Old 07-03-2018, 07:28 PM   #19209
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by Aipex8 View Post
I have been thinking about one of the two available pedal spacers, but both are 1" and I'm afraid that is too much. Looks like shaving it down to 1/2" is a possibility!
If you have access to CNC, might be worth it... but keep in mind that when you do shave off the spacer, you do need to shave off few mm of bolts. Bolts that come out of firewall are bout 1”, that’s why all the pedal spacers are 1” thick. It’s a bit awkward angle you gotta be to grind it off, but I did it without an issue.
Old 07-03-2018, 09:07 PM   #19210
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
You forgot that maybe the route was all downhill …
humfrz
That would've made the drive even more fun.
But really, 459.2 miles from 11.637 gallons.....39.46 mpg.
Interesting for me, the station I found to fill up only had 92 as their highest octane. Never encountered a station with a 92 before.
No real witchcraft involved, just the benefit of having the automatic spinning everything at lower rpms at the same speeds....even then, I was not expecting to be knocking on 40mpg's door in this car. That's the same personal best I got from my old 03 Corolla.
Oh, and I did the posted speed limit pretty much the whole time (55-70 depending on state), no sandbagging. Just sat in the right lane and let everybody else go by. Even encountered an older twin in Hot Lava somewhere in North/South Carolina.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 07-03-2018, 09:33 PM   #19211
humfrz
Well, that's good mileage for sure …
I thought maybe you had filled up in Denver and coasted to Wichita ..
humfrz
Old 07-03-2018, 09:43 PM   #19212
Ashikabi
Ashikabi's Avatar
When I first bought mine I got 40mpg on the highway. Then I tuned it and that went to shit
Old 07-03-2018, 10:56 PM   #19213
dnieves
Drives: FR-S 10 Series
Got the FR-S back, cause of leak was a creased crush washer. Dealer replaced the washer and topped off the oil. Second oil change since Saturday, does this count as a flush?
dnieves is offline   Reply With Quote
Old 07-04-2018, 12:21 AM   #19214
humfrz
I figure a "creased" crush washer, was one that had been used before and tightened down too tight on its second use …
Yep, you got "flushed' fer sure.
humfrz
Old 07-04-2018, 03:44 AM   #19215
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Or maybe a dealer dusching
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 07-04-2018, 11:07 AM   #19216
BreakTraction
BreakTraction's Avatar
Finished installing the Wide body kit
Cut the rear fenders and welded them as well as sealed them with silicone. Car is coming along nicely.
Insta: @BreakTraction.
Youtube/ Documenting the Build: Break Traction https://www.youtube.com/breaktraction
BreakTraction is offline   Reply With Quote
Old 07-04-2018, 05:18 PM   #19217
humfrz
Originally Posted by BreakTraction View Post
...............Cut the rear fenders and welded them as well as sealed them with silicone. Car is coming along nicely.
Oh, my, are things getting that rough in Philadelphia ..??
I reckon a little extra armor never hurt anything.
"jest ah messen wich ya" - pay old humfrz no nevermind ..
Seriously, it looks like you did a nice job ..
humfrz
Old 07-04-2018, 08:58 PM   #19218
dnieves
Washed, clay bar and waxed. Worth it despite the potential of heat stroke.
BTW Old timers are right, Liquid Glass is pretty good.
FYI Coke Cola doesn't remove synthetic oil stains from pavers. Pretty much nothing from Home Depot does either.
Old 07-05-2018, 12:04 AM   #19219
humfrz
From the Farmers Almanac ..
"Liquid dish soap or laundry detergent will remove most oil stains on pavers. Directly apply the soap to the stain and allow to sit for 20-30 minutes. Then scrub with a nylon bristle brush and rinse with hot water. Repeat this step as needed".
humfrz
Old 07-06-2018, 11:35 AM   #19220
trvth
trvth's Avatar
Drives: '15 Halo Scion FRS, 1999 Saturn SC2
After 3 years, 3 months, and 12 days ....
2015 Halo Scion FR-S 6MT new w/TRD exhaust, cold air intake, quick shifter, sway bars, lowering springs, & brake pads. Since then, TRD door braces, strut tower bar, & battery tie-down, Motul fluids in trans/diff & brakes, GrimmSpeed master cylinder brace, Stoptech stainless brakelines, OpenFlash Header 3 w/overpipe, OpenFlash Tablet on E85
trvth is offline   Reply With Quote
Old 07-06-2018, 11:42 AM   #19221
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
you had the cruise control on doing 33?
fx1mark is offline   Reply With Quote
Old 07-06-2018, 12:11 PM   #19222
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
He didn't want to die while taking a picture while driving.
carsebuco is offline   Reply With Quote
