES tap it every so slightly, but only from flexing of the panel. I only noticed this because when I went to tighten the bolts down after heat cycling, there was some coating that was knocked off. I could not hear it, nor would I have known. So I'm not going to worry.
Last edited by weederr33; 04-06-2020 at 09:37 AM. Reason: My review did not post O_o
Old 04-15-2020, 06:44 AM   #186
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
In which area is the ACE CS400 better? Mid rev range or top end?
Old 04-15-2020, 09:24 AM   #187
weederr33
weederr33's Avatar
Mid range. But it has plenty of top end too.
Old 04-16-2020, 03:32 PM   #188
weederr33
weederr33's Avatar
Got a sound clip of the new exhaust set up! @Tcoat
Old 04-16-2020, 03:38 PM   #189
Sounds much like the standard TRD exhaust with maybe a tad more rasp and volume. Looks great too!
Old 04-16-2020, 03:40 PM   #190
weederr33
weederr33's Avatar
The rasp is the headers for certain. They are very raspy
Old 04-16-2020, 03:45 PM   #191
Ahhh yes that makes sense. So with stock it is probably very close to the standard TRD.
Old 04-17-2020, 03:06 PM   #192
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
@weedere33 or anybody else. With regard to the oil cooler, the cusco kit is, to me, outrageously priced. Are the radiator hose adapters available separately? I have everything else.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 04-17-2020, 07:23 PM   #193
weederr33
weederr33's Avatar
It is very over priced! I'm sure you could contact Cusco directly and ask for replacement adapters. Otherwise, you may have to see if someone can CNC a pair for you.
Old 04-17-2020, 10:13 PM   #194
Capt Spaulding
Persona Non Grata
Actually, you can find them a number of places. I ordered a pair of 40mm anodized aluminum water temp sensor adapters for just under $10 each.
I'm looking forward to your report on how well the set up works.
thanks for the help.
Old 04-18-2020, 03:28 AM   #195
tweedbean
tweedbean's Avatar
Drives: White GT86
Love following the progress on this, such a great colour
tweedbean is offline   Reply With Quote
Old 04-18-2020, 11:52 AM   #196
mrg666
pessimistic skeptic
mrg666's Avatar
So I bought the Cusco Oil Cooler a few months back but had not had time to install it and all of the time consuming aspects of burping the coolant.
I don't foresee it being any better than the throttle body method, but hey, I'm stuck at home, why not do it. Should be putting the ACE CS400 on later in the week!
Those T connectors do not give me any confidence that there will be sufficient coolant flow through the cooler. Do you see any temperature difference between the coolant inlet and outlet of the coil?
Weederr's Cosworth Supercharged Raven weederr33 Member's Car Journals 232 03-25-2024 10:09 PM
FS: DRL Mod for Monogram/10-Series/Release Series 1.0 leoh007 Audio/Visual, Electronics, Infotainment, NAV 0 05-12-2015 12:14 PM
10 Series / Series.Blue rear view mirror 86-ADL Cosmetic Modification (Interior/Exterior/Lighting) 4 11-16-2014 07:32 PM
BRZ series.blue/FRS Series 1.0 photos Johnny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-25-2014 11:23 PM
