Old 07-01-2014, 10:32 AM   #1919
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by PolishFrs13 View Post
Any advice on how to up the power for it than ? it would be much appreciated!
What @mike the snake said are two of the ways:
1. Lower compression pistons
2. Some form of additional octane or cooling like E85 or meth
3. A larger turbo
My question would be why are you set on the 350 whp goal? You can do between 300 and 350 whp with the GTX28 no problem and reliably.
Old 07-01-2014, 11:03 AM   #1920
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Added a link to @No Limit Motorsport 's second Full Blown build thread.
Old 07-01-2014, 03:52 PM   #1921
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
I hit 360 dynojet numbers, 93 octane, 12 psi, reliably, with knock control on, several pulls, with crappy dyno fans. But I do have a gtx35
Ironsquid is offline   Reply With Quote
Old 07-01-2014, 06:15 PM   #1922
P86RAVES
Drives: 08 WRB WRX STi / NA Miata
What was your TQ at?
P86RAVES is offline   Reply With Quote
Old 07-01-2014, 06:18 PM   #1923
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Hows ljs e tune?
Old 07-02-2014, 09:01 AM   #1924
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
It was over 9,000.
I can't remember it was a while ago at a friends dyno, no sheet. It was more of a preliminary run before we added additional fuel.
Old 07-02-2014, 09:29 AM   #1925
P86RAVES
It was over 9,000.
It's all good. I was asking because I'm trying to see how these things make power and torque relative to the EJ.
Old 07-02-2014, 10:13 AM   #1926
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
There's plenty of turbo dyno sheets if you search on here that show hp/tq. Most of the turbo vendors have sheets you can compare to EJ.
Old 07-02-2014, 10:27 AM   #1927
Reaper
Reaper's Avatar
Drives: violent
Gtx28 if you want the torques.
Old 07-02-2014, 10:56 AM   #1928
King Tut
NASA SpecE30 Racer
King Tut's Avatar
They make torque similarily to an EJ in that max torque will normally be reached when max PSI is reached. None of us are running those little baby OEM Subaru turbos though so we don't get that big initial low RPM PSI surge and torque spike that most EJ motors have. We are able to maintain max PSI and a flatter torque curve closer to redline with a properly sized turbo. There is a forced induction dyno thread if you want more info. @Ironsquid is one of the few running a GTX35, so his torque plots would look very different than mine with a GT2871R:
Old 07-02-2014, 10:33 PM   #1929
Reaper
Reaper's Avatar
Drives: violent
Mine is in my build thread. Lotsa torques!
Old 07-03-2014, 07:13 AM   #1930
Boba_kz
Installed Koyo radiator + FBM fans and shroud + FBM oil cooler
Still have a problem with overheating (250F)
Outside temperate +38C (100F)
Boba_kz is offline   Reply With Quote
Old 07-03-2014, 08:04 AM   #1931
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Oil temp. 250 or water temp 250?
Just cruising around, tracking, driving it hard?
Old 07-03-2014, 08:44 AM   #1932
Dipstik-sportech
Dipstik-sportech's Avatar
Are u idling it for 4hr straight or something? Did u bleed the system? Are the fans coming on? 250° is damn near head gasket failure temps
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
