Old 01-07-2016, 05:08 PM   #1919
FastWhite
Drives: Subaru BRZ Limited M/T
I too would like some light wheels. But I am also aware that light wheels can be more "fragile" so I will be content with my choice. These are my race set.
So many things to do for the new season. We can do the radiator, oil cooler and put on a new steering wheel. A nice 'D' shaped wheel would be nice.
My poor pocket book.
FastWhite is offline   Reply With Quote
Old 01-07-2016, 05:17 PM   #1920
justinco
justinco's Avatar
Drives: 2022 GR86
Originally Posted by smg1138 View Post
Looks like my stock brake pads are just about due to replacement. What pads are you guys using for STX? I'm looking for something better than stock, but won't squeal like crazy on the street. I don't mind some dusting as long as it washes off fairly easily and isn't corrosive.
I got HPS for my FRS, however I have not used them yet. Last time I used HPS/HP+ was on my CS Miata, they were ok.
I had Ferodo ds2500's on my STX e36 and they are a great pad.
justinco is offline   Reply With Quote
Old 01-07-2016, 05:23 PM   #1921
justinco
justinco's Avatar
Drives: 2022 GR86
Radiator/steering wheel is allowed so long as no performance (ie: weight reduction, smaller size, etc) benefit, right? Or did they change the proposed rule to be different?
If that is still the case, I do not see any reason to change the wheel or radiator, unless you just want a cooler looking wheel? (I would have done this for the ugly wheel on my e36 hah)
Old 01-07-2016, 06:06 PM   #1922
strat61caster
strat61caster's Avatar
I also thought that steering wheel swaps must not be lighter than OE so no weight advantage there.
Unless of course you're asking so you know how much weight to add to it...
ineedyourdiddly
Old 01-07-2016, 06:08 PM   #1923
e1_griego
e1_griego's Avatar
Drives: Many
Exactly what i'm asking. How much weight to add.
e1_griego is offline   Reply With Quote
Old 01-11-2016, 11:09 PM   #1924
justinco
justinco's Avatar
Drives: 2022 GR86
Thoughts on battery holders for lightweight batteries? I have a LFX24L3-BS12 and would rather not spend $100+ on a battery tray.
Also, thoughts on rear shock top mounts (the 1" or 2" Raceseng style)? Necessary or no?
Old 01-12-2016, 01:30 AM   #1925
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by e1_griego View Post
Does someone want to weight a stock steering wheel/airbag setup -- you know, for science? Or have access to an uninstalled wheel?
I'm just curious how much heavier it is than a hub/QR/sparco setup.
Here ya go (been done)
Originally Posted by Anthony View Post
Yes. It weighs 6.24lbs with the cruise control lever.
Old 01-12-2016, 09:06 AM   #1926
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Some sort of DIY will probably be best. I made my own out of carbon fiber: thread.
But before that, it was just zip tied in place.
They weren't real enthused about that zip ties at autocross, but they let me slide. I wasn't in STX though. Now that I have the carbon bracket, no one complains.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 01-12-2016, 11:38 AM   #1927
justinco
justinco's Avatar
Drives: 2022 GR86
Thanks, I was thinking the same thing. Need to pull the batter out of my car and see what kind of attachment points are available for a base plate.
Old 01-12-2016, 11:41 AM   #1928
Anthony
Weight Nazi
Anthony's Avatar
For the base, I just drilled some self-tapping screws right into the chassis. The battery is attached to the base using a liberal amount of 3M double sided tape, which is more than enough to hold the little guy down to the plate, and then the plate is screwed to the chassis. That's actually plenty to keep it in place. The top bit is there to keep it from moving too much, but really it's more for looks since the base hogs all the function.
Old 01-13-2016, 07:07 PM   #1929
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by vroom4 View Post
I'll be parting my entire car this weekend, if anyone wants a national trophying setup for the cheap, I'm ready to deal for a package buy.
Have both wet and dry wheel setups ready to go. I'll even include your base alignment specs and shock settings for different surfaces
What are you going to run instead?
Old 01-13-2016, 11:27 PM   #1930
vroom4
No idea. Car is 100% stock as of an hour ago
vroom4 is offline   Reply With Quote
Old 01-14-2016, 02:24 PM   #1931
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Wanna buy a GTI?
Old 01-14-2016, 08:35 PM   #1932
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Trying to sell everything together or going to sell parts separately. I might be interested in some items.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
