#183 |
I'll post vid's once I get the new pipe in. Most likely a month from now.
#184 | |
Drives: '87 Corolla GTS, '13 FR-S 6MT
I have the new style over/front pipe. I went with the 3" which has the standard style resonator AND the new ball type helmholtz. I can confirm that the "VVT rasp" is gone. |
The Following 3 Users Say Thank You to RiskyTrousers For This Useful Post: |
#185 |
Drives: 2014 SSM BRZ
I just got mine tuned after searching for a leak over the last two weeks. Gave up after new gaskets. Didn't realize it was vvt that was causing the rasp. Would I need to retune for new resonator design or am I good to go even with 3in. Are all the new fp/op on their site shipping with new style resonators?
#186 | |
Drives: 2013 FRS Whiteout
Nameless Performance Overpipe/Downpipe Combo
So the new 3" has the ball style helmholtz? I thought only the 2.5" had them and the 3" had a regular long tube resonator? Either way is good to know the rasp is gone.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
The Following User Says Thank You to yomny For This Useful Post: | Jrdad (08-24-2014) |
#187 |
#188 |
Drives: 2013 Scion FR-S Raven
Does the EL header you're running have a catalytic converter?
My setup is the FA20club EL Header with primary cat, Perrin Overpipe, Nameless Catted Front Pipe with older style Helmholtz resonator, stock exhaust, Perrin Tips. Running OFT 2.0 EL Header 93 octane tune, MAF rescaled No drone and just a hint of "buzz" from 4000-4800 rpm's during wide open throttle only
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#189 |
#190 |
Tire Destroyer
Drives: Firestorm+snail
#191 |
To better match the 3" header collector. The front pipe does taper down to 2.5" at the cat-back flange. As a bonus, this actually fit better than the 2.5" and has a deeper exhaust note.
The Following User Says Thank You to RiskyTrousers For This Useful Post: | Rosticles (08-26-2014) |
#192 |
Making me want to switch over. All new op/fp have ball resonator even though it doesn't show it right?
#193 |
I was told all the new orders of downpipes were getting the new design, they just haven't had a chance to update there photos. I would specify you specifically want the new design in the purchase notes just to be safe.
#194 | ||
Here's a pic. ![]() |
#195 | |
Drives: 2013 Scion FRS firestorm
I wanted to go that route but was worried about noise level and cost as I already have the 2.5" dp and 3" axleback. |
#196 |
Thank you for adding the pictures! It is a great help.
Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 02:23 AM |
Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 04:57 PM |
Vitamin R from Nameless Performance. | Jason@Nameless | BRZ Photos, Videos, Wallpapers, Gallery Forum | 4 | 06-22-2012 11:27 AM |
We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-18-2012 11:32 PM |
Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 04:32 AM |
