Old 12-28-2016, 02:46 AM   #183
Irace86
Drives: BRZ + Ducati M796
Originally Posted by johan View Post
A tune from Harrop for non-US fuels would still be useful as a starting point for MAF scaling and cam angles. The MAF scaling is particularly important since the kit replaces the MAF housing.
@HarropOz is there a way for end users to get a base cal from you for ECUTek? Knowing that it won't be usable out of the box, but still important as inspiration for a tune.
I ordered my kit from Neal on the 19th, and waiting patiently for delivery (honestly, I am), but trying to work out the details regarding tune. I will be doing install myself, my 2017 BRZ is already tuned on ECUTek, and I will need to be able to fire the car up and drive it for a couple hours to get to my buddies dyno so we can properly tune it.
Having something to go off of for the MAF will be paramount to the success of my install. Cruising down the freeway for two hours in limp mode is unappealing.
They already have a US spec tune. It's just with CARB getting tested. Doubt they will release it before everthing gets approved, and they might not release theirs like Edelbrock did. With that said, could the Edlebrock tune work as a get-you-down-the-road tune?
Irace86 is offline   Reply With Quote
Old 12-28-2016, 01:39 PM   #184
johan
Drives: '14 981CS, '99 NB1
Thanks. Kyle actually mentioned the same thing in his build thread - about using the Edelbrock tune. I guess I'll see how things play out. Even if Harrop isn't willing to release the tune - if I can just get the correct MAF calibration, that would be amazing.
johan is offline   Reply With Quote
Old 12-28-2016, 05:56 PM   #185
Kodename47
Kodename47's Avatar
Drives: UK GT86
Just run the tune in closed loop until you get to the dyno. Will be fine to drive and won't take long to get the MAF right on the dyno. If in doubt, just bump the stock scale up a bit to be on the safe side. Log the trims a bit at idle and see where it's sitting.
Be interesting to see a MY17 FI tune, the WOT fueling control is different to previous ROMs.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-28-2016, 06:22 PM   #186
johan
Yes, the fueling is different - it threw us off at first when we started tuning my car. It's more Toyota-esque and less Subaru-esque.
Old 12-28-2016, 11:17 PM   #187
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Just saw your email. I've already worked with Delicious to create a Harrop specific tune. I'll talk to Zach and see if we can get you a start up map.
The Racers Line is offline   Reply With Quote
The Following 2 Users Say Thank You to The Racers Line For This Useful Post:
CxG (01-10-2018)
Old 12-29-2016, 03:59 AM   #188
johan
Awesome thanks!
It's a 2017 Automatic
Old 12-29-2016, 12:09 PM   #189
gtengr
Drives: 2017 BRZ
Is that a pro or con?
gtengr is offline   Reply With Quote
Old 01-04-2017, 05:02 PM   #190
HarropOz
Drives: Harrop TVS1320 Supercharged 86
Let me get back to you on that one Johan, perhaps flick us an email at sales@harrop.com.au
HarropOz is offline   Reply With Quote
The Following User Says Thank You to HarropOz For This Useful Post:
The Racers Line (01-05-2017)
Old 01-04-2017, 05:49 PM   #191
johan
Email sent, thanks for the response.
Old 01-13-2017, 01:00 PM   #192
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
It can be done. With ease. :-)
-Zach
Old 01-27-2017, 05:51 AM   #193
Bfranklyn86
Drives: GT86 Harrop S/C
Ok Guys...
Minimumn Pulley Size is 65mm - Requiring E85 to avoid Knock. should see 17-18PSI
Our car is running the 2.1l HKS Stroker Kit, and the 65mm Pulley, Plus some new enhancements making 315KW At The Hubs. Thats 422HP, and then to convert that to Engine HP, which you americans love.... factoring in a rough guess at 20% Drive Train loss thats 506HP at the Engine.
Hows that sound????
We run this on our Track Car, with no Issues with IAT, Please see the below chart with our track data from our MOTEC.
Thanks for that info @HarropOz
Could you elaborate on how you took the power output from 364whp (e85) when you initially put the stroker kit in, to to the 422whp quoted here. That's a pretty sizeable increase for a few tweaks!
I'm also interested to know what proportion of your customers go for the smaller 85mm pulley on stock internals and 98oct. Is it a rarity, or fairly common?
Many thanks.
Bfranklyn86 is offline   Reply With Quote
Old 01-31-2017, 01:37 AM   #194
Irace86
Any CARB updates?
The Following 2 Users Say Thank You to Irace86 For This Useful Post:
funwheeldrive (03-15-2017), TheGuyWithTheFireStorm (01-31-2017)
Old 02-01-2017, 11:07 AM   #195
G-Unit86
Hi guys i'm looking to buy a SC this spring for my BRZ and I've narrowed it down to an Bedrock or Harrop. I really like the packaging of the Harrop, and leaning that way, but i have 2 questions.
1st: @HarropOz, looking at your tack data do you know what you ROA was, and how does that compare to a stock pulley setup?
2nd;
Also has any one ran this kit with an aftermarket CAI, I currently have a Perrin Intake on my car, so I no longer have the stock air box in the car. I would have to dig it out of my parents basement back in Canada. I'm currently living in Michigan so not to much of a heart ache.
Thanks
G-Unit86 is offline   Reply With Quote
Old 02-01-2017, 01:06 PM   #196
johan
2nd;
Thanks
re: intake
I've wondered the same myself, eyeballing it from pictures - it looks like there's a -slight- possibility you could make it work if you modified a silicone coupler to fit.
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 05:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 03:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
