#183 |
Drives: Scion FR-S Whiteout
Quick Note: DDM Tuning H1 bulbs doesn't fit the Mini H1 projectors.
-Sent from outer space
2013 Scion FR-S
#184 |
Think we found the issue. His bulb vs my bulb.
This makes sense of the pattern he was getting since the focus point is different on the much shorter bulb. Sent from a Motorola DynaTAC 8000X |
#186 |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Did u order the same kit from the retro fit source? Which bulb is who's?
#187 |
Mine is the long one. Yes we ordered the same kit just a different bulb temperature. He contacted the retrofit source this morning and said they shipped him the wrong bulbs so they are shipping new ones to him.
| The Following User Says Thank You to Yruyur For This Useful Post: | FR-Shadow (07-30-2013) |
#188 |
What was the temp of the ones that were so much brighter? The comparison pics was night and day.
#189 |
6k. But we will take more comparison pics because they should be both bright once he gets the correct bulbs.
#190 |
5000k should be even brighter.
Sent from my SGH-T889 using Tapatalk 2
2013 Scion FR-S
#191 |
Drives: 2013 Scion FRS
#192 |
Awesome!
2013 Scion FR-S
#193 |
So is our cutoff correct or should the dips line up so there is only one?
Also is it possible to "focus" the beam by moving the bulb in or our of the housing. I thought I recall the bulb sitting on something that coukd be moved via a nut. Sent from a Motorola DynaTAC 8000X |
#194 | |
As for the right one, the driver side bows down the sides a bit too much on the right. The hotspot of the passenger side also seems a bit too high that the actual usable light gets lost in the cutoff. So yeah, the top lines of both cutoffs should line up. The dips shouldn't though, the space between them should equal your headlight horizontal spacing. ![]() I wouldn't really worry too much though, these are the Mini H1 projectors and they will rarely be perfect. I would say the left one is a 9, while the right one is 8.5.
2013 Scion FR-S
#195 |
@retrosmiths @civicdrivr
What do u think? The projectors were wide and i brought them in. I also lowered the beam to 21.5 in above the ground. My question is why is the left crisper and more blue cut off and the right side is just normal kind of
#196 |
One of them needs rotation (see double side lines).
Right side, check bulb seating.
2013 Scion FR-S
| Morimoto Retro-Quik Xenon Retrofit System for FR-S | Xenocide117 | Cosmetic Modification (Interior/Exterior/Lighting) | 63 | 07-18-2014 07:37 PM |
| The Retrofit Source Bi-Xenon FR-S Retro-Quik Conversion | Andrew @ TRS | Exterior Parts - The Rest | 84 | 07-23-2012 09:43 PM |
| OEM Fog Light install! ON and working! | 86design | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 38 | 07-04-2012 07:11 PM |
| How to install Homelink mirror? | Grimlock | Electronics | Audio | NAV | Infotainment | 10 | 06-10-2012 06:07 PM |
| Five axis limited retro | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 05-18-2012 03:16 PM |
