Old 09-05-2021, 03:00 PM   #19293
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Finished off my RT660's. 3 sessions into the 5th day and they gave up and started coming apart.
Old 09-05-2021, 08:21 PM   #19294
soundman98
ProCrastinationConsultant
soundman98's Avatar
maintenance!
new battery, as the 7 year old original was starting a little hard, and didn't want to go into fall/winter with it.
new serpentine belt, the original had 1 crack in it that would make it squeak on startup after moisture or cold
did a double-oil change as well. was admiring how handy the fumoto valve is, so i opened it up to drain out the old oil, and started re-filling before closing it. i think i only lost a quart to the process!
in the process of a paint detail. it's been 5 years, time to re-wax, and some very minor scratch correction.
and finally fixed the crusty headlights that have been bothering me.
Old 09-07-2021, 12:27 PM   #19295
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Installed JDM style exhaust hangars to try and address some minor cabin resonance (totally gone now!) and Verus Non-aggressive rear diffuser.
I'm actually quite glad that I decided to take off the old OEM style rep. "diffuser". 100% of the bolts and connection hardware were rusted, seized, and snapped upon removal after only a few years of being on the car. You get what you pay for I suppose.
Functional aero on a car that never sees the track? Sounds about right
wolffbite is offline   Reply With Quote
Old 09-11-2021, 05:49 PM   #19296
magbrz
Drives: 2020 BRZ w/ PP
Installed FTSpeed Steering Wheel
I took advantage of the Labor Day sale and bought the FTSpeed carbon fiber and leather steering wheel. Install went smoothly and I love the flat bottom, makes it easier to get in and out.
magbrz is offline   Reply With Quote
Old 09-25-2021, 10:50 PM   #19297
Grady
Grady's Avatar
Bought my BRZ a friend!
Old 09-26-2021, 12:05 AM   #19298
soundman98
soundman98's Avatar
the rangers are good companions!
Old 09-26-2021, 01:43 AM   #19299
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
WHAT DID YOU DO TO YOUR BRZ TODAY?
Haha snap! Great combo
(86 awaiting coilovers)
ACT86 is offline   Reply With Quote
Old 09-26-2021, 07:30 PM   #19300
wizmatics
Drives: '18 BRZ 50th, '07 Prius (yeah...)
I was dead set on buying an aw11 mr2 two weeks ago, but got beaten to the punch. Got beat to the puncheon? Got a beating in the paunch? Oof! Anyway, I really wanted to give my brrz a sibling that doesn't suck. Kudos!
wizmatics is offline   Reply With Quote
Old 09-27-2021, 08:02 AM   #19301
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Drained and filled the transmission with Redline MT-LV.
dragoontwo is offline   Reply With Quote
Old 09-28-2021, 04:00 PM   #19302
dragoontwo
dragoontwo's Avatar
I replaced a thing, and added a thing. Will test drive later tonight.
Old 09-28-2021, 04:05 PM   #19303
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
TS crossmember and draw stiffeners ?
Old 09-28-2021, 04:06 PM   #19304
dragoontwo
dragoontwo's Avatar
Yep. Have had the flex v-bars for a while.
Old 09-28-2021, 08:17 PM   #19305
norcalpb
norcalpb's Avatar
Did you need to jack/support the engine to install the updated crossmember?
Old 09-28-2021, 08:49 PM   #19306
dragoontwo
dragoontwo's Avatar
Yes. I supported the transmission just behind the crossmember.
The biggest pain was removing all the dang body clips on all the panels.
