Old 05-08-2015, 04:58 PM   #1919
DC2R
Drives: 2014 Scion FR-S
Originally Posted by shadoken View Post
I am considering upgrading my AudioUnit and was stuck between this and the Pioneer 8000NEX.
I want the NEX because it has CarPlay , but this one is much cheaper and essentially does the same thing since it has android in it. If anyone has used both How is the experience on this compared to CarPlay? Smooth Lag-free..etc?
Also how the Maps App on this thing. I heard you can use Google Maps? But how does that work without internet connection. Does this allow you to tether to your iPhone via USB or Wifi?
For me the Pioneer are way too expensive. You don't even get capacitive touch until you get over $800 last I checked.
If you want lag free look elsewhere. This is a single core at 1 Ghz. The performance is less around what a flagship phone was in 2010. I compare it to MyTouch 4g from back when froyo was the flavor of Android.
That being said it is a decent unit and leaps better than anything else I have seen in person.
This unit supports a USB modem or you can use your phone's Wi-Fi hotspot. You can download offline maps in Google maps or use one of the apps that doesn't require network.
Personally I just always tether and use Waze.
DC2R is offline   Reply With Quote
Old 05-08-2015, 05:44 PM   #1920
shadoken
shadoken's Avatar
Drives: FRS RS 1.0
Thanks , So USB tethering is an option then. Thats great , I will mostly have my phone. But apart from that , does it have any inbuilt NAV? Since I dont have good signal when am outside any major metros (Tmobile ).
Also does Waze allow you to download the entire USA maps?
shadoken is offline   Reply With Quote
Old 05-08-2015, 05:50 PM   #1921
DC2R
USB modem is option. If you want to use phone you most broadcast a hotspot.
I use Waze online for traffic based routing.
Sygic seems to be the preferred option for offlinebut is not free. I tried but didn't like it.
When my tethering was broken I would download offline maps of my area in Google maps.
Old 05-17-2015, 06:41 PM   #1922
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
Has anyone had issues with extreme static or audio drop-outs? I was having audio drop-outs that seemed to coincide with bumps, so I assumed my connections came loose. (Probably unrelated, my rear camera also stopped working.
So I took out the unit to check all the connections. Nothing seemed loose, but i reconnected everything. When I turned on the car, I got good sound for about 15 seconds, then no audio (and still no rear-camera). If I turn up the volume I can hear intermittent static using USB and the radio app even when still, so its not a loose connection (well I doubt it is). I'm starting to think its something inside the unit.
Anyone have ideas before I put the stock HU back in for testing?
milhouse is offline   Reply With Quote
Old 05-17-2015, 07:00 PM   #1923
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Plug the stock HU back in and see what happens.
Pwolf is offline   Reply With Quote
The Following User Says Thank You to Pwolf For This Useful Post:
DC2R (05-17-2015)
Old 05-17-2015, 09:00 PM   #1924
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
I had issues like that for a while. Tapping the screen with a bit of force did the same thing. It eventually sorted itself out.
SilverlightPony is offline   Reply With Quote
The Following User Says Thank You to SilverlightPony For This Useful Post:
Kevinn (05-18-2015)
Old 05-18-2015, 03:04 PM   #1925
milhouse
Because Racecar
milhouse's Avatar
Awesome - I got out my old HU and for some reason the SD Card was gone. Hooked it up anyway (thinking it might just be for maps) and it won't even get past the Initial screen. Anyone have an image they would be willing to share?
Old 05-19-2015, 07:14 AM   #1926
Kevinn
Drives: 2014 BRZ Limited, Black, Manual
The stock BRZ Head unit may have an antitheft feature on it. But I could be mistaken. Maybe it's still covered under factory warranty? There's SD images on this forum elsewhere, you'll have to search for it.
Kevinn is offline   Reply With Quote
Old 05-19-2015, 09:53 AM   #1927
P3tras
Drives: Subaru BRZ '13 WRB
Image will not work. Files in the card are encrypted with card ID. Unfortunately, there is no way to use it without original SD card (SD will work from other models, including Toyota cars, using same type Fujitsu head-unit).
P3tras is offline   Reply With Quote
Old 05-20-2015, 12:51 PM   #1928
petr
Drives: Mazda Miata
There's a 2015-03-18 rooted firmware on official forums http://ca-fi.com/forum/viewtopic.php?f=26&t=4751
But I haven't tested it!
petr is offline   Reply With Quote
The Following 2 Users Say Thank You to petr For This Useful Post:
DC2R (05-21-2015), Kevinn (05-20-2015)
Old 05-20-2015, 01:34 PM   #1929
Kevinn
Thanks for this! I'm still on the 9/21 rooted firmware. Wouldn't be interested in this radio if it wasn't for root...
I can't test the firmware, will be busy. Hopefully someone else can chime in?
Old 05-20-2015, 01:55 PM   #1930
The_Understated
Hooner in training... eh?
The_Understated's Avatar
Drives: 2013 Scion FRS
Anyone else notice the website pricing is down to $429? Is this normal or because they're out of stock??
**Dunno what to put here yet... Imagine something witty...**
The_Understated is offline   Reply With Quote
Old 05-21-2015, 12:03 AM   #1931
kwebb1086
Drives: asdasdf
I will mainly be using the headunit to listen to Pandora while Waze runs in the foreground. Based on what i have read, that should work just fine. However, does this also work with FM radio and waze/ google maps audio? Or is the FM function an application that exists outside of the standard android system? I hope that makes sense.
kwebb1086 is offline   Reply With Quote
Old 05-21-2015, 12:11 AM   #1932
The_Understated
Far as I'm aware the radio should act like any audio/music source in android so shouldn't be affected by whether or not it's the active screen. Meaning you can activate the radio, switch to Waze and still have it playing in the background. Same goes for most other music apps. Unless the new app you're running takes over the active audio source (like some games do; IE trials fusion), you'll be fine.
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
